(#201)
frb1979 frb1979 is offline
Car: M550i
Default Boostane and map2 - 10-20-2020, 05:25 AM
Hi Terry - I recently purchased the jb4 for my 2019 M550i. Is it safe to leave it on map2 for everyday driving? I use 93 gas
With the use of boostane pro, should I use a different map?
dlnkwnt dlnkwnt is offline
Car: 2007 335i Sport
Default 11-07-2020, 12:46 PM
Curious about e85 as well... Installing jb4 tonight. 2018 M550 93 oct.
Default 11-07-2020, 06:13 PM
Yes map2 should be fine for 93 octane, and you can run up to around 30% E85 as well. Start with map2 on that too.
Default 11-07-2020, 08:58 PM
thank u sir
Default 12-08-2020, 07:54 AM
Installed JB4 a few weeks ago, but cant get anything to connect. Bluetooth: Pixel 3XL, Samsung s20, and Samsung S9... all running Android 11. BMS Cable: Asus G14 running Windows 10. Both TMAP connections and OBDII cable connected, tried everything... Only thing i did not do was test the board itself for power. Where should i place my meter to test? thx. (2018 M550/JB4/Connect kit Rev 3.7)
Default 12-08-2020, 08:19 AM
Just email support for help, support@jb4connectkit.com. Adapter may be defective or wrong one for the JB4.
Default 12-08-2020, 08:34 AM
got u. thx
tonyjenkins77's Avatar
tonyjenkins77 tonyjenkins77 is offline
Car: 2011 BMW 750LI
Default Connection issue after firmware update - 12-28-2020, 09:33 AM
Hey @Terry,
I updated firm ware now I cant get a connection to bluetooth. Just installed yesterday with minimal connection issues. Also, the car has went into limp mode with Drive train code on display. Please help. N63 Not sure if this is relevant but I will attach a couple of logs as well.
Default 12-28-2020, 09:38 AM
Originally Posted by tonyjenkins77
Hey @Terry,
Sounds like a failed update then. You'll need to disconnect the JB4 until you can get the firmware loaded properly. Contact support@jb4connectkit.com and describe what happened. It's possible we'll need to send you a new 2580 chip to pop on and reset it.
Car: 2011 BMW 750LI
Default 12-28-2020, 10:00 AM
Yeah, because without the connection to the bluetooth, I cant confirm the interface. I was just trying to check interface. Thanks terry, I'll contact the support team.
Car: 2011 BMW 750LI
Default 12-28-2020, 10:02 AM
Is there a way to get the car out of limp mode prior to or post disconnecting jb4?
Default 12-28-2020, 10:09 AM
Just need to reverse the TMAP connections for the moment I'm afraid. Then the car will go back to running normally.
Car: 2011 BMW 750LI
Default 12-28-2020, 10:14 AM
Ok, Thanks.
Default 12-28-2020, 10:16 AM
Just to confirm what version of app are you using? The log above is from a data cable/windows?
Car: 2011 BMW 750LI
Default 12-28-2020, 10:22 AM
A333
Car: 2011 BMW 750LI
Default 12-28-2020, 10:27 AM
logging gave me the option to choose excell gave me an option to view through Handcome office view as well but I chose excell to view it
Car: 2011 BMW 750LI
Default 12-28-2020, 10:29 AM
A333 is the app version
Default 02-11-2021, 11:11 AM
Updated map guide in the app and first post, to go along with v7 firmware posted.
Car: 335i, 2009
Default 02-13-2021, 12:09 AM
Hey Terry, Recently got a 2020 X5 M50i!
But do I need the OBD port connected for stage 1 operation, or only TMAP? Trying to see if I can make it a faster install without having to install the OBD portion... thank you!
Answered my own question, I was looking at the wrong PDF for installation. The N63R clearly states Tmap only... thanks! Ill find out if its possible to install without removing as much paneling.. cross fingers and get my long stemmed tools ready!
JB4 ||| H&R Sport Springs
X5 50i 2013 ///M Sport
BMS Stage 1
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2021 M550i xDrive
Default 02-13-2021, 01:48 PM
You shouldn't have to remove any panels unless you want to run the wires for clean mounting. The TMAPs are accessible without it. The TU3 trucks should be the easiest of all installs due to airbox placement. On the cars we need to remove the crossbraces and airboxes. You don't have either one in the way, so you should have clear access.
The OBD install should take maybe 5-10 minutes. No inner panel removal is needed from what I've read. Just slit the grommet, run a stiff wire through, tape the plug to it and pull it back out.
Mike Levy
2022 Black Sapphire X3 M40i - At the dealer, awaiting pick up
Car: 335i, 2009
Default 02-15-2021, 02:01 PM
Thank you for the response! But is OBD necessary for only stage 1? I know OBD is required for logging, for obvious reasons. But was wondering if only stage 1 is desired, is TMAP only connections okay. Similar to a JB+, where no logging typically can be done, was curious if it's the same sort of functionality.
BMS Stage 1
Mike_L's Avatar
Anti-Social
Default 02-15-2021, 03:14 PM
Supposedly it defaults to Map 1 without the OBD. So it should work, just won’t be optimized.
Mike Levy
mxp-lax mxp-lax is offline
Car: X7 M50i
Default 02-20-2021, 12:11 PM
Hi. Does anyone know the part number to the M10x55 hex bolt that attaches the cross bar to the strut dome? We're supposed to remove it for the JB4 install on the X7 and the service manual says to replace the bolt once it has been removed. Thank you!
Mike_L's Avatar
Anti-Social
Default 02-20-2021, 01:32 PM
RealOEM.com - Online BMW Parts Catalog
I believe its Number 10.
Mike Levy
zse8h zse8h is offline
Car: M5501
Default 04-26-2021, 10:53 AM
@Terry
New 2021 M550i and JB4 on the way. What basic user adjustment settings do you recommend, if any? What software version should I run or does the JB4 ship with the most up to date software for the n63 chassis? Also is the OBD connection needed when running stage 1?
Thank you in advance.
