(#7401)
Robert's Avatar
Robert Robert is offline
Car: bmw
Default 09-10-2013, 08:08 AM
Originally Posted by Grip&Go
Been on ISO26 for a week, when driving threw the neighborhood slowly in 1st and 2nd gear around 20to30mph the car surges back and forth. Any idea what settings I can change to cancel this out? Setting 10= 85 havn't changed 12 or anything else.
thxs
My car did not like the 26.2 either. Was laggy as hell at 80 and 28 settings which I tried to adjust but without much suscces.Flashed back to 25 and all problems solved as it also run great on it before.
Btw. I also run the old bms RACE AT flash with E40 mix and the car runs great.
Don't feel as reflashing would change much for me at this point.
Installing the 255 inline pump this weekend as I finally got all the right hardware for proper install.
2008 e92/MHD Wedge E85/Alpina TCU /RB Inlets/MMP Outlets/Vrsf DP/Helix FMIC/Forge DV/BMS CP/DCI/Fuel It st2/TBI/TC Kline/Swift SA coils/MF lsd/Hotchkis sway bars/M3 front and rear links/ Diff LDK/AKG Race subf/diff bushings/Megan toe links /TSW18 forged Nurburring/Mich PSS 245/265 /BMW(Brembo)M perf 370mm BBK
Grip&Go Grip&Go is offline
Car: 135
Default 09-10-2013, 09:12 AM
Surging can only be menu 10 set too high.
yea my car's never had wastegate rattle issues so I changed 10 to 90 and throttle response was really great.
I'll change 10 back to 80 that's what its always been.
thxs!
Stucks Stucks is offline
Default 09-10-2013, 09:18 AM
Originally Posted by muzzammil15
26.2 is real nice under boost I noticed with 26.2 my shifting is a bit harder in normal driving. I am AT
I noticed the hard/jerky transmission shifting too. Also noticed a teeny bit more rattle when letting off the throttle abruptly. guess this really does mean all cars/turbos/wastegates are different, since majority of people report deceleration rattle to be gone. 26.2 seemed better under wot, but I went back to 23g, which seems to be the best all around for my car so far. menu 10 is set to 65-70 and menu 12 is set to 34
Current: 2008 e92 335i coupe.
BimmerNFS's Avatar
BimmerNFS BimmerNFS is offline
Car: 2009 BMW 335i E90
Default 09-10-2013, 10:15 AM
For those of us who do not have any rattle, what settings do you guys think sounds the best?
2009 BMW e90 335i 6AT, Sport Package, Cold Weather Package, Premium Package, Logic 7, Space Gray Metallic, Dakota Gray Leather
BMS DCI, BMS JB4 G5 ISO, BMS OCC, BMS CP
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 09-10-2013, 10:40 AM
I just set 90/2.0 for the menus 10/12. Don't know what they exactly mean, but the setting seems to be working. It did once created a very distinct exhaust on WOT 2nd gear over 3000 rpm. I still get a slight rattle, but it quickly disappears.
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E45,
Fuel-it! Stage 2 standard,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.020")
robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default 09-10-2013, 03:43 PM
Settings of 33/88 are best for my RB'S so far.
NewHotness NewHotness is offline
Default 09-10-2013, 04:14 PM
Thanks Rob, will try this out on mine too
robc1976's Avatar
Car: 2007 335i
Default 09-10-2013, 06:59 PM
feels pretty good so far
gunda gunda is offline
Car: BMW 335i E92
Default 09-10-2013, 09:10 PM
So for the problem with rattling occurring when letting off the throttle abruptly in 1st, 2nd, and sometimes 3rd gear, do you suggest setting menu 12 lower or higher? I believe that menu 12 controls this portion of the waste gate positioning, correct me if I'm wrong please.
Default 09-10-2013, 09:15 PM
Send a log over of it. ISO25 holds the wastegates shut when letting off the gas, while ISO26 lets them swing open to relieve pressure. I believe the ISO26 approach is safer for the engine. But, may make it more prone to rattle for an instant when letting off the gas. If it happens in ISO25 also though then you simply have menu 10 set wrong.
Car: BMW 335i E92
Default 09-10-2013, 09:44 PM
So do you want me to flash back over to iso 25 and record a log of me letting off the throttle abruptly in 1-3 gear? I am also going to test out setting menu 10=80 and 12=20 tomorrow, going to see how that works...
bmsportzn135i's Avatar
Default 09-10-2013, 10:10 PM
So a setting of say 80 in menu 10 would be 4 on the rev counter right? And 12/20 would be 1?
537.75HP 540.63TQ
NacRacing335 NacRacing335 is offline
Car: 335
Default 09-11-2013, 06:42 AM
So I have noticed that my car keeps switching back to map 0 randomly. This has been since I updated to ISO 25 . Would the ISO_26.2 fix this problem and is it related to the obd2 port switching me back to map 0. I assume the fix in ISO_26.2 is to fix that. I thought I was loosing my mind....
2008 E92 - JB4 G5 ISO , E85 Flash ,FBO , Stg 2 LPFP KW v2 Coilovers, M3 Suspension Arms And Bushings , Hotchkis Sway Bars, 19" CSL wheels 255/275
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 09-11-2013, 06:58 AM
This problem was specifically fixed in 26.2, see the release notes on page 1.
Default 09-11-2013, 08:31 AM
If you want to send a log of the "issue" on ISO26 I'll check it out.
UnderPressure's Avatar
UnderPressure UnderPressure is offline
Car: BMW 535i
Default 09-11-2013, 10:33 AM
I also noticed that the JB4 was switching back to map 0 on ISO 25. I updated to ISO 26.2 and that corrected that problem, but now the CANflap will not stay open. It keeps closing after a few seconds. I wonder if there is some kind of conflict after my recent BMS pump gas flash.
2010 535i xdrive M Sport , JB4 G5 ISO / BMS pump Flash / xHP stg. 3 TCU flash / BMS DCI /ER charge pipe ,ER FMIC / RB PCV valve/, 30% E85
najin23's Avatar
Car: 335i CDV
Default 09-11-2013, 11:36 AM
You may be right. I think I have noticed the similar thing yesterday. I haven't flashed yet though.
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
Evochuck Evochuck is offline
Car: 335xi
Default 09-12-2013, 10:51 AM
After flashing to 26.2, rattle is back with a vengeance, even with menu 10 at 80.
Default 09-12-2013, 11:27 AM
Email a CSV log of it rattling. Have some changes in 26.3 that should resolve it assuming 25 was working.
robc1976's Avatar
Car: 2007 335i
Default 09-12-2013, 11:58 AM
Terry,
I don't have rattle...well the Lagfix algorithm stay the same as 26.2...I love the way it operates.
HeavyMetalRocker's Avatar
HeavyMetalRocker HeavyMetalRocker is offline
Car: BMW 335i e90
Default 09-12-2013, 02:01 PM
Hey Terry, I just received my G5 upgrade in the mail! Just wanted to say thanks for the high temp enclosure and this thing got here FASSSST!!! Awesome service, Awesome products!
Thanks man, Mike!
DanL DanL is offline
Car: 2010 535i M Sport
Default 09-12-2013, 02:07 PM
26.2 worked fine with my car until I flashed the DME with the latest BMS pump gas flash. Low RPM driveability sucks and after three days of trying, I can't find any combination of menu 10 and 12 settings that resolves it. I'm just about ready to flash my DME back to stock.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
Premium, Value, Cold Weather, Sport Auto, Navigation, Satellite, Logic 7, Comfort Access, Park Distance, Fold Down Rear Seats, Heated Rear Seats, Rear Side Airbags, JB4 G5 ISO, BMS DCIs, ER Charge Pipe, Proform Clear Bra, LUX H8 160 LED angel eyes
Default 09-12-2013, 02:13 PM
If you want the JB4 to ignore the flash map throttle mapping then set fud to 96.
Default 09-12-2013, 02:38 PM
Thanks, Terry, I'll give that a shot. The car accelerates smoothly above 3K RPMs but is anything but smooth below that. What's the best starting point for menus 10 and 12? I think I've dropped 10 down to 50 and have 12 around 35 right now.
Robert's Avatar
Car: bmw
Default 09-12-2013, 02:49 PM
I would try flashing the jb4 back to 25 firmware. That's what I did when 26.2 sucked on my car .25 works great with backend flash.
Btw. I am 2008 AT fbo E40 with bms meth.
