Wht550Jersey Wht550Jersey is offline
Car: 11 550i
Default Installed jb4 . T map engine codes - 03-09-2020, 03:03 AM
T map signal active with engine off
T map signal short circuit to B +
Reduce power
I checked the plugs everything seems connected . I had no issues prior to install
2011 550i
Default 03-09-2020, 10:06 AM
Loose wire inside harness, damaged JB4 board perhaps. You'll need to further diagnose it.
Car: 11 550i
Default 03-09-2020, 10:21 AM
Iíll open it up again . Terry could it be the blue wire on the 24v red wire ? Will I be able to get a board swapped ? I just opened the box yesterday
Default 03-09-2020, 10:47 AM
What blue wire is on the 24v red wire? Got a picture?
Car: 11 550i
Default 03-09-2020, 10:56 AM
For the Bluetooth that gets posi tapped in the jb4
Default 03-09-2020, 05:07 PM
The spot is fine but sometimes people pull out pins in the process. Unplug the JB4 control board from the harness and ensure the gold pins all line up.
Car: 11 550i
Default 03-16-2020, 06:27 AM
I got a new board and still showing t map short circuit to b + . I have replaced spark plugs , coils and now a new board . Checked all the gold pins there in . Unplugged the harness to tmaps and plugged back in . Iím at a lose . Any ideas what this code is ???
Default 03-16-2020, 10:19 AM
Did you damage the Tmap sensor some how?
Car: 11 550i
Default 03-16-2020, 10:34 AM
I never took them out . Iím replacing to 3.5 from you guys with type a harness . I have replaced everything . Car runs fine with out jb4
Default 03-17-2020, 10:40 AM
You're not providing photos, log, or anything we could use to help you. But if you want to send the JB4 in we can always test it here to insure it's working properly.
