(#8126)
E36graduate E36graduate is offline
Car: 335xi Sport
Default 01-07-2014, 04:01 PM
big_C ...the JB4 will blow your mind, just get it! Yes, it will make the software lag obsolete.
Mehank24....not sure, but why not update the firmware and inerface...seeing that you will be addicted to updating after you start.
SneakyDeeky's Avatar
SneakyDeeky SneakyDeeky is offline
Car: 335i E90 6MT
Question Cutting Diodes - 01-07-2014, 07:35 PM
I know that #2 on the first page states...
"2) G5 board must have diodes removed as shown in the photo below to run this firmware."
... however, is this still true for a recently purchased G5 ISO board (say November 2013)?
If yes, why wouldn't the diodes be cut prior to purchase?
6MT | JB4 G5 | E60 | Walbro 392 | NGK 5992 | Spec2+ | ER Dual Oil Coolers | ER CP | Synapse BOV | ETS FMIC | 3.46 Wavetrac LSD
BMS DCI | AR *** | Magnaflow | BSH OCC | KW V1 | M3 Bits | Advan RS | Michelin PSS | LS3 AEs | P3 Boost Gauge | Dyno Results | COTM Pics
scotte30m3 scotte30m3 is offline
Car: 07 335i sedan
Default 01-07-2014, 07:40 PM
Originally Posted by John
Rename the downloaded file and add a .hex extension and it should work
DO NOT do this, it is not the same file with a different extension...
FL335's Avatar
FL335 FL335 is offline
Sua Sponte
Car: 13 335is
Default 01-07-2014, 08:32 PM
I've changed the compatibility settings as well, but you can change the file extension for the same result. I've done it many times with different types of files including ones found on this site.
'13 LMB 335is DCT | MHD/BQ Tuning |
infinity's Avatar
infinity infinity is offline
metanol pawa!!
Default 01-08-2014, 08:49 AM
chrome is the law
Time is the best teacher
sirfredi's Avatar
sirfredi sirfredi is offline
Default 01-08-2014, 09:18 AM
I have the option 6.4, Automatically DTC disable at startup
What does this feature? FUD = 18
18 - Drop boost target more aggressively as a function of DTC intervention
What for it really that function?, act as if we had the DTC on?
Jelly335 Jelly335 is offline
Car: N54 335
Default 01-08-2014, 12:58 PM
I'm having a problem where I rip on it and it goes into map 4 no ses light and my auto clear is off. But I do get 2C3B Lambda probe in front of catalytic converter, not plugged. I recently installed my 2 step over the weekend.and fixed a wire and updated it to the latest. Any help would be great
Default 01-08-2014, 01:14 PM
Need to find/fix that lambda fault before the tuning will stay on.
Car: N54 335
Default 01-08-2014, 01:45 PM
I did a search it's bank 1 o2 sensor. I guess I fix that first and I'll be good.
Car: N54 335
Default 01-08-2014, 05:03 PM
Did another pull again and got these codes
2CAA Lambdaprobe before catalyst, temperature
2CAA Lambdaprobe before catalyst, temperature and ses flashed
Car: 335i E90 6MT
Default 01-11-2014, 10:03 AM
Bump
Default 01-11-2014, 10:09 AM
If the board was shipped as ISO it would already have the diodes removed. You'd only cut them if updating from firmware 10/1/2012 or older, which was integrated firmware. So if the car is running fine check the firmware date. Anything newer than that date above is ISO firmware and if the car is running OK already has the diodes cut.
beyondriddick beyondriddick is offline
Car: 09 135i
Default 01-11-2014, 01:46 PM
Originally Posted by infinity
me the same thing happens that to you. Any solution?
same in 27.12 hex
Same here. Any sol'n anybody?
PURE STAGE 2 TURBO'S * BMS PI * FUEL-IT STAGE 3 * PRECISION RACEWORKS INLETS * JB4 G5 ISO * MHD FLASH * HPF FMIC * ER CHARGE PIPE + TIAL * AR DP'S * HPF EXHAUST * MFACTORY DIFF * MOTIV TWIN DISC CLUTCH * M3 CONTROL/TRAIL ARMS * CROSS CF STRUT BAR * H&R FR/RR SWAY BARS * ST COILOVERS * MICHELLIN PSS 225/255 * iCARBON DIFFUSER *
**Stock Frame World Record 711WHP 652WTQ**
2016 BMW S1000RR
Default 01-11-2014, 02:04 PM
If you need support post a log of the issue and any codes in the support section.
Car: 09 135i
Default 01-11-2014, 02:15 PM
Will do Terry. Thanks.
2016 BMW S1000RR
Car: 335i E90 6MT
Thumbs up 01-11-2014, 06:54 PM
Perfect! Thanks for clarifying.
infinity's Avatar
metanol pawa!!
Default 01-12-2014, 03:36 AM
@Terry, if you put in the interface, in BFP 22 psi, is changed only to 21.9 psi
It's silly, but it should know
crazynuts16 crazynuts16 is offline
Car: E92 335i
Default 01-13-2014, 02:50 AM
is there a way to factory reset every option on the jb4? I just did the BT flash and I want to make sure there are no settings that shouldn't be there. I set all the AFR values to 0 manually, however I am not sure if the boost values were custom set or not etc.
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 01-13-2014, 11:24 AM
Yes, go under File and select "Restore Defaults".
Just remember to select the correct version from the pull down menu under the "Settings" tab first.
harry$ harry$ is offline
Default 01-13-2014, 12:43 PM
Would this also reset/return gauge hijacking options back to stock as well as anything else not set as a default value setting when this is done?
SoCalHarley SoCalHarley is offline
Car: 2007 335i e90
Default Map 5 better choice for 91 Octane? - 01-15-2014, 11:21 AM
I have been thinking that for the 91 octane we are forced to run here in CA that Map 5 would be a better choice than Map 1. If there is detonation at 13-13.5 lbs of boost which is Max boost on Map 1 due to the limitations of 91 octane fuel the JB4 will pull timing etc due to detonation but boost can still hit its maximum.
With Map 5 if 91 were to cause detonation the learning aspect of Map 5 would lower the boost targets to the 12 lb min of that map.
Would't that aspect of Map 5 make it a safer or more appropriate choice for lower octane fuel.
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 01-15-2014, 01:09 PM
In what troubleshooting situations would option 1/7 reset adaptations be used? What would the result be?
chrisinfla chrisinfla is offline
Default 01-15-2014, 04:10 PM
FUD 19 - Alternative partial throttle mapping algorithm
Terry can you give some more detail regarding this setting?
Default 01-15-2014, 05:11 PM
The 3.5 bar sensor causes values to round to the nearest plausible precision.
Default 01-15-2014, 05:12 PM
It's just an internal diagnostic command tech support may enable when troubleshooting partial throttle boost issues.
