E90335i-RA E90335i-RA is offline
Car: 2008 335i
Default AFR Targets w/ E85 - 07-17-2016, 06:30 PM
I'm running E55/93 oct right now, FBO JB4 + MHD E85 BEF
My previous MHD custom tune (flash only) was targeting about 12.5 mid range and 11.9 - 12.0 top of RPM range. I noticed JB4 + E85 BEF is targetting about 12.8 near the top end. I'm hitting 12.8-13.0 top end. I feel this is a bit lean.
Educate me. Thanks!
Jsr1256 Jsr1256 is offline
Car: 08 335i Sport Package
Default 07-17-2016, 06:51 PM
I'm pretty sure that's what it spose to be these are direct injection. That's what my buddy's car runs afr wise with e85 bef anyways
08 E92 335i AT 20k Miles | ***** E60 Flash| E85 | VRSF FMIC | VRSF Lower Charge Pipe | ER Charge Pipe|Tial Bov| Vrsf *** | DCI | IC Sprayer | Scoops | NGK 1 Range Colder Plugs | Fuel It LPFP | E60 | [12.2 @ 118with e85 flash] [ My E60 flash 1/4 = 11.8 @ 120
icewall icewall is offline
Car: BMW 135i
Default 07-18-2016, 07:24 AM
What bef are you using. The 6/1 file run 12afr up top
Car: 2008 335i
Default 07-18-2016, 10:10 PM
Using 6/1
It's def targeting 12.8
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 07-19-2016, 12:13 PM
Follow the actual load and rpm to see where you are in the table.
Default 07-19-2016, 01:45 PM
Those maps target leaner AFR's for a couple reasons.
If you are running a stock turbo flash, you usually aren't running fueling upgrades beyond an LPFP upgrade, so getting to 450whp on heavy E85 mixes will take leaner AFRs or you will run out of fuel.
If you look at hybrid or ST flashes, you'll see those target approx. 12:1 up top. However those guys are also running Stage 2 or Stage 3 pumps and port injection so they aren't confined to the limitations of the stock HPFP.
SamJ SamJ is offline
Car: BMW 335i
Default 09-20-2016, 06:27 PM
so with FBO JB4 stage 2 pump upgrade and E85 Back end flash AFRs of 13 up top are ok?
Default 09-20-2016, 07:20 PM
Yes I think I'm at 12.9 to 13 hard to tell on jb4 graph tho its Def 13 area tho up top. I'll have to look at a csv when I get home . I'm on e85 flash with e60
Spxxx's Avatar
Spxxx Spxxx is offline
Default 09-20-2016, 08:55 PM
Shoot for 12.7-8 with E50ish if fuel upgrades can handle it
Default 09-21-2016, 07:28 AM
Looks like my CVS log is round 12.8 up top
bradsm87 bradsm87 is offline
Car: E90 LCI 335i
Default 09-22-2016, 02:03 AM
Has anybody tried a back to back comparison of running richer with the extra timing that it allows vs leaner with more limited timing? I run E21 (25% E85) and I still target 12.3:1 in the midrange and 12.1:1 up top with aggressive timing to make the power/torque back that was lost from running richer. The advantage of this is that EGTs and in-cylinder temps should be much cooler from the combo of richer afr and more advanced timing.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 09-22-2016, 12:27 PM
That's about how we set up our e25 map.
