Rich- Rich- is offline
Car: 2015 M235i
Default N55 EWG BEF running rich Log Review - 01-04-2019, 04:43 PM
First time posting on here, so if I will probably miss some information that is needed.
I have a 2015 M235i with ~22k miles. The car currently has a ********, full exhaust, VRSF intercooler, charge *****, BMS intake, JB4, MHD BEF. bit6 is enabled.
I wasn't having this code pop up until I did the BEF. I am currently using 93 fuel and I watch the AFR and it isn't ever rich on cold start.
Attached are the logs from today and screenshots of the code I get every time I start the car. If I need to log anything else, just let me know and thanks in advance!
Car: 2015 M235i
Default 01-04-2019, 04:44 PM
log 2
Car: 2015 M235i
Default 01-04-2019, 04:47 PM
*Sorry for a bunch of posts
Car: 2015 M235i
Default 01-05-2019, 06:50 PM
Just a small update since I have been driving the car more over the last few days. The MIL is popping up every time I start the car now. Doesn’t matter if it is a cold start or if I go into a store and come out.
Default 01-05-2019, 08:24 PM
If you clear, does it come back?
Car: 2015 M235i
Default 01-06-2019, 03:27 AM
When I clear it, the code doesn’t come back until the next time I start the car.
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 01-07-2019, 07:00 PM
I’m having a similar issue. Except mine is mixture too lean.
Car: 2015 M235i
Default 01-20-2019, 07:44 PM
So, I added some e85 in, to have an effective e40 mixture. Now the MIL is gone and hasn’t come back at all. Is this normal? Everything else seems fine other than I am still not getting any log pressure reading.
