(#9801)
PLF's Avatar
PLF PLF is offline
Default 09-15-2015, 01:29 PM
I think the best option for gauges is the wot-view only. The oil gauge will show oil any time you're not racing around.
I have been searching for a while on how to change the highjack to wot only but can't find info only option I find is 50% throttle or more... ??
Default 09-15-2015, 01:41 PM
By WOT I mean 60% pedal input or more.
Default 09-15-2015, 01:42 PM
Logs and support request go to the support forum.
blown07's Avatar
blown07 blown07 is offline
Car: 335xi, 335i
Default 09-16-2015, 09:40 AM
Safety mode 4 is to all maps the same as safety mode 1. Meth adder is only ever used on map 3.
Perhaps I'm misunderstanding but I think they are asking is why is a safety mode required if no additional boost is being added to the other maps anyway? Mode 1 is raise boost as a function of meth flow but you will run the same boost on a given map with or without meth flow as there is no "meth adder" to remove with the safety.
335i FBO,Meth,MHD,XHP3,LSD,GCLites 11.83@124.88
335xi FBO,Meth,MHD,XHP3,VTT stage1 11.38 1/4 - 7.30 1/8th - 3.35 0 to 60 @ 0C
Default 09-16-2015, 09:43 AM
When safety mode = 4 is enabled all maps have a base boost of around 15psi and then target is raised to their true target as a function of meth flow.
Spacegrau's Avatar
Spacegrau Spacegrau is offline
Car: 09 335i
Default 09-16-2015, 02:46 PM
Nice work, I'm really enjoying menu 11 @ 3000k. Almost feel like I don't need a backend flash the acceleration is so smooth!
GermanBoy's Avatar
GermanBoy GermanBoy is offline
Car: BMW 335i e92
Default 09-17-2015, 06:38 AM
are there any updates for map 3 targets with n20 tmap+ inlets?
Eristoff's Avatar
Eristoff Eristoff is offline
Car: BMW e92 335i n54 coupe (2006)
Default 09-17-2015, 09:43 AM
Terry can you explain what exactly do the changes in 31.5?
E92 335i coupe 10/2006 @ BMS DCI ; JB4 G5 ISO ; AR Design 3" DPs ; APEX EC7 18" wheels ; BMS OCC ; BEF ; MMP inlets & outlets ; RB PCV valve ; Vibrant ressonators
Default 09-17-2015, 10:03 AM
The firmware notes document in what version various changes were made.
tim_gtir tim_gtir is offline
Car: 2009 335i
Default 09-17-2015, 10:14 AM
None of those settings have any effect on full throttle except menu 12 and only if its set too high.
Terry, how do I get or purchase a custom map/flash on map6 on the JB4 stage 3 for the n54? I want to boost up more by rpms setting. I want more than map 7 18.5 psi.
I'm have FBO and will only run on racing fuel 100+ octane.
I'm not sure if I have the latest firmware but I bought my JB4 around May 2015 so I'm assumed it came with latest firmware.
I'm willing to pay for a safe custom setup on map 6 where I want to push 20-22 psi. I know that's close to maxing out the turbos and potential risk for the motor but I'm not worry it's only 3k-4k for a new motor. If it blows up it'd just be a good reason to get it fully built.
What's recommended as far as fuel upgrade or meth if necessary to run that much of boost.
Again this setup will only be running on 100+ racing fuel.
Thanks,
Default 09-17-2015, 10:20 AM
The latest JB4 firmware, settings, and back end flash maps are posted to the forum. To run more than 20psi requires an N20 3.5bar TMAP adapter.
Map 7 runs around 20psi so I'd start there. If you need help or tuning advice post a log in the support area.
If you require special tuning attention beyond what we can help with via the forum you will have to hire a personal tuner. We don't endorse any but they are around.
v1nc86 v1nc86 is offline
Car: E90 335xi
Default 09-17-2015, 10:55 AM
Thanks,
You should start with map 7 and backend flash (race) maps... it will be a good start !
2008 Jet Black 335xi E90 6AT | Alpina B3 TCU Flash | BMS Backend 7/1 Pump Flash | JB4 G5 ISO 31.5 | BMS DCI | BMS CP | VRSF 5" FMIC | BMW Performance Exhaust | VMR V718 / Kumho | Best 1/4 mile: 12.37@110.4 MPH | Top speed: 0-270 km/h | YouTube
themyst themyst is offline
Super Demigod
Send a message via AIM to themyst
Default 09-18-2015, 09:13 AM
terry I noticed you said the later firmwares may overboost. if they do, what should be adjusted to resolve the issue?
E90 LCI N54 6AT
Default 09-18-2015, 09:48 AM
Haven't had any issues with it.
Default 09-18-2015, 02:41 PM
BTW, haven't had any issues with overboosting or boost oscillation since I switched to 31.5
Thanks Terry!
N54 | Build Thread
climax_E92 climax_E92 is offline
Car: E92 335i
Default 09-18-2015, 04:35 PM
Which would be a stronger flash? Race or e85? It says map up to e30, race for higher, but e40 at least for e85 flash so a little confused. Likeif I run e55, should I use race or e85 flash? Thank you
Default 09-18-2015, 04:45 PM
Anything E40 or higher is better off using the E85 flash UNLESS you often run straight pump. In which case the RACE is a better dual purpose flash map.
mike_nazz mike_nazz is offline
Default 09-18-2015, 07:14 PM
Terry, is it a good idea to use b3 alpina flash with mhd/jb4 e85 map 7. I noticed map 7 sometimes causes tranny slip on high rev low gear on my transmission.
nyt nyt is offline
Car: 335ix
Default 09-18-2015, 07:47 PM
yes, alpina flash is needed on higher horsepower at cars.
Default 09-18-2015, 09:35 PM
Trans flash? Definitely!
blown07's Avatar
Car: 335xi, 335i
Default 09-19-2015, 05:09 AM
Okay thanks.
So historic timing is ignored on all maps when safety mode = 4 including map 3??
10) v31.5: Adjusted meth_safety mode = 2 to apply to all maps when selected.
Sorry but I don't understand which safety mode is applied to all maps if safety mode = 2
Cheers,
Default 09-19-2015, 09:22 AM
Right. Historic timing is meant to protect you against insufficient meth volume or quality to cover the requested boost gauge, and to protect against the rare solenoid failure. But with E85 in the tank these two aspects of the safety system become less critical.
Jcoccy335 Jcoccy335 is offline
Car: 2006 335i
Default 09-19-2015, 09:47 AM
Finally got home and updated to 31.5. Acceleration rattle is gone and car now feels like an e46 m3 . Got menu 11 set to 3000 rpm. Love it nice job.
2006 e92 monaco blue
Jb4 G5 ISO
Bms dci
Bms 3" *********
Forge cp and twin BOV
Bilstein b12 kit
If it ain't broke, break it.
Car: E92 335i
Default 09-19-2015, 12:22 PM
How does 3k feel compared to like 2k? I haven't gone over 2k cause I'm trying to figure out what settings to change to stop the jerky feeling when rolling from a stop ... :/
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 09-19-2015, 01:44 PM
I guess you need to test by lowering your menu 12 , default 2800 but many reported lowering it to 2600 and 2500 smoothed the issue
