hydra hydra is offline
Car: 2010 135i
Default New N54 stock turbo world record @ 523whp - 09-01-2016, 10:53 AM
Hey all,
Got my car dyno'd this morning and came up with this:
Car: 2010 135i
Default 09-01-2016, 10:54 AM
Dyno model is a Dynocom 5000X (we don't have any Dynojets locally), and the temp was 81F with a 1400ft DA. Car is running 21.x psi peak tapering down to 17psi on redline with FBO except outlets and running C16 race gas. Smoothing Factor on the dyno is 1, my dyno sheet printout says 523whp, I don't know why the pic above says 518whp but it is what it is... Run was done in 4th gear btw on a 6MT car with a 3.46 rear end. I can post logs if need be...
Spxxx's Avatar
Spxxx Spxxx is offline
Default 09-01-2016, 11:02 AM
shouldn't it be an average of 4th/5th gear? does the final drive effect things?
You're gonna get a lot of **** for this not being on a DJ
Car: 2010 135i
Default 09-01-2016, 11:05 AM
Doesn't really matter to be honest. FWIW the dyno in question has proven to put out reasonable whp numbers in the past so I have no reason to believe that my numbers are very far off the mark...
Jt0407 Jt0407 is offline
Car: Bmw
Default 09-01-2016, 11:09 AM
What does it make with smoothing factor, 5? Normally, what everyone uses.
Sabre Sabre is offline
Default 09-01-2016, 11:10 AM
definitely be prepared for bs. For what it's worth at least you dynode in 4th, vs everyone else has done so in 5th, if I recall correctly. Great pull regardless.
BTW, what wheel n tire set up are you running?
suspenceful's Avatar
Car: 2008 BSM 135i
Default 09-01-2016, 11:11 AM
If it's not on a DynoJet, it'll be taken with a grain of salt.
Great numbers none-the-less.
BMW135xi's Avatar
BMW135xi BMW135xi is offline
Car: BMW 135I
Default 09-01-2016, 11:19 AM
No meth, no inlets ,and hitting only 21PSI and making 523HP. ??????????????????
Car: 2010 135i
Default 09-01-2016, 11:30 AM
I'm running Volk TE37SLs in 17x8.5 +40... <15lbs each with (lightweight) 245/40/17 Bridgestone RE71Rs with ~40% tread life remaining... Also have a Spec LWFW for what its worth...
Car: 2007 BMW E90 335i
Default 09-01-2016, 11:45 AM
Great numbers, but it's hard to believe you're getting 50-100hp more than others with roughly the same boost and setup.
2013 135is DCT Carbon Black
phil1320 phil1320 is offline
Car: 2011 335is
Default 09-01-2016, 11:48 AM
I think he has inlets just no outlets. But he did say he is running on C16 which is a pretty superior race gas to use in these cars
PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 09-01-2016, 12:14 PM
No dynojet, no record. Good #'s tho.
SOLD - FBO N54, Pure Turbos stage 2, TFT inlets, JB4/MHD, EOS intake manifold w/PI, Fuel-it stage 3
Default 09-01-2016, 12:16 PM
Power is probably around 450whp on a dynojet but sounds like its running well. Get it to the track and enjoy it!
BuraQ's Avatar
BuraQ BuraQ is offline
Car: 335is DCT
Default 09-01-2016, 01:14 PM
No logs is a sin
WR is held on a dynojet
If you don't have access to a DJ then get vBox numbers to at least compare with the WR holder
Power curve looks good
2011 E92 335is w/DCT
2007 E92 335i 6AT
BMW135xi's Avatar
Car: BMW 135I
Default 09-01-2016, 01:36 PM
I think the record stand at 500HP or 503HP and that is with meth, costume flash, inlets,
3.5 bar, stage#2 pump , e-85 , and boosting 24PSi -25psi.
BuraQ's Avatar
Car: 335is DCT
Default 09-02-2016, 12:47 PM
No, the record stands at 507 whp on a dynojet with 24 psi, no meth, E60, FBO and inlets, trapping 123-124 full weight @ 11.5, and is DD car.
http://www.n54tech.com/forums/showth...ighlight=BuraQ
Some other guy claimed 518 or something like that but I couldn't find where this was posted. I heard from others the claims had issues passing legitimacy (edit: found out this was the guy lol )
Another car did 503 with 22 PSI, FBO, no meth, only E60, logs and vbox numbers to back it up which is also a DD car.
There are a lot more coming
2007 E92 335i 6AT
Oryx's Avatar
Oryx Oryx is offline
Car: 2010 535xi
Default 09-02-2016, 01:35 PM
That doesn't much sound like a strong argument for a world record. I'm sure it's a beast and runs well.
boost junkie boost junkie is offline
Car: bmw
Default 09-03-2016, 04:34 AM
21psi tapering down to 17 at redline sounds like a recipe for a WR!
BMW135xi's Avatar
Car: BMW 135I
Default 09-03-2016, 07:13 AM
BuraQ---60' are real good bro...
K.Jameel K.Jameel is offline
Car: BMW E92 N54
Default 09-04-2016, 06:16 AM
What about your HPFP i think you max it out very well!!!!!
BMW 335i '08 E92 N54, JB4 G5 IOS, BMS DCI, VRSF ***, BMS-Tial BOV Kit with Chargepipe, VRSF FMIC, BMS Meth Kit, JB4 MHD BEF, BMS PCV valve, BMS OCC. TCU Alpina_B3 Flash, .
The Leopard's Avatar
Car: E92
Default 09-04-2016, 07:07 AM
Ditto.
OP please stop claiming a WR on every forum. Hop on a dynojet and lets see what it puts down,
TS N54
BEAR-AvHistory's Avatar
BEAR-AvHistory BEAR-AvHistory is offline
335is 7DCT/JB4
Car: BMW 335IS 7DCT/JB4
Default 09-04-2016, 09:05 AM
Too much variance Dyno manufacturer to manufacturer. Some of my runs on a NC DynoJet were with 5WHP of the DynoJet Terry uses in California with identical mods. & software.
Close enough for government work.
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
2013 135is 6MT/JB4/ISO
2011 335is 7DCT/JB4/ISO/BMS Flash(sold)
FF Cobra Mk-IV COYOTE BOSS + TKO-600
BMW135xi's Avatar
Car: BMW 135I
Default 09-04-2016, 09:33 AM
I say he puts 450HP to 470HP in a Dyno...
