djarett djarett is offline
Default JB4 Back End Flash Question regarding +2 psi - 09-01-2016, 10:47 AM
So I've had my JB4 G5 for a while, pretty familiar with it. I've recently added the basic bolt ons (vrsf CP, FMIC, ***) and decided to do the JB4 backend flash using MHD.
I successfully put the tune on, and set the 4/2 menu setting (I think.... When I go into menu 4, the option is pointing to 2, so I assume its set? These toggle menu options confuse me).
I'm running latest jb4 firmware (G5_ISO_32_5).
ON TO THE ISSUE:
I've read that the BEF will target 15psi on map 1 and 17psi on map 2. Since installing the other day, I have only seen 15psi in map 2 (reading my hijacked fuel gauge). I haven't done any logging to see what the jb4 is targetting cause my laptop battery is pooched. Replacing tomorrow and will log then but I'm still curious....
Is it true that in all cases, JB4 + BEF(pump) will target 15/17 psi in maps 1/2? I only have 91oct in the tank currently. I have access to 94 but no e. Map 5 was only giving me about 15 psi as well.
Is it possible it's an issue with my selection of the 4/2 setting for BEF?
Any insight is greatly appreciated, thanks!
Jayock's Avatar
Jayock Jayock is offline
Enginerd
Car: 2009 135i
Default 09-01-2016, 10:54 AM
It will target that. But a boost leak could prevent you from getting there.
Really need the logs.
--2009 BMW 135i--2016 Nissan Titan XD (Turbo Cummins ISV)--2016 VW Tiguan 2.0Tsi --1988 Beechcraft Bonanza--Suzuki GSX-R 1000--Honda CBR-600RR--
JB4 G5 ISO | MHD | E85 | Fuel-It S3 LPFP / PI | MFactory S3+ Clutch / SMFW / LSD / Mounts | Diff Lock | UUC Tranny Mounts | DwnPipes / Exhaust / FMIC | Chargepipe / Tial | KW V3s | HR Sways | HPA full M3 Suspension | BMS DCI / Oil Cooler Valve / Cowl Filters / 4bar / 2Step / OCC | RB PCV | Stri Gauges | Pole Position 225/265 | Installing: DR 6466ST
ThaCuda's Avatar
ThaCuda ThaCuda is offline
Car: 2007 335i
Default 09-01-2016, 10:56 AM
you are correct. Map1 is 15. Without a log, not much help here. If only 91, you need to either use map 1 or 5. And above all else, we need to see a proper log.
Did I mention do a log?
Logs will help.
Log.
2007 335i 4dr JB4, Hexon RR600, Inlets, 4Bar, Index 12, Boost Concept Pump, DCI, FMIC, DP and full exhaust, Burger Meth, MHD BEF. Auto.
Spxxx's Avatar
Spxxx Spxxx is offline
Car: E92 335i
I believe 4/2 also changes boost scaling on your dash gauges... you really need to log
M-Sport 135i - N54 - FBO - E60 - Mfactory LSD - MHD - JB4 - SPX Tuned
ThaCuda's Avatar
Car: 2007 335i
Default 09-01-2016, 10:57 AM
the in dash reflects the boost safety as scale
Haha alright guys thanks. It's coming!
Default 09-01-2016, 10:58 AM
Not sure I understand. Can you elaborate?
