(#9176)
Default 05-07-2015, 05:18 PM
The 4/2 specific maps and settings would be discussed in the back end flash thread. None of that applies to those who don't use back end flash maps.
Bullitt1841's Avatar
Default 05-07-2015, 05:49 PM
I do see it now. But it's only in the BB thread and not the MHD thread. I don't use BB so I don't read that one
bnd's Avatar
bnd bnd is offline
Car: 2008 N54 E92 335xi
Default 05-08-2015, 05:39 AM
G5_ISO_29
1) Modified duty bias & 3rd gear limiter such that duty bias values of 30 and below are ignored, and 3rd gear boost limit values of 10psi or below are ignored. This should help those who update firmware without reading the directions.
2) Modified fuel trim reading such that 0 = -33% fuel trims, 25 = 0% fuel trims, and 50 = +33% fuel trims.
3) Added a setting under FutureUseD = 98 that may help with wastegate rattle during decel.
No more wastegate rattle
I had horrible rattle that involved setting my DWP to 18. I set everything to your listed default values and used FUD 98 and it's wonderful again!
Thank you Terry!
2008 335xi N54 E92
MHD WedgeBQ
BMS JB4 G5 ISO
BMS Dual Cone
BMS OCC
VRSF 3" DP
VRSF 7" IC
VRSF CP
Tial Q BOV
Fuel-It Stage 2 LPFP
Alpina B3
NGK 5992
Canada335 Canada335 is offline
Car: 08 E92 335i
Default 05-09-2015, 05:59 AM
Has anyone else noticed a new pressure release sound when shifting, not under high boost? I installed the 28.9 firmware and this sound appeared. Does not sound like the DVs, and shouldn't be as they aren't providing any boost when it happens.
Default 05-09-2015, 08:17 AM
Yes.
Do you have a gauge to display your boost, digitally? With the JB4 Mobile app you can watch very small boost numbers.
What flash are you running?
Car: 08 E92 335i
Default 05-09-2015, 11:05 AM
Originally Posted by Bullitt1841
Yes.
I don't have a digital gauge, I will be getting the mobile app and trying that the next time I am at home. I'm running the JB4 on top of Dinan stage 2. Any idea of where the release would be coming from?
08 E92 335i
BMS DCI, VRSF 3" DP's, ETS 5" intercooler, ER charge pipe, Forge DV's, JB4 G5 ISO map 2 on top of Dinan stage 2, BMW performance exhaust, BMS OCC, UUC SSK and CDV delete
Selene's Avatar
Selene Selene is offline
Car: 2008 Sapphire black 135i
Default 05-12-2015, 12:50 PM
I love the exhaust note while using FutureUseD=98, but, almost all my BOV noise has disappeared... Anyone else notice this?
'08 135i 6-Speed... BMS Pump Flash, BMS JB4 G5, BMS 3" ***, BMS OCC, RB PCV, VRSF 5" Stepped FMIC, aFe DCI, Racewerks Charge Pipe w/ TiAL Q BOV, Modified Berk Exhaust
Selene's Avatar
Default 05-13-2015, 03:40 PM
Also... Tons of WG rattle on cold starts now... Shuts up when idle lowers.
kuch335's Avatar
kuch335 kuch335 is offline
Car: 07 335i Coupe
Default 05-13-2015, 03:49 PM
Same here.. still rattle on low rpm acceleration too. Used to be able to get rid of it with 12 set at 35 but moving 12 doesn't seem to change anything anymore.
2007 335i E92 AT - JB4 G5 ISO + BMS E85 Flash, MR5 Intake, VRSF ***, VRSF 7in FMIC, ER CP, Fuel-It Stage 1, RB PCV, UUC Corsa Exhaust, Sachs SRE Coilovers, M3 Control Arms, H&R Sway, BA Diff Lock, MDF Scoops, Tint, LED Int, LUX V3, CF Hood, Mini Battery
Default 05-13-2015, 04:16 PM
As long as FUD is not set to 98 nothing has changed in the last 10 versions with regard to wastegate adjustment or anything that would contribute or effect rattle. As far a FUD = 98 goes that may make rattle better or may make it worse, depending on what is actually wrong with your wastegates. Wastegates that are physically properly adjusted and not worn out should never rattle at any setting or position. So all these settings are just a matter of trying to mask a physical problem with software. As the wastegates further degrade expect to need to change settings. At some point no setting will mask it.
Indo Rider's Avatar
Indo Rider Indo Rider is offline
Car: 135
Default 05-13-2015, 05:13 PM
Ha, yeah, I'm there.
2009 135i 6MT Jet Black, FBO+
gsr1416 gsr1416 is offline
Car: 2008 bmw 335i e93
Default 05-16-2015, 11:13 AM
Just installed jb4 g5 I so on my 12 335is Dct and running firmware 29/0/2. I'm curious if I'm suppose to plug in the numbers on page 1 in user adjustment settings? Also is their anything special to do for dct? On page 1 it shows user adjustment settings however am I suppose to make changes under the tab methanol, or the last tab settings? Thanks
Default 05-16-2015, 11:35 AM
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 05-16-2015, 01:59 PM
yes make sure you have the latest interface, set all duty bais to zero, make sure you adjust the 3rd gear or set it to zero,
I don't think you need something special running DCT but I noticed my friend DCT runs much smoother after the MHD BMS flash.
Default 05-16-2015, 04:38 PM
great thanks rushan! Yes I am running latest interface as well. I read on another thread about dct models to setting fub=5 not sure where I'm suppose to change at though.. If anyone with dct knows about any settings to switch please chime in! Thanks
tjobeid tjobeid is offline
Car: 07 335i coupe
Default 05-17-2015, 11:04 PM
what happened to the "Reset DEFAUL option" and for people running back end flash, do we no longer need to set it to "n54 w/backend flash" option?
Another question, when running the backend flash now with the new interface all the options for AFR and CPS are still filled in. Does it automatically ignore them? I'm sorry if i missed something this thread is just way to long.
Rushan's Avatar
Car: 335i E92 2009
Default 05-17-2015, 11:41 PM
No reset default option to avoid issues, you can follow the 1st page to set the default values,
For backend flash you need to set the option 4/2 from streeting wheel, 4/3 for stock flash.
Make sure you download the latest interface and latest firmware, the AFR and CPS changed to AFR BAIS and Duty BAIS, make sure to set them all to zero if you use backend flash with option 4/2, if using stock flash 4/3 only Duty BAIS should be set to zero.
Make sure the 3rd gear boost also set correctly to zero or to your desired value.
JP.Williams JP.Williams is offline
Car: E93 335i
Default 05-19-2015, 11:20 PM
i haven't been around here for a long time, not been keeping up with the updates. i think im on about 28.5 and i got my JB4 in later 2014 around november i think?
Can i update to the latest version?
Recently been having some trouble, keep dropping to map 4 with half engine light. No faults before or after.
hendo hendo is offline
Car: e92 335i
Default 05-20-2015, 04:30 PM
Quick log of my car . 2007 auto .Car is fbo, jb4 29.02, bms e85 flash via mhd, map 2, e50 with fuel it stage 1, it feels slow to spool ...thoughts?
thanks in advance.
http://***********/u/hendo/jb4-mhd-e8...-6-10-11-17-18
Default 05-20-2015, 06:14 PM
thanks in advance.
Post in the support section.
Default 05-20-2015, 06:22 PM
You would need to log to find out why you're kicking to Map 4.
Shafer Shafer is offline
Car: 2008 e90 335i 6MT
Default 05-20-2015, 09:03 PM
Just make sure you read the firmware notes before installing it.
Then get some logs posted of the map 4 switch.
DSCOFF's Avatar
DSCOFF DSCOFF is offline
Car: 335i coupe N54
Default 05-21-2015, 01:31 AM
Hi Terry, With firmware 29, does that mean the fuel trims we see on the interface at idle say 25.0, previously, this would have been zero?
serhat06 serhat06 is offline
Car: 05 e55 amg/ 07 e92 35
Default 05-23-2015, 11:00 PM
Hi everyone, does any one know how often the pin 7 on (G5_ISO_29) triggers in second, for the two step? also is it a negative out put? any more info Volt, etc?
im trying to do with a relay from local store or use a transistor.
Default 05-24-2015, 09:19 AM
Around 10hz. The PID is setup for standard automotive relay.
