(#226)
Default 09-19-2015, 08:55 AM
Originally Posted by TheYuriPandaa
Whattt if i where to, at WOT, during shift keep my foot planted but press the anti-lag button between the shift and let go when the gear catches
I don't think it will work. But, we will be attempting to integrate anti-lag with our NLS system in a few weeks.
Default 09-19-2015, 09:05 AM
We've added the kit to our site on the n54 upgrades page. Note we don't have any inventory and we make them to order. So expect a day or two delay before shipment: http://www.burgertuning.com/N54_JB4_upgrades.html
Zombie1 Zombie1 is offline
Car: 2010 135i
Default 09-19-2015, 09:40 AM
Hey Mr.burger I'm Ready to make the jump to the jb4! This anti lag feature has pulled me over to the dark side . If I order them both at the same time can they come pre assembled?
Default 09-19-2015, 09:43 AM
Sure just make a note in the order, hopefully Eric or Edwin at the waehouse will see it and put it aside for me to assemble it for you.
Car: 2010 135i
Default Awesome - 09-19-2015, 10:08 AM
Thanks for the quick response placing Oder now.
obriennathaniel's Avatar
obriennathaniel obriennathaniel is offline
Car: F30 335i
Default 09-19-2015, 01:17 PM
ohhhh how I would love to have this on my F30 lol
CG Precision VS-1 Exhaust\DR-1 | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | JB4/ACF Performance w/BM3 | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge|
Default 09-19-2015, 02:30 PM
Yes I know.. Unfortunately it can only work for the N54 right now. Our N55 and S55 JB4 systems can run that end of it easily but its the free at home flash tuning that is the missing equation.
Blaster400's Avatar
Blaster400 Blaster400 is offline
Car: 2007 BMW 335 E92
Default 09-19-2015, 05:46 PM
JB4 G5 w/BMS MHD backend flash | MOTIV 750 | 100% E85 | MOTIV port injection | Fuel-It Stage 3+ LPFP | Akrapovic Exhaust | DSS Axles | DEFIV lockdown kit | Quaife LSD
HouseN54's Avatar
HouseN54 HouseN54 is offline
Default 09-20-2015, 11:35 AM
Terry are you updating the single turbo flash files also?
| ProCharged C6 Z06 | Civic-X Si | F30 330i |
Default 09-20-2015, 02:30 PM
MHD files are updated.
HouseN54's Avatar
Default 09-20-2015, 06:43 PM
I meant BB files.
Default 09-20-2015, 08:46 PM
In the next BB file release the ST and E85 maps will have the tables changed.
jamhot's Avatar
jamhot jamhot is offline
Default 09-21-2015, 10:46 PM
Could do with some more video contribution of this feature. It's difficult to see/hear
Forge fmic,VRSF DP, Charge pipe with HKS BOV, BMS intakes, BMS jb4 G5, backend pump flash, 19" MV4s, Golf T mod
jamhot's Avatar
Default 09-22-2015, 07:49 AM
Guys, Just doing a compare on the new and old E85 maps to see the antilag changes in the new backend flashes. I am confused because I don't see how temperature correlates with the 38f timing pull stated at the start of the thread. Looking at it, it seems that the timing pull comes in at 80f??? I have just started using tuner pro after doing the EU changes to a map so excuse the noob question if I am being dumb. Just trying to get my head around this because I would like to implement for Pump flash
Default 09-22-2015, 09:00 AM
Make sure the XDF you are using is in SAE standards (not metric) if doing a comparison. The XDFs we used are in the first post.
jamhot's Avatar
Default 09-22-2015, 10:20 AM
is this an interpretation option in tunerpro or are you referring to the XDF file standard? I have loaded the XDF on the first post but I see no difference???
sch4400 sch4400 is offline
Car: 08 535i
Default 09-22-2015, 10:22 AM
payment send....cant wait ~~
Default 09-22-2015, 10:28 AM
If you need assistance using tuner pro you may be able to find some other threads that discuss the details of it.
bmsportzn135i's Avatar
bmsportzn135i bmsportzn135i is offline
Default 09-22-2015, 12:10 PM
Terry, will you be updating the race and pump flash for the antilag or is this only for the E85 flash?
Also,im waiting to pull the trigger on this with a 2step from you guys, just waiting for you to integrate the two.
537.75HP 540.63TQ
Chadd! Chadd! is offline
Car: 09 335i
Default 09-22-2015, 02:58 PM
Ordered! For launches, you just hold the button, brake and mash the gas pedal and hold on? Will the rpms build up while I do this?
Default 09-22-2015, 03:12 PM
E85 only for the time being. You can modify the flash files yourself but not sure I'd suggest this without E85.
blisstik's Avatar
blisstik blisstik is offline
Car: 2007 E92 MOTIV 750
Default 09-22-2015, 04:22 PM
Does anyone with IJEOS have it working?
I can't get mine to work! I have the wire in #17 on large black subconnector, #4 pin on data cable, 9/13 E85 PI MHD backend and MAC 12.2 firmware on the JB4.
MOTIV750 / MHD+JB4 / ADV / SB REAR O2
just_dirty just_dirty is offline
Car: E92 Gulf Livery 335
Default 09-24-2015, 08:16 AM
How about Anti lag and Meth?
Frozen Black Widebody E92 : VRSF CP, N54Tuning DP, Tial BOV, DCI, MHD Flash, Aquamist HSF-3 Meth kit Dual Nozzle, Megan Racing Toe Arms,Megan Racing Camber Arm, Megan Racing Trailing Arm, IND Delrin Subframe Bushings, M3 Control Arms,Fortune 500 Series Coilovers, Square 18x11 Apex Ec7 w/ 315/30/18 Hoosier R7's
Default 09-24-2015, 08:23 AM
It enables for now. Will need to be further evaluated.
BostonBeemah's Avatar
Car: AW 135i
Default 09-24-2015, 08:28 AM
Does the temperature drop when you go full throttle with the car off just ignition? If it does, then the appropriate table changes might not have been made in the flash.
RIP 2008 AW/BL 135i
