(#1526)
wardy335i's Avatar
wardy335i wardy335i is offline
Car: E93 335i
Default 09-28-2015, 10:47 PM
I noticed someone said about their better fuel economy.
I am stage 1 MHD 98RON and i get 22MPG around town and 32MPG on a 70-80mph run.
Very pleased with that considering i got 16MPG before mapping.
2008 E93 335i M-Sport 6AT
MHD Stage 1 // Dual Foam Cones // Avant Garde M359 //
Powerflex Black Edition Polys // Ferodo DS2500s // VRSF 3" *** // TBC
London
dotCEO's Avatar
dotCEO dotCEO is offline
Car: 08' BMW 135iM
Default 09-29-2015, 04:52 AM
Originally Posted by Mikewills
The latest ECU file is provided by MHD. You actually don't need to back up your ECU when flashing. I confirmed this the other day, when I flashed back to stock, even after deleting my old backed up BIN file.
Yea, I am able to go back to stock, but the issue is that my old BIN had something I need.
This doesn't seem like it's going to end well for me
7DCT 2013 LeMans Blue BMW ///335is (Pending Inspection)
6AT | 135i ///M Sport - CRASHED (TOTALLED)
Syclone Syclone is offline
Car: 2008 E88 135i Convertiblev
Default 09-29-2015, 07:29 PM
Originally Posted by themyst
I just wanted to add - these MHD maps are fantastic for fuel economy! The older Cobb / BT flash solutions used an extremely low load target to achieve 6AT flatline fix, but in turn it negatively impacted fuel economy during regular driving (a combination of AFR and load targets).
I was shocked to see having tons of power on tap with possibly better-than-stock fuel economy! Extremely happy MHD/JB4 stacker here!
I was suprised as well - E85 map on BB was a 19-20 mpg hwy....with MHD it is now 22-23 mpg.
I wonder what the Pump is....
Good work guys.
Lake Wylie, SC
2008 BMW 135i E88 Convertible
Blue/Black
Koni STR.T suspension, M3 Front suspension arms
JB4 Map 7, E85 Backend flash, Fuelit stage 2 fuel pump, Mechtech Intercooler, Raceland ***, NGK Sparkplugs, BMS DCi, Alpina Trans flash, BMS silicon inlets, BMS charge pipe.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 10-01-2015, 01:23 AM
Originally Posted by Blind35
i have code 2C9E
flash map - my stock fixed with my friend
I had to changed my Lambda sensor after DP
but code still stay
flshing don't help me
If you changed the right sensor (bank 1 after DP), maybe you have an electrical issue. Check wires all along till the DME connection.
Originally Posted by mave198
Been flashing with MHD for a couple of months now with no problems. However flashed the latest pump backend with the latest MHD version and now have a SES light on the dash with no codes showing up.
Anyone else had this problem?
Are you reading codes with JB4 or MHD?
Originally Posted by dotCEO
I performed an ECU backup when I first switched over to MHD. I am now trying to restore from the ECU backup I did, but I am unable to locate the backup file in any of the folders.
Any way I can recover this ECU backup?
The file is YOUVINXXXX_original.bin in the root of MHD folder on the device.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default MHD update - 10-01-2015, 01:28 AM
Here is the change log for the 09/24 (v1.10) update:
- up to 3 "JB4 backends only" licences can be purchased
- Stage 0 (stock map) is available for the "jb4 backend only" licence, to quickly switch to a stock map.
- map updates are 10s faster (other modules code clearing removed)
- Added codes clearing for other modules (transmision, dsc etc). Codes reading is supported only on the DME.
and the previous v1.09 build:
- new option: deactivate the pedal kickdown switch
- new option: raise engine idle speed
- show licences displays the order numbers
gefrozen gefrozen is offline
Car: BMW 135i
Default 10-02-2015, 07:43 PM
I have the same issue like Van3 has, I can't connect to the eco with the MHD flasher.
Somebody has a solution?
Traf Traf is offline
Car: 2009 135i Coupe
Default 10-02-2015, 11:35 PM
Make sure ignition is on (engine off) and JB4 in map 0. Otherwise you have a faulty cable.
f*** v-bands clamp
riva riva is offline
Car: 335XI
Default 10-03-2015, 07:48 PM
Is the battery adaptation reset the same thing as registering a new battery with the bt tool?
oldslow oldslow is offline
Car: 2011 335iS
Default 10-04-2015, 08:10 AM
MHD says ecu is read protected?
Blind35 Blind35 is offline
Car: 335Xi '08 N54
Default 10-05-2015, 01:39 AM
hi
i have e92 335xi 2008 (N54)
FBO and JB4 G4!!!
can i flash PUMP map???
bradsm87 bradsm87 is offline
Car: E90 LCI 335i
Default 10-05-2015, 02:44 AM
Did you have a Cobb and not do a proper uninstall?
Welterweight Welterweight is offline
Car: E92
Default 10-06-2015, 07:25 PM
I uninstalled my COBB AP then tried to flash the MHD Built in E40 Map and I keep getting an error. It says it cannot communicate with ECU. Turn ignition ON and plug into OBD.
I tried about 10 times with no luck. I feel I am missing something very simple here. HELP!
Do I need to purchase anything?!?!
wardy335i's Avatar
Car: E93 335i
Default 10-06-2015, 08:28 PM
Guys, a little help please..
What exactly are the BMS Flashes on MHD that are free??
I have an Auto trans do i need these or would they benefit ?
London
dh58 dh58 is offline
Default 10-07-2015, 02:41 AM
unfortunately BMS flashes don't have great notes.. We're told that there are lots of little improvements that add up.. Fueling, trims, afr, etc etc.
Russjonesr's Avatar
Russjonesr Russjonesr is offline
Car: Bmw e92 335i
Default 10-07-2015, 03:03 AM
Guys,
BMS flashes are for JB4 users....if you don't have a JB4 installed you should stick to the MHD flashes.
ksmyth's Avatar
ksmyth ksmyth is offline
Default 10-07-2015, 03:51 AM
Plugged in the android this morning to adjust the idle speed/reflash. MHD says a cable isn't connected. I just used the cable with DIS yesterday with no issues. In fact, when I plug the cable in MHD pops up, so I know it's seeing it. JB4 is on map zero. Anyone experience something like this? The only change I can think of would be updates on the android. Running 5.0.2 now.
09 335xi - 6AT - JB4 - hot side inlets - *** - MHD Flash - 7" IC - Fuel-It TBI
BostonBeemah's Avatar
Car: AW 135i
Default 10-07-2015, 10:57 AM
With an auto trans you will benefit as the tranny will see higher observed load to torque if I remember correctly. Mt users don't benefit as much but it's definitely worth the upgrade imo
RIP 2008 AW/BL 135i
wardy335i's Avatar
Car: E93 335i
Default 10-07-2015, 11:52 AM
Ok do i need to get JB4 or do i just run MHD stage 1 and BMS?
London
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 10-07-2015, 12:00 PM
Registering is only needed when your new abeerry has different specs than the former. But any battery change requires a battery adaptation reset.
You have a tune installed (MHD, Dinan, Cobb etc). email me if you need more help.
hi
FBO and JB4 G4!!!
I think bms doesn't support old JB4 versions. There is a cool thing about g4 that g5 can't do - map 0 is really passive, and you can run a MHD stand alone map, with the DME flash controlling the boost.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 10-07-2015, 12:09 PM
Most likely a cable issue. http://bimmersoftware.com/Cables is highly recommended.
Do you have Torque or other OBD apps installed? Maybe another app is fighting for cable control. Try a device reboot too.
Either you run MHD Stage1, or you install a jb4 to run a BMS backend instead of stage1.
wardy335i's Avatar
Car: E93 335i
Default 10-07-2015, 12:14 PM
Is anyone running the Stg1 +FMIC flash without an FMIC???
Logs ?
London
ksmyth's Avatar
Default 10-07-2015, 01:17 PM
Already tried the reboot. No go. Your app is the only app installed on the tablet. I bought it just for this. Other thoughts?
Car: E92
Default 10-07-2015, 04:51 PM
[QUOTE=MHD;412804]Most likely a cable issue. http://bimmersoftware.com/Cables is highly recommended.
I ordered the Bimmersoftware cable last night. It shipped today. Thank you!
ksmyth's Avatar
Default 10-07-2015, 05:40 PM
that is the exact cable i have... i just thought of one other thing. i did fire up the BT software with this cable inadvertently connected. could that screw the cable up?
ksmyth's Avatar
Default 10-07-2015, 07:04 PM
Screw it. Bought another cable just in case. Let's hope that's it.
