(#8201)
Force[FED]'s Avatar
Force[FED] Force[FED] is offline
Car: '08 535i 6AT
Default 02-14-2014, 11:21 AM
To pass an OBDII code reader inspection the car must be in Map 0 which bypasses the JB4.
Wish I had remembered this before I took my '08 535i through inspection recently, and it failed because it was not in a "READY" status. DOHHHH. Does anyone know, if I change it to map 0, do I have to get a few hundred miles on the car to get all the tests to run? Does setting it to map 0 clear the saved values for all the tests they care about for OBD2 checks?
Kev
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 02-14-2014, 01:37 PM
I changed it to map 0 just before the emissions, and it passed ok with dp fix and ******* dp
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E45,
Fuel-it! Stage 2 standard,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.020")
robc1976's Avatar
robc1976 robc1976 is offline
Default 02-14-2014, 05:23 PM
so no need for driving in map 0 cute a 100 miles or so?
najin23's Avatar
Car: 335i CDV
Default 02-14-2014, 06:11 PM
at least i didnt as far as i remember. i assume you have one more chance left. if in doubt, drive around 100miles with the map0. but jb4 is instantaneously on/off like computers.
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
335i__'s Avatar
335i__ 335i__ is offline
Aussie member
Default 02-17-2014, 07:33 AM
so when my fuel gauge goes to 3/4 full under WOT, is that 15psi?
jb4 g5 on map 1, completely stock car including airbox etc - if its 15psi, isnt that a little high for map 1?
thanks
2008 BSM 335i JB4 G5
Byoung8's Avatar
Byoung8 Byoung8 is offline
Car: E90 335i 07
Default 02-17-2014, 07:47 PM
I haven't been on this site in a couple years. I am still on firmware version 6/4/2011! I want to update it so I can do the gauge sweep. I found the other post created for obsolete hex file and the date shows 082112 for G4, does that mean I don't have G5? When did G5 become available?
When I bought my JB4 I remember upgrading to a new board which was included in my purchase. Was that for the G5 board or G4?
Anyways, I have a SES light on and wanted to read the code. Here's what it read if anyone can help:
2A2D Fuel low pressure system, fuel pressure
2AAF Fuel pump, plausibility
2ACB DME digital motor electronics main relay, input signal
2EF4 Map thermostat, mechanics
Thanks guys,
Brandon
Default 02-17-2014, 08:18 PM
Thanks guys,
Brandon
8/21/12 was the last G4 firmware. For $150 you can upgrade to a G5 ISO board on our site. Well worth it IMHO.
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 02-18-2014, 09:03 AM
Agreed! Best upgrade I ever made.
Bimmer335 Bimmer335 is offline
Car: 2007 bmw 335i sedan
Default 02-18-2014, 01:50 PM
g5 is really good i also fixed my wastegate rattle and im very happy with it..but my inspection is coming up and i have dowpipes...but since g5 comes with ******** fix does anyone know how can i pass the inspection...what should i do...any help would be great thankss..
najin23's Avatar
Car: 335i CDV
Default 02-18-2014, 02:03 PM
get a dp fix from bms. Integrate it with jb4 harness, a bit of wiring required, but easy. Just before the emissions, change your map to "0", then turn your key in. It should pass ok. At least I passed mine ok here in Georgia.
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
brakthru brakthru is offline
Car: BMW 335i
Default 02-19-2014, 03:57 PM
Hey guys
Has anyone gone from the iso 27.3 hex file to 27.13 & noticed any improvements or loses in throttle response? Ive been debating on whether or not to update due to some reportings of earlier versions may have caused some members a lil loss in throttle response while trying to solve their wastegate issue. Im not having any problems that im aware of with iso 27.3 but wanted the latest update.
Also, my part throttle or mid throttle acceleration has diminished alot after BMW did oil change and breaks last year. I think they updated my dme. Since then i have installed the bb flash which helped but did not completely restore part throttle to its former glory. Lol. Any help is appreciated. Im also thinking about a wedge flash. Thanks guys.
MathR601's Avatar
MathR601 MathR601 is offline
Default 02-20-2014, 10:51 AM
Originally Posted by brakthru
Hey guys
Did you try to play with menu 10 and 12? The higher it's set, the more responsive it is. These menus can kind of revert back the update you might got from bmw.
JB4 G5 ISO, BMS DCI, 3" AR ***, E85, BMS OCC, BMS Spacers, ECS Blackout Kidney Grille.
Car: BMW 335i
Default 02-20-2014, 02:41 PM
I found the problem. I scanned the tcu and dynamic traction control module today with bavarian technic and found numerous dtc wheel speed sensor codes and other codes. The dealer did not cleared these after the brake sensor, pads and rotors were done. They attempted to update the tcu but didnt so i didnt lose the alpina coding. I cleared the codes and wow the car is back. Snappy throttle caught me off guard. Better shifting and acceleration with less throttle input. Mpg in dash went up some too. Btw i did play with menu 10 &12 in the past and like the default settings. Thx for your help.
najin23's Avatar
Car: 335i CDV
Default 02-20-2014, 08:00 PM
you get one more chance to pass free. try it first
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
jacobniell jacobniell is offline
Default 02-22-2014, 11:54 PM
Hi there
Can any of you tell me what the default settings are for menu 10 and 12?
I have just installed new turboes (RB) and would like to go back to the original default settings.
Stucks Stucks is offline
Default 02-23-2014, 11:05 AM
Originally Posted by jacobniell
Hi there
menu 10 = 80
menu 12 = 32
Current: 2008 e92 335i coupe.
Drik Drik is offline
Question Best tune - 02-23-2014, 12:44 PM
Hi Terry i have a 335i automatic with jb4 dual cone filters chargepipes ********* and oil thermostat recently in a dyno test the car throw 382whp in map 2 i have the intercooler right now to instal wish is better map to test with in a dyno.
Thank you:
Default 02-23-2014, 01:36 PM
Originally Posted by Stucks
menu 10 = 80
menu 12 = 32
Just what I was looking for
Dirty Dog's Avatar
Default 02-27-2014, 05:02 PM
Not sure if it's been requested before but given the popularity of the Walbro 255 inline, any chance we can get LPFP on the gauge hijack? Was thinking a scaling of min=40 middle=70 and Max=100??
Default 02-27-2014, 06:32 PM
Mo, moved your log, etc, to the support section. Hopefully some more eyes can help shed some light on there on your timing issues. I'm out of ideas for your car.
Default 02-27-2014, 06:33 PM
It's a good idea. But remember high pressure is more important. If high pressure crashes, then you'd want to look in to low pressure to determine if its up to spec. But high pressure can crash even with full low pressure.
Dirty Dog's Avatar
Default 02-27-2014, 07:04 PM
Makes good sense. I only replaced my HPFP recently and it's been holding well up top on E50. Will try E60 but I like how the car feels on E50 & meth.
Moral of the story is you need to log when running high ethanol content.
Default 02-28-2014, 01:00 PM
It's always good to keep an eye on it. But remember the JB4 also monitors it for you. And if high pressure drops below 7 for more than 2 seconds it will trigger a map 4 switch and flash the SES light 2 times.
Ramjet's Avatar
Ramjet Ramjet is offline
Car: Z4 s35i 7DCT
Default 03-01-2014, 05:38 AM
Hey Dog, what did you replace the HPFP with? OEM?
E89 N54 / Wedge / RB Turbos / AFE DCI / HPF FMIC / Stett CP / Forge DV's / AR Cattless DP's / BMS OCC / RB PCV2 / BMS Spacers
Dirty Dog's Avatar
Default 03-01-2014, 04:25 PM
Yeah just OEM. Added the in tank Walbro 255 inline last week. Still on stock turbo's. How's your car doing?
