(#3901)
Bullyking Bullyking is offline
Car: 2013 535i
Default 03-07-2021, 03:14 PM
Map 2 is the worst on my car so much lag and barely pulls but Iíll get to it tonight or tomorrow and will post logs how many pulls should I do before logging
2013 535i n55 c/dp, bms intake , Jb4, MHD pwg2 e85 bef ngk 2step cooler plugs walbro 450 lpfp e40
435gc 435gc is offline
Default 03-07-2021, 04:21 PM
Log the 3rd pull.
May be worth doing a run without the sprint device to see if that is at all relevant. It does seem like your throttle is slow to come on once you mash the pedal.
Car: 2013 535i
Default 03-07-2021, 06:58 PM
Okay sounds good Iíll get to it tomorrow morning appreciate the advice and help
Car: 2013 535i
Default 03-07-2021, 07:10 PM
Not sure if it may be the firmware out of date but this is the version I am using and I also have the v1 board when I uploaded the newest firmware it gave me driver malfunction and 4 different codes so went back to this one
Car: 2013 535i
Default 03-08-2021, 11:34 AM
The three pulls I did today with map 5 with the adjustments and sprint booster off
Car: 2013 535i
Default 03-08-2021, 11:36 AM
3rd one
Default 03-08-2021, 11:56 AM
Looks like your wastegate is learning up and closing better now. However you are still pretty off your boost targets.
Can you do a proper log please. 3rd gear. Shifter to the left. Manual shifting. Sport+. Dsc off. 2k rpm pedal to the floor. Take it to 65krpm shift to 4th. Give another 2 secs. Take foot off the gas.
I would also suggest you post it in the support sub forum. That way BMS can weigh in as the experts.
Car: 2013 535i
Default 03-08-2021, 01:13 PM
Yes all pulls are sport + manual mode with dct off hereís map 2
Car: 2013 535i
Second
Default 03-08-2021, 02:00 PM
Thats a better log. The others you had multiple gear pulls.
Something funky is going on beyond my expertise. Map 2 is supposed to be an additive map, but your looks like an absolute map. Still not hitting boost targets. Boost leak may be your issue.
I would post your latest map 5 and map 2 pulls in the support section. So BMS can weigh in. May need a new control board or firmware adjustment.
Car: 2013 535i
Default 03-23-2021, 11:25 PM
Map 6 log with BEF and new Jb4
mrkelly23 mrkelly23 is offline
Default 03-28-2021, 04:17 PM
Hello all,
So I recently purchased the jb4 piggy for my n55 335i. Everything works great but the bc in dash. To go over some things I have done: made sure obdII was connected correctly, f10 comp mode enabled. ObdII bc button is not disabled. Updated to latest firmware. Anything Iím missing here?
dust0879 dust0879 is offline
Car: BMW F10 N55
Default Deleted - 03-28-2021, 06:22 PM
Deleted
Last edited by dust0879; 03-30-2021 at 06:54 AM.. Reason: Agreement with vargas tony
craigf20n55 craigf20n55 is offline
Car: m135i
Default Jb4 not working after firmware update. - 11-01-2021, 10:15 AM
Hi guy's hope all well. Recently tried to update the firmware on my f series n55 ewg jb4. All seemed to be OK and flashed OK. Bluetooth no longer connects, car runs like crap, jb4 no longer operational either, won't connect via Bluetooth or laptop and no dash control either. Have I blown this 2580 chip or something? I also wanted to run the ewg add on cable but now not sure what firmware to use. Need to resuscitate the jb4 first of course. Please help!!! Thanks guys
Flipper Flipper is offline
Car: 2015 BMW M235i 6sp
Default 11-01-2021, 02:23 PM
Hi Craig, I think it's a different problem but I recently updated the firmware on my 2015 M235i (EWG) and it killed my car as well. Turns out that even though my CAR has an EWG, the JB4 I have is an early PWG version. I flashed the latest PWG firmware, and the car was fine. Since you can't connect to your JB4, I'm not sure how much this will help you.
Contact support at BMS directly, via email - they were very helpful.
Car: m135i
Default 11-02-2021, 12:00 PM
Hi flipper thanks for the reply bud. I'm sure I have the correct board v3.0 of something. Was all fine but I thought I'd try the latest firmware. I've now ordered the new chip from Bms in haste. Read quite a few similar scenarios about the chip blowing. Currently the jb4 has been removed awaiting the chip. Cant beleive my luck with this car lately with all the plastic sh*t under the bonnet needing replacement. Done all the charge ***** including the turbo intake one, not cheap😭
RVA_N55_Fan RVA_N55_Fan is offline
Car: 2014 435i
Default BMS bov vs dv - 11-10-2021, 06:36 PM
Hey folks
I have the bms bov installed. A buddy w a similar car build as mine mentioned the potential need to get a dv+.
Question:
Should I get a dv (ts or gb) rather than the bms bov?
Daniel
2016 435i M-Sport EWG MPPK Manual 6, BMS Map 6 BEF-PS2-Race, Pure Stage 2 turbo, Spool-FX150 HPFP, Walbro 535 LPFP, BMS Intake, BMS FMIC, BMS BOV, 3.5 TMAP, ER DP, AA CP, FTP Turbo Inlet, H&R Sport Springs, BMW 335is clutch kit, BMS Clutch Stop, BMS Diff Bracket, BMS Wheel Spacers, BMW SSK, BMW Track Package
mbanks21 mbanks21 is offline
Car: 2015 335i
Default 02-08-2022, 12:10 PM
Updated to latest firmware, getting drivetrain error, reduced power, codes 123511 and 120408. Changed from map 5 to map 0, haven't gotten the error in 2+ days. Should I be updating my PID or any other settings with this new version? Sorry no logs available at the moment.
Default 02-08-2022, 04:22 PM
Could have a wrong setting, can't check that until you attach a CSV.
Car: 2015 335i
Default 02-08-2022, 04:41 PM
Can I email it to you from the app directly?
Default 02-09-2022, 11:51 AM
Email it to yourself, save it, and upload it here.
Car: 2015 335i
Default 02-09-2022, 03:41 PM
Hope this works. 2015 335, jb4 w mhd flash, flex fuel, ewg harness, 3 gallons of e85 not sure what else you need to know.
PID 20
FOL 70
I'm ignorant to a lot of this stuff so thanks in advance
Default 02-10-2022, 11:56 AM
I see you have them but are your EWG wires connected? Also, set your user adjustments back to the default values, enable option 6 since you have a BEF loaded, and then do a proper log on map 5.
To properly evaluate the tuning, we'll need a full throttle JB4 log from 40-90mph on a safe private track.
F Chassis N55 JB4 - N54Tech.com - International Turbo Racing Discussion
Car: 2015 335i
Default 02-10-2022, 02:43 PM
Hopefully that looks better and yes ewg is hooked up
Edit - just got drive train error again.
Default 02-11-2022, 11:06 AM
Did you set FF to 50 and it already worked its way back up to 150?
Also, try a log on map 1...I want to see what that looks like.
