Bostons335i Bostons335i is offline
Car: 08 335i
Default Single turbo log review / timing pull - 01-17-2022, 01:53 PM
Hi all ,
Did a log on my single turbo n54. Was sitting for a couple weeks so I thought I’d go ahead make sure everything was good . Felt pretty sluggish too me , and I saw the timing was being pulled a bit . Lmk if you guys see the same .
It’s on pump flash with 93 from shell with map3 20psi . It also has the fuel it CPI kit with 950cc injector stage 2 lpfp
Thank you in advanced !
P30_M3_R1_220117_1509.csv
Default 01-18-2022, 11:45 AM
Agreed...some timing getting pulled but otherwise looks pretty normal.
Car: 08 335i
Default 01-18-2022, 03:39 PM
Hey Steve ,
Thanks for the reply ,
I’m really stumped on what could be causing this ? The sparks / coils are new , I’m using shell 93 gas , and intake temps are good too . I was reading up on that high rpm misfire from the dual mass flywheel and it got me thinking , I still have the dual mass on this set up could the dual mass be causing the timing being pulled ? I do occasionally get the normal high rpm misfire as well. I don’t think the boost or the tune are too aggressive either , let me know what you think. Thank you
Car: Evo VIII
Default 01-19-2022, 11:35 AM
What spark plugs are you currently using?
Default 01-19-2022, 12:15 PM
Not all fuel is created equal...before going to a lot of trouble, I'd change sources, try some octane booster/ethanol, or some race gas to see if that cleans up the timing.
Car: 08 335i
Default 01-19-2022, 03:05 PM
Hey Steve thank you for the reply , I was just about to do that I’m ganna see if a couple gallons of e85 will help out next fill up I’ll report back once I get that in there . Thanks so much!
Car: 08 335i
Hey cannon ,
Using ngk 2 step colder gapped to .02
Car: Evo VIII
Default 01-19-2022, 05:46 PM
Originally Posted by Bostons335i
Hey cannon ,
perfect
Car: 08 335i
Default 01-28-2022, 02:23 PM
Hey Steve ! Got a couple gallons of e85 in the tank, man does the car feel so much better , can see the timing actually go up now felt really good. I seem to have another issue now though with fuel trim variance with the CPI kit. The higher I go up in dual basis the bigger the variance . I had to increase the bias because with the e85 the fuel trims were maxing out did some testing seems that bias on 70 is a decent fit but I still got the fuel trim variance code and brought to safety map. So I went ahead and turned fuel trim variance off (unsure how bad this is for the car) (FUA 65) . Here is a log of the differnt settings of duty bias at 100,80,70. Please take a look and let me know if you think I can do anything to get these trims better , just odd they seem to be bad with more CPI input . Thank you
P30_M3_R3_220128_1359.csv
Default 01-31-2022, 02:47 PM
Where do you have your injector installed? The further away from the throttle body, the better.
Car: 08 335i
Default 01-31-2022, 04:34 PM
Hey Steve !
I’ve had the CPI on since before the single kit and never had an issue . But I have attached some pictures on here for you to take a peek at and Lmk what you think. I read up a little and someone mentioned a boost leak can also cause this? Lmk what you think on both thank you !
Please let me know if the photos come out okay first time attaching them to a post here lol!
Car: 08 335i
Default 02-09-2022, 03:09 PM
Got around to do another couple logs, had to increase CPI to 80 because trims were still high . First pull timing was all over the place , second pull seemed great timing came together but into the shift to 4th pulled on cyl 1 and 4 .
Steve do you have any ideas on the fuel variance with CPI kit?
Thinking about getting boost leak test as well
P30_M3_R2_220209_1332.csv
Default 02-10-2022, 11:23 AM
I agree, it could be due to a boost leak in the manifold (bad/missing gasket etc.) or if there is a build up or something causing the fuel to form large droplets, that could do it as well.
Thatslow135 Thatslow135 is offline
Car: BMW 135i
Default 03-05-2022, 09:17 AM
Following!
