(#8176)
scotte30m3 scotte30m3 is offline
Car: 07 335i sedan
Default 01-26-2014, 06:10 AM
Originally Posted by scottycs
when I try to download the newest attachment I get the file "attachment.php"
Its an Internet Explorer 10 and 11 Compatibility issue.
From your Internet Explorer browser window
Select Tools
Select Compatibility View Settings
Dialog box opens
In "add this web site" enter "www.n54tech.com"
Select add
Select Close
Restart the browser.
big_c big_c is offline
Car: NA
Default 01-27-2014, 07:35 PM
So I notice in some photos the G5 is the larger square box...and mine is the thinner one. Any difference between the two?
bigdaddycain's Avatar
bigdaddycain bigdaddycain is offline
I love me some used mods!
Car: nothing at the moment....
Default 01-28-2014, 06:34 AM
No, the new, bigger box is better for cooling the unit.
COBB AP|CP-e|ETS|ER|Forge DVs|KW V1|M3 Sways|BBS CH|BMS|
335i__'s Avatar
335i__ 335i__ is offline
Aussie member
Default 02-01-2014, 06:45 AM
ok, just installed my G5 tonight, idles great & no service lights.
just learning the steering wheel controls - is what I've underlined here a typo?
surely it should say channel switch, not volume?
thanks
2008 BSM 335i JB4 G5
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 02-01-2014, 07:37 AM
thanks
Volume moves the speedo to select the menus, and channel moves the tach to select the function. Once you have selected the function, moving the volume up/down saves that function.
335i__'s Avatar
Aussie member
Default 02-01-2014, 08:51 AM
yes you are right...
ive only had my car a few weeks & i had the buttons mixed up for what i thought they did.
just took it for my first drive on map1 (bone stock car with 33k miles).
holey f**ck, she moves out now - no error codes or lights - except for the dts.
thanks
aoschadlin's Avatar
Car: 535i
Default 02-01-2014, 09:10 AM
thanks
Now go here http://www.unitedpetroleum.com.au/ and see if theres an e85 station nearby.
335i__'s Avatar
Aussie member
Default 02-01-2014, 09:25 AM
allready on to it - a nice 10 mile drive up the freeway - might put new plugs in it first though - probably never been changed since new.
Default 02-04-2014, 10:38 AM
ISO 27.13 Notes
1) Disabled lean-run safety when DME is in lean spool mode below 3000rpm.
2) Slightly rescaled the open loop mapping from max effect at +7psi over DME BT to max effect at +5psi over DME BT. This should improve some of the fuel trim maxing out issue we're seeing with colder weather but may increase chances for 29F2 codes if open loop is left set too high.
Car: 09 E92 SG
Default 02-04-2014, 10:47 AM
ISO 27.13 Notes
Would his have any effect on those running a flash?
Shouldn't have much effect if using a back end flash.
m4xbmw7's Avatar
m4xbmw7 m4xbmw7 is offline
Car: F02/E82
Default 02-04-2014, 11:22 AM
ISO 27.13 Notes
This for custom settings only, when open loop is left high correct ?
Car: NA
Default 02-04-2014, 01:09 PM
When does open loop occur? Is it wise for everyone to update to this new file?
335's Avatar
335 335 is offline
Car: E92 335xi
Default 02-04-2014, 01:39 PM
ISO 27.13 Notes
where can i get a link for 27.13?????
Car: 09 E92 SG
Default 02-04-2014, 01:51 PM
First page
335's Avatar
335 335 is offline
Car: E92 335xi
Default 02-04-2014, 03:00 PM
updated to 27.13...running a lot better in cold, it just snowed about 1 ft in NY yesterday so i couldn't really open it up anywhere but i did a few quick pulls and it is running wayyy better in cold temps. once all the snow is cleared out i'll take logs and i'm ordering a new diverter valve friday when i get paid bc my stock one is a BOS and is leaking so i can't even hold boost if i want too
Default 02-04-2014, 03:26 PM
In cases where open loop has learned up to the max of say 95 when adding this firmware you may get a 29F2 code if open loop is too high for your DME version. If so just lower it by 5 or 10.
Jayman1869's Avatar
Jayman1869 Jayman1869 is offline
Car: 535i
Default 02-05-2014, 06:15 PM
Select Tools
Dialog box opens
Select add
Select Close
I was having this same issue, and I tried your advice. However, when I went to download, I hit "save as" and its either PHP or all files. No .hex appears?
FL335's Avatar
FL335 FL335 is offline
Sua Sponte
Car: 13 335is
Default 02-05-2014, 06:45 PM
Just save it as is to your desktop and just rename the extension to hex. I've done it. It works.
'13 LMB 335is DCT | MHD/BQ Tuning |
gunda gunda is offline
Car: BMW 335i E92
Default 02-06-2014, 06:43 PM
so I have not been able to test out 27.12 much, but I do live here in Toronto, Ontario and there been substantial snow fall recently and very cold temperatures. Would this justify updating to the new 27.13? how will this firmware react when the weather warms up here in the spring?
Default 02-06-2014, 07:41 PM
Nothing to do with external temps, though extreme cold means more power for our engine.
N54 TuNeR's Avatar
N54 TuNeR N54 TuNeR is offline
Cool ///Member
Car: E90 SEDAN
Default 02-07-2014, 08:05 AM
I have had readings on jb interface of sub 32 degrees while spraying 100% meth.would that be too dense for our cars or bad around or below 32 degrees?
SOLD
2004 E46 ///M3 MODDED
PRESENT RiDE
2008 E90 SEDAN G5 iSO-FBO FSB-100%METH-DUAL NOZZLES,Fuel iT!Stage 2
FL335's Avatar
Sua Sponte
Car: 13 335is
Default 02-10-2014, 08:39 PM
The first thing I'd check are all the hose connections on that FMIC to make sure there's no leaks. I put mine in a month ago and probably spent a hr making sure I had all the hoses and clamp seated properly behind the beads to avoid having to deal with crawling under there again.
MathR601's Avatar
MathR601 MathR601 is offline
Default 02-10-2014, 10:10 PM
Originally Posted by BeeMuh
Hello experts,
I have the following:
AR ***
ER CP with TIAL BOV
7" VRSF FMIC
Injen DCI
I have my log uploaded and if anyone can take a look and see what's going on with my car. Ever since I had my 7" VRSF FMIC installed, my car was pulling like a beast. Two weeks later, not so much. I hijacked my fuel guage and I'm only getting 5 lbs of boost. Is it possible that my new FMIC is broken internally?
Way under target. You certainly have a leak. Like the other guy said double check all the connections of the FMIC.
JB4 G5 ISO, BMS DCI, 3" AR ***, E85, BMS OCC, BMS Spacers, ECS Blackout Kidney Grille.
BeeMuh's Avatar
BeeMuh BeeMuh is offline
Car: '07 335i
Default 02-11-2014, 08:53 PM
Ty guys!
