(#8451)
techjunkie's Avatar
techjunkie techjunkie is offline
Default 07-12-2014, 07:35 PM
Thanks for the update Terry,
harry$ harry$ is offline
Default 07-12-2014, 08:37 PM
Terry,
On the average ignition are you still going with the quietest cylinder or taking an average from all six....what kind of changes have been made to the ignition logic?
Default 07-12-2014, 08:41 PM
It's taking the "loudest" or lowest cylinder currently. But only if raw timing values on 2-6 are enabled.
ElSaigel ElSaigel is offline
Car: E93 335i '07
Default 07-13-2014, 12:36 AM
ISO 28 Notes
1) Added support for cyl 2-6 raw timing values & knock corrections and full time dual bank AFR logging. To use you must be running the 7/5/14 and later interface. To enable enter the appropriate value under CPS7000 for the software version your vehicle is equipped with. Most MSD80 are i8a0s, most MSD81 are ijeos.
CPS_7000 options:
i8a0s timing corrections: 1
ijeos timing corrections: 2
ilaos timing corrections: 3
i8a0s raw timing values: 4
ijeos raw timing values: 5
ila0s raw timing values: 6
How do I know if my vehicle is i8a0s, ijeos or ilaos?
JB4 G5 ISO, BMS DCIs, BMS 3" ***, VRSF 7" FMIC, BMS OCC, CP-e charge pipe with Tial BOV, BMS cowl filters, Fuel-it Stage 2 LPFP, BMS short shifter, BMS clutch stop, CDV valve deleted, Spec Stage 2+, map7@E60
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 07-13-2014, 05:29 AM
Yo Terry!
Idea with the oil gauge hijacking... Thoughts on having it switch to hijacking once oil temps reach a certain temp?
Really useful seeing its the only oil temp reading we can get.
m4xbmw7's Avatar
m4xbmw7 m4xbmw7 is offline
Car: F02/E82
Default 07-13-2014, 07:01 AM
http://www.n54tech.com/forums/showthread.php?t=20563
Most 2008 and earlier cars are MSD80 and take the I8A0S BIN, while most 2009 and newer cars are MSD81 and take the IJE0S BIN. If your 2007-2008 models has an IJE0S software version though be sure to upload the IJE0S file. Loading the wrong file for the DME type will result in a "PAF Mismatch Error" after writing and you'll need to rewrite the correct file.
blown07's Avatar
blown07 blown07 is offline
Car: 335xi, 335i
Default 07-13-2014, 08:00 AM
Sorry but I don't see a place to enter this "To enable enter the appropriate value under CPS7000 for the software version your vehicle is equipped with"
335i FBO,Meth,MHD,XHP3,LSD,GCLites 11.83@124.88
335xi FBO,Meth,MHD,XHP3,VTT stage1 11.58@121.67
erwan35's Avatar
erwan35 erwan35 is offline
Car: bmw 335i e92
Default 07-13-2014, 08:25 AM
Does the iso28 for bms flash user only?
_______________________________________\\\
BMW 335I E92 2007 RHD 6AT,FULL M3 BODYKIT,HYBRID TURBOS,BMS ADAPTER W/ 3.5BAR TMAP,VTT INLETS,JB4 G5ISO W/ MHD TREBILA FLASH,BMS ANTI-LAG,AEM METH KIT W/ FSB,BMS DCI,VRSF CHARGEPIPE & TIAL BOV,VRSF C@TLESS ***,FMIC,BMS OCC,BMS CABIN FILTER,MUFFLER CUSTOM BULLET,97RON PUMP GAS
Fuman Fuman is offline
Car: '09 E92 335i 6AT MSport
Default 07-13-2014, 08:27 AM
I've got that same clarification too. Does it mean CPS Column, 7000 Row?
E92 N54 6AT, JB4 G5 ISO, FBO, METH, E85 FLASH, PI, S2 LPFP
Bullitt1841's Avatar
Default 07-13-2014, 09:44 AM
Yes.
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 07-13-2014, 10:45 AM
The ISO 28 for timing values & knock corrections, this is for who running flash? Or also used for who on normal JB4 maps?
I mean do I need those if I'm not using backend flash? Sorry if my question seems silly but I'm trying to understand what it's used for
Default 07-13-2014, 10:55 AM
Originally Posted by _ink
Yo Terry!
Option 4/1 will turn on stealth gauge mode and only hijacks the gauges when the gas pedal is past 50%. That's how I run.
bmwsf bmwsf is offline
Car: bmw 335i
Default 07-13-2014, 11:00 AM
Related to this, can someone explain what timing correction and raw timing values actually do? Which do I want to choose (timing correction or raw timing value) if I have the JB4 Iso 28 and BMS backend flash in my 2008 335i?
2008 BMW 335i | JB4 G5 | BMS Pump Flash | 3" n54Tuning *** | 3" ER Charge Pipe | 5" ETS FMIC
Default 07-13-2014, 12:24 PM
It's normally used for those running a back end flash who are doing custom tuning or want a more in depth look at the effect of changes they are making. For the average user who doesn't log I don't think it will be very useful.
_ink's Avatar
Car: 335i DCT
Default 07-13-2014, 04:00 PM
What do you have your oil hijack?
I have it for meth flow, and once the engine is warm it would be good to have it constantly ready for meth flow indication.
Default 07-13-2014, 04:53 PM
It's in my sig. I think timing might be more important than meth flow, unless you're constantly having flow problems. If you have an FSB, your boost level should show whether or not your meth is flowing.
Now that I run JB4 Mobile on my Android, I can always take a look back at how my WOT was since autologging is turned on for me. BEST SETUP EVER, ha ha.
Default 07-13-2014, 05:49 PM
Yes.
Thanks! I was in the dark for awhile after doing that on instincts!
Fed Fed is offline
Default 07-14-2014, 11:42 PM
ISO 28 Notes
CPS_7000 options:
So could you please tell me what option I should use if I'm running an MSD80 IF80S? Thanks!
kboretti's Avatar
kboretti kboretti is offline
Default not a valid win32 application - 07-18-2014, 08:12 PM
I just get setup.exe not a valid win32 application when i try to install the new interface. So over windows. I wish this stuff ran natively on macs.
2008 335i JB4 30% E85
2006 325i Stock
sfvalley335i sfvalley335i is offline
Car: 335
Default 07-19-2014, 01:06 AM
what happened to the drop down menu in the settings tab in which you would select the motor type and bms flash or not...?
musc's Avatar
musc musc is offline
Car: 335is DCT
Default 07-19-2014, 02:04 AM
I don't think they have separate selections for flash or no flash. Just choose based on engine type.
335is DCT
Rushan's Avatar
Car: 335i E92 2009
Default 07-20-2014, 01:47 PM
With the new interface there is no reset defaults?
How to reset to defaults now? I had that option on the older interface but it's gone with the new interface update
Default 07-20-2014, 02:19 PM
I'm not really understanding that one either. I have recently had everything in my User Adjustment tab go to all '0's while driving (likely from a JB4 Mobile for Android bug) and I had no way of getting the car to drive properly until I hooked up my laptop with the availability to restore defaults. This was not good for me because my entire Map 6 settings got wiped out, and my DWP was at zero, therefore not boosting at all. This has happened twice so far, but seems to be working fine on the latest JB4 Mobile release.
I need this feature back.
Element's Avatar
Element Element is offline
Car: BMW 135i N54
Default 07-22-2014, 02:11 PM
+1
Thankfully I haven't updated all of my devices so I have an older version to use for now.
2016 F22 M240i | 8ZF
rif75's Avatar
rif75 rif75 is offline
Car: Bmw 335i N54 JB4 stage 3 + Bmw M5 F10
Default 07-27-2014, 04:11 PM
Hello guys
I have a pretty special 335i n54 of 2007 with 2 turbos KKK K04, the same one of Audi S3, a lot of person told me that it is a great turbos, it can take more than 21 psi. My car has forged CP piston with 9.5.1 compression set. Wagner intercooler and **.
I'm now running with the map5 and map7 with 50% of e85 and my question is what is the best flash for me, the e85 or the one for bigger turbos?
Since I have big turbos and forged engine, what s the max pressure I can give with the map 6?
I have some engine fault in 5 and 6 gear after 5000rpm, even when I put my car on the dyno...The fault go away directly without cuting the engine. I think maybe it's because I need the e85 flash.
Thank you guys.
