(#9551)
boost junkie boost junkie is offline
Car: bmw
Default 08-19-2015, 05:12 AM
Originally Posted by _ink
Great update!! menu 11 adjustability has helped greatly in pedal feel from 0-50%, I have mine set @ 2000.
Loving menu 11 too. Nice work Terry!
K.Jameel K.Jameel is offline
Car: BMW E92 N54
Default 08-19-2015, 06:12 AM
That just an brilliant update Terry
I'm keen to set meth Addictive to 75 without any issue or switch me to map 4 after several pulls, now really i need those inlet .
BMW 335i '08 E92 N54, JB4 G5 IOS, BMS DCI, VRSF ***, BMS-Tial BOV Kit with Chargepipe, VRSF FMIC, BMS Meth Kit, JB4 MHD BEF, BMS PCV valve, BMS OCC. TCU Alpina_B3 Flash, .
tim603's Avatar
tim603 tim603 is offline
Car: 07 E90 335i
Default 08-19-2015, 06:51 AM
So I just got my JB4 (finally) and I am trying to understand all the vocab and settings. Unfortunately alot of these Acronyms are defined by using other acronyms so it makes it somewhat difficult to understand. Hopefully someone doesn't mind helping!
What is PID Gain?
Where should the FF/Wastegate Adaptation be set at and how do different values affect performance?
Is there any disadvantage to having my Fuel Open Loop set to 100? (Max throttle response / sensitivity 0-100% is what I want to try out for a little while)
Car: BMW E92 N54
Default 08-19-2015, 06:58 AM
What is PID Gain?
This thread should help
http://www.n54tech.com/forums/showthread.php?t=21269
tim603's Avatar
Car: 07 E90 335i
Default 08-19-2015, 07:08 AM
Originally Posted by K.Jameel
I know thats the thread that lead me to these questions lol it does have ALOT of great vocab and definitions but it doesn't describe any of these questions unfortunately
What is PID Gain?
Where should the FF/Wastegate Adaptation be set at and how do different values affect performance? Should I just leave this at 80 and let it adjust itself?
Default 08-19-2015, 07:33 AM
Originally Posted by dh58
Terry is oil temp as a parameter on the roadmap or planned?
I ask because i'm using the jb4 mobile app to display all my relevant gauges and this would be super helpful.
Not beyond FUD = 11.
tim603's Avatar
Car: 07 E90 335i
Default 08-19-2015, 08:58 AM
So is menu 11 still adjust fuel open loop or is that in a different spot now? Sorry brand new to all this and trying to wrap my head around it
bk335xi's Avatar
bk335xi bk335xi is offline
Car: 335xi 6MT
Default 08-19-2015, 09:01 AM
Menu 11 in the newest update is changed to adjust throttle input. FOL can be adjusted in the desktop interface, I don't think terry changed it to a new menu.
08 335xi 6MT | FBO
Default 08-19-2015, 09:07 AM
We'll adjust the wheel control sheet when more people are on v31.
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 08-19-2015, 09:08 AM
If you use firmware 30 or earlier then menu 11 for FOL but if you updated to latest firmware 31 then menu 11 will adjust padal-throttle and you can change FOL from windows interface only
ThaCuda's Avatar
ThaCuda ThaCuda is offline
Car: 2007 335i
Default 08-19-2015, 04:27 PM
With this V31, should all prior Duty Bias adjustments be restored to 0 and fud as well? I only ask to make sure I'm taking full advantage of the menu 11 changes.
2007 335i 4dr JB4, Hexon RR600, Inlets, 4Bar, Index 12, Boost Concept Pump, DCI, FMIC, DP and full exhaust, Burger Meth, MHD BEF. Auto.
Default 08-19-2015, 04:32 PM
The v31 changes have nothing to do with duty bias or FUD settings.
AbacusRacingN54 AbacusRacingN54 is offline
Car: 07 335i
Default 08-19-2015, 06:15 PM
Love v31..
BriaN54 BriaN54 is offline
Car: E92 335i
Default 08-19-2015, 08:24 PM
Originally Posted by AbacusRacingN54
Love v31..
I agree. This update has done more to help my wastegate rattle on acceleration than any other update.
Car: BMW E92 N54
Default 08-20-2015, 01:32 AM
+1
climax_E92 climax_E92 is offline
Car: E92 335i
Default 08-20-2015, 01:41 PM
Hey guys on the timing cylinder logging, how do i find out if i'm 4, i8aos or 5, IJOS. I have a late 07 e92 335i.. thanks guys
Rushan's Avatar
Car: 335i E92 2009
Default 08-20-2015, 01:46 PM
Usually 4 for all pre 03/2008 and 5 for newer, when you set the value you will start to see the timing on all cylinder 2 to 6 instead of flat 0 on all, so you should be 4 except if your ECU running old un updated software
Car: E92 335i
Default 08-20-2015, 01:50 PM
Thanks you for the quick response! I thought so. I do have it in 4, but after updating new firmware, I'm having weird numbers on ignition timing. Can you take a look and see what's wrong? AFRS looks lean too no? Thabks..
Default 08-20-2015, 02:00 PM
Logs go in the support area but your menu 12 looks too high. Should be at 2800rpm or less. Try 2200rpm for example.
Car: E92 335i
Default 08-20-2015, 03:12 PM
Apologies and thanks terry. When I checked it this morning, 12 was at 3400 I think. I will lower it to 2200 when I get off work thank you. Is menu 12 what's causing my timing to go to zero and lean AFRs?
Default 08-20-2015, 03:48 PM
It's causing boost to go too high, which would lead to those other issues.
elijahcole92 elijahcole92 is offline
Car: 97 Supra
Default 08-21-2015, 07:28 AM
Terry, i'm having a hard time understanding the v31 update. Could you explain or put in detail a little more the advantages/disadvantages/effects (spool, etc) with the new 10, 11, 12 settings?
Jcoccy335 Jcoccy335 is offline
Car: 2006 335i
Default 08-21-2015, 08:14 AM
+1
Can't wait to get this new FW hope it kills my WG rattle on throttle. Turbos have only done 1000miles .
2006 e92 monaco blue
Jb4 G5 ISO
Bms dci
Bms 3" *********
Forge cp and twin BOV
Bilstein b12 kit
If it ain't broke, break it.
Default 08-21-2015, 08:57 AM
Menu 10 & 12 are discussed in the JB4 FAQ: http://www.n54tech.com/forums/showpo...61&postcount=1
DK335i DK335i is offline
Car: 2007 E92 335i
Default 08-21-2015, 03:42 PM
I had the same overboost issue after the 31 update. Car would drive fine to work in the morning, but overboost immediately on the way home.. not sure why.
Yesterday I thought I fixed it by lowering menu 11 to 1000, but it did it again today. So after reading in this thread last night, I checked menu 12, and it was at 3500. Changed to 2500 and everything seems to be fine for now.
I think there's less wastegate rattle after the update if that makes sense. Besides these small issues after updating, I am happy with v31 so far..
'07 335i N54 | Wagner EVO 1 Performance FMIC | Injen Intake | JB4 (Map 1) | BMS Pump Flash
