vickers507 vickers507 is offline
Car: 2010 335xi
Default 2021 G07 jB4 install - 01-30-2021, 03:29 PM
I am trying to install a jB4 into a brand new 2021 X7 M50i. The install directions do not match at all. Maybe I am missing something but completely different. Also, once I get into the wastegate connectors, the clips are on the wrong sides, but the connectors match otherwise. Just curious if others have tried this install yet.
Thanks, Ben
Default 01-30-2021, 05:03 PM
The EWG won't be compatible yet if you have the 180 out connections. As for the rest should be the same, TMAP sensors are located on the intercooler.
Car: 2010 335xi
Default 01-30-2021, 05:37 PM
Thanks Terry. Do you expect to just create a middle adapter harness to fix this in the future?
Ben
Default 01-31-2021, 03:24 PM
Ben
Yes we do
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2021 M550i xDrive
Default 01-31-2021, 09:54 PM
Can I ask what your build date is? BMW changed the N63TU3 DME in June, and the newer ones supposedly can’t be unlocked or tuned yet. If yours is newer and the JB4 works, I know I can install mine on my 8/26/20 build.
Mike Levy
phaser's Avatar
phaser phaser is offline
Car: X5 M50i
Default 02-01-2021, 08:39 AM
Originally Posted by Mike_L
Can I ask what your build date is? BMW changed the N63TU3 DME in June, and the newer ones supposedly canít be unlocked or tuned yet. If yours is newer and the JB4 works, I know I can install mine on my 8/26/20 build.
Would that also be true for a 2021 X5 M50i built in mid September of 2020? Probably a stupid question but I am learning.
Mike_L's Avatar
Anti-Social
Default 02-01-2021, 11:13 AM
Yeah, September is after June.
Mike Levy
Car: 2010 335xi
Default 02-01-2021, 01:40 PM
The build date is Jan-25-2021. I installed the jB4 over the weekend and it appears to be working correctly minus the wastegate control.
phaser's Avatar
Car: X5 M50i
Default 02-01-2021, 04:08 PM
Was asking in terms of M550i vs M50i, wondering if they would be exactly the same. I am new to this BMW turbocharged stuff.
phaser's Avatar
Car: X5 M50i
Default 02-01-2021, 04:35 PM
Can you gives us a short review. Does the vehicle feel faster? Increase in low end, mid range, top end? Really like to hear.
Mike_L's Avatar
Anti-Social
Default 02-01-2021, 05:26 PM
They're identical besides the air filtration system and ***-back. Even the ********* are shared.
Mike Levy
Mike_L's Avatar
Anti-Social
Default 02-01-2021, 05:27 PM
Perfect. Once we get a little warmer I'll do it too.
Mike Levy
