Spxxx's Avatar
Spxxx Spxxx is offline
Car: E92 335i
Default Code 2d59 - While cruising (Recebt BMS MHD Race map) - 08-14-2016, 07:20 PM
Was cruising on hwy 5 after a hot day at Thunderhill where I beat on the car with zero codes and all of a sudden I get half engine limp mode + code 2d59 and oscillating RPMs while cruising in D mode at 75mph. Had to pull over and restart engine, car started running fine after a restart.
This seems to be a torque discrepancy seen by the DME?
M-Sport 135i - N54 - FBO - E60 - Mfactory LSD - MHD - JB4 - SPX Tuned
Spxxx's Avatar
Car: E92 335i
Default 08-14-2016, 07:44 PM
I've never had this code before this latest map I flashed and only when cruising... All torque settings are the same, even load settings.
Would it be unsafe to disable code 2D59 (Control Actual Torque)?
Spxxx's Avatar
Car: E92 335i
Default 08-14-2016, 08:19 PM
FYI this map had some timing/fueling changes but otherwise identical to BMS Race Flash (load tables etc)
Default 08-14-2016, 09:22 PM
Sounds like a flash problem on the torque related settings. If its not the actual race BEF then load the actual file.
Spxxx's Avatar
Car: E92 335i
Default 08-14-2016, 09:29 PM
It was, only things changed were fuel table and ignition table - neither would have any effect on torque output read by the DME
Spxxx's Avatar
Car: E92 335i
Default 08-14-2016, 09:43 PM
For some reason I was running an old BMS BEF that I modded, trying out the June release torque values.
