(#3101)
saxplayr's Avatar
saxplayr saxplayr is offline
Car: 2007 335i e90, 6MT, Milltek exhaust, DCI
Default 08-27-2011, 09:32 AM
Just installed the JB4. Took about 90 minutes to complete the basic install. Had to add another 30 minutes to run the USB to the glovebox (a physical labor) and another 30 for diagnostics to figure out that the power lead was not secured well (engine cranked, but did not turn over). So all tolled, 2.5 hours. Dashboard is working well... so cool!!
Now waiting for Hurricane Irene to settle down outside. It isn't too bad here around Raleigh, just some rain and gusty wind, thank God. Pray for the coast!
NOW I'VE GOT A TICKET TO RIDE!!!
Jim
saxplayr's Avatar
Default 08-28-2011, 05:01 AM
Lovin' my JB4!! Already got yelled at for driving too fast!!
Two questions:
Does Map 5 remember after you go to another Map and then return, or does it have to relearn?
Is it possible that the JB4 introduces some turbo lag? Or does it just feel that way because the boost is so much more noticable when it kicks in?
dfjaws's Avatar
dfjaws dfjaws is offline
Car: 2007 335i 6MT
Default 08-28-2011, 01:03 PM
Map 5 relearns if you use another map. Just turing off the car will not cause Map 5 to re-learn.
I just keep mine on map 5. Autotuning FTW.
saxplayr's Avatar
Default 08-28-2011, 01:54 PM
Thanks Jaws!
dfjaws's Avatar
Car: 2007 335i 6MT
Default 08-28-2011, 02:09 PM
No problem. For me, about half the time, map 5 makes a little more boost than map 1. I always run 93 octane though. Your mileage may vary.
shaank shaank is offline
Car: E92 335i Msport 6MT
Default 08-29-2011, 09:28 AM
newest firmware installed - gauge sweep is cooler than I thought it would be :D
saxplayr's Avatar
Default 08-29-2011, 05:45 PM
Just seems to be getting stronger and stronger every time I drive it!!
BTW, the video was a lifesaver for doing the install. Excellent! I just walked through it step by step. The visuals were great.
Yeah, the gauge sweep is very cool!!
SlicktopTTZ's Avatar
Turbo Lover
Car: 300zx TT, 1M
Default 08-29-2011, 06:07 PM
Two questions:
A higher boost level will take more time to achieve. Remember you have to accelerate the turbine and compressor wheels with exhaust gas, and obviously the higher the target turbo RPM is, the longer it will take to get there.
Also the extra torque does make the off-on boost transition more noticable, to me in an enjoyable way.
saxplayr's Avatar
Default 08-29-2011, 08:16 PM
Thanks Slick. Makes sense!
saxplayr's Avatar
Default 08-29-2011, 08:19 PM
Terry, What are the next firmware features on the horizon? Is there a place to find out what is coming next?
I read something about impacting traction control on the thread, but don't see any features in the list in the first post.
romak47's Avatar
romak47 romak47 is offline
luvsmyride
Car: 135ci
Default 08-29-2011, 08:24 PM
HAHHA. TERRY,
it sounds like you are a drug dealer!.. a dealer for speed!
shhhhh i wont tell anyone!
JB4, DCI, Digi boost, CSL eyelids, 5% tint, KW v2's. Bastuck 85mm quad w/ ***+resonator delete mids, LED int ltg, Perf SSK, CF int trim, 19" SF-71 rims, CDV mod, BSH OCC, ER+tial charge pipe. AR DP's, Helix IC, meth
saxplayr's Avatar
Default 08-30-2011, 10:00 AM
At some point we'll do a writeup on what everything stands for. It's on the to-do list but hasn't made it to the short list quite yet.
+1
saxplayr's Avatar
Default 08-30-2011, 03:27 PM
Just read through all 3142 posts on this thread. WHEW!!! Lots of good stuff. Just uploaded the latest firmware... piece of cake. I also now understand that Map 5 needs 4600rpms in 3rd and 4th gear to tune. (Might be a good update for page 1 of the thread).
Running Map 5. Was traveling home at about 50 mph in 3rd gear and punched it (to get up to 4600rpms). The tires chirped!!
Also just changed the global boost for 1st and 2nd. Also just learned that holding the DTC button down will turn off the traction control.
Just keeps getting better... yeah, like a drug. Thinking about the DCI now after my wife recovers from the JB4.
dfjaws's Avatar
Car: 2007 335i 6MT
Default 08-30-2011, 07:16 PM
Get the DCI. I LOVE it. Turbo spool noise and you can hear the diverter valves more.
Turbo Lover
Car: 300zx TT, 1M
Default 08-30-2011, 08:05 PM
Yep, it makes it addicting to load the motor up!
EnjoixE92 EnjoixE92 is offline
Car: 2011 335is DCT
Default 08-30-2011, 11:13 PM
http://tinypic.com/player.php?v=2po1jqq&s=7
What cha think Terry? JB4 MAP5,Vanguard Performance Exhaust, A&R Designs ******* dp,AFE Filter, Silver Bullet Thottle Body, 93 Octane. and 71 Degrees outside :D
Steveo's Avatar
Steveo Steveo is offline
Humid 535i
Car: 535i
Default 08-31-2011, 01:23 PM
Where the hell was it 71 degrees in La today????
Default 08-31-2011, 01:27 PM
You can send a log in if you want me to look over it. But video looks cool!
Car: 2011 335is DCT
Default 08-31-2011, 01:51 PM
The thing is that. you can only catch that type of weather around 6-7am lmao.
pinoy pinoy is offline
Default 08-31-2011, 03:53 PM
yea, putting the Auto Tuning instructions on first post would be very helpful. What page are the instructions on?
davidrbixby's Avatar
davidrbixby davidrbixby is offline
Car: 2008 335i Sedan
Default 09-05-2011, 09:09 PM
Hey Terry,
When I am in M2, I have a problem with auto downshift to M1 when I punch the throttle. Any way to overcome or manage this? I'd like to accel out of sharp turns in 2nd when I race, but don't want a downshift to spin me out.
Thanks again, Dave.
2008 E90 Sedan 335i, BMS G5, Quaife LSD, BMS Intake, Forge Diverter Valves, ER Charge Pipe, Forge Intercooler, Macht Schnell down *****, Bilstein Suspension, M3 Hood, Bumper, Sideskirts, Custom 700hp Oil Cooler, Square 18x9.5 wheels with 275/35R18 Continental Cup Tires.
OldBooster's Avatar
OldBooster OldBooster is offline
Car: 2008 135i AT
Send a message via Skype™ to OldBooster
Default 09-05-2011, 09:15 PM
Originally Posted by davidrbixby
Hey Terry,
Thanks again, Dave.
Teach your foot to avoid pressing past the pedal 'kick down' point. You'll become a better driver as you smoothly press the pedal down. You're still getting full throttle at the kick down point.
Cheers!
Terry's unmatched dedication to the N54
Held #1 on www.DragTimes.com:
First to run 11.012 @129.30
Default 09-05-2011, 09:16 PM
Scoops installed. Quaife LSD going in tomorrow. Meth install next week. Setrab Oil cooler behind kidneys in 2 weeks. Exhaust Y with electronic cutover to race ***** from ******* DP in 3 weeks. RB Turbos ordered, install end of Oct. Addicted to JB4 and speed
Default 09-05-2011, 09:18 PM
Thanks. I'll start practicing. 2hrs track time at Sebring this weekend.
shuteng486 shuteng486 is offline
Car: 2010 E60 535I
Default 09-06-2011, 08:05 PM
that sounds so fun david!!!
i wish i was there too
i am stuck here at LA CA woo man it was really hot today my 535
with max cool works great thanks to Terry.
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
