dltbmw750 dltbmw750 is offline
Car: 2012 BMW 750i
Default 750i support help - 06-20-2019, 11:20 AM
Hello everyone,
I'm new to all of this so bare with me.. I have a 2012 750i and I just installed the JB4 (which is freak'n awesome) I have it set on MAP 1 but did try 2 abd 3, I noticed with MAP2 I was burning more gas and 8.95 a gallon for 100 octane isn't cheap. But anyway I set it back to MAP1 which is still great but I noticed when I pushed it I got the drivetrain malfunction on my iDrive screen but the car didn't go limp at anytime while driving so I didn't worry about it. I did notice that the car idle a little rough sometimes but not bad. I check the codes on the mobile App and this is what came up: 118802, 128401 and 120308 Boost pressure lower than expexted. After reading the other post I believe these are turbo codes which may indicate I have a leak. Anyone else had this on they're F01?
Default 06-20-2019, 11:33 AM
First step is to post a JB4 log so we can see the details!
Car: 2012 BMW 750i
Default 06-20-2019, 05:04 PM
https://mail.google.com/mail/u/0?ui=...2b3b3862aac741
Default 06-21-2019, 03:17 PM
Sorry I can't open that file
Default 06-24-2019, 10:07 AM
Originally Posted by dltbmw750
Post the CSV file and we'll take a look.
Go to advanced on the reply box, then click the paperclip to attach a file.
Car: 2012 BMW 750i
Default Log - 06-28-2019, 09:20 AM
Here's the log.
Car: 2012 BMW 750i
Default 06-28-2019, 09:21 AM
I want to run E85 in my 750. Which Map is recommended for that?
Car: 2012 BMW 750i
Default 60% 100 Octain 40% E85 - 06-29-2019, 07:21 AM
Here's the latest log. Ido realize it's gonna take some time to learn to read the logs so I'm depending your expertise fellas and I truely appreciate ya..So This is the latest log. The previous logs I was running 91 octane in which I was getting the Drivetrain Malfunction. Ran 60% 100 octane and 40 E85 and wow what a differnce and the best part no Drivetrain Malfunction so far. So I attached the code so that you guys can take a look and see the what changed from the previous log I posted.. Thanks in advance.
Car: 2012 BMW 750i
Default 60% 100 Octain 40% E85 - 06-29-2019, 07:23 AM
Oopps..forgot to upload log. My bad!
Car: 2012 BMW 750i
Default 06-29-2019, 07:24 AM
By the way.. I was running on MAP 3
Default 06-30-2019, 09:31 AM
Let's see a log on map1 next. Also 40% E85 is too much keep it around 20-30%.
Car: 2012 BMW 750i
Default Log - 07-03-2019, 06:58 PM
Here's the log running with MAP 1
Default 07-07-2019, 10:56 AM
Any codes or issues on map1?
Car: 2012 BMW 750i
Default MAP 1 Codes - 07-24-2019, 05:48 PM
These are the codes using MAP 1.
Default 07-24-2019, 07:06 PM
Did you clear all codes ahead of time (ign on, engine off) so we know what is current?
Car: 2012 BMW 750i
Default 07-30-2019, 11:12 AM
I cleared them while the engine was still runningand when I went to check for codes there were not any to be found. The engine light was out as well so I figured everything was cleared.
Default 07-30-2019, 06:00 PM
Misfires are the main codes there, maybe crashing the fuel system with E85 use. Able to trigger codes on map1 on pump gas?
Car: 2012 BMW 750i
Default 07-30-2019, 08:26 PM
I'll run out the fuel I have in there now and will replace with straight pump gas.
