Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2021 M550i xDrive
Default Did we ever get the EWG plugs straightened out? - 12-24-2020, 07:17 PM
Or are they still upside down for the TU3? Finally broke 1200 miles, finally floored my car and man was I underwhelmed. Sure donít feel like 523hp. More noise than acceleration. The midrange thatís great for normal driving (and makes it a better street car than the M5) feels like **** at WOT. JB4 is going on this weekend. Just need to know if the EWGs will work or if I should just install the TMAPs and obd. Thx.
Mike Levy
Default 12-24-2020, 10:38 PM
Fits some models, others have them 180 out and they don't fit, yet.
Mike_L's Avatar
Anti-Social
Default 12-25-2020, 01:12 AM
Okay, I’ll try them and find out. One looks easy to access, not so much the other.
Mike Levy
phaser's Avatar
phaser phaser is offline
Car: X5 M50i
Default 12-25-2020, 08:03 AM
Originally Posted by Mike_L
Okay, Iíll try them and find out. One looks easy to access, not so much the other.
Please, please, take some pics while you are working on connecting the EWGs to the JB4.
Mike_L's Avatar
Anti-Social
Default 12-25-2020, 11:29 AM
I think itís these. Access isnít as good as it looked like at first glance. Actually it looks like it may be easier to remove the actuators than access the plugs with them installed.
Mike Levy
phaser's Avatar
Car: X5 M50i
Default 12-25-2020, 01:18 PM
Great pics Mike.
Thank You.
Looks like the actuators are secured with (4) allen screws from what I see there.
Let me know how it goes. I'm guessing that my '21 X5 M50i will be the same config.
phaser's Avatar
Car: X5 M50i
Default 12-25-2020, 08:18 AM
The 5 lbs of boost on map 1(maybe map 2) should be a very noticeable increase in power. I certainly hope so as I will be installing a JB4 on my '21 X5 M50i in Jan. and will likely have a '21 M550i by early summer and am considering the JB4 for that also. Lets us know how you make out, hope it gives you a nice big "bump"!
Mike_L's Avatar
Anti-Social
Default 12-25-2020, 06:42 PM
Its gonna be a few days. I gotta get a set of E Torx sockets. Thought I'd be able to remove the cross bar bolts with a hex, but I'm going end up rounding them off.
Mike Levy
phaser's Avatar
Car: X5 M50i
Default 12-25-2020, 06:51 PM
I couldn't tell if they were hex or Torx. Rounding them out with a hex driver would be a real PIA.
phaser's Avatar
Car: X5 M50i
Default 01-02-2021, 08:43 AM
Hey Mike, any success or progress with those waste gate actuator JB4 connections?
Mike_L's Avatar
Anti-Social
Default 01-02-2021, 09:29 AM
Haven’t had a chance to work on the car. Been working with BMW and the dealer on issues with the Tanzanite blue paint (it’s very soft and scratch prone), so I’m kinda afraid to lean on it until I get a ceramic coating next week. Don’t want to make it worse than the road debris already did.
I’ll see if I can pop off the driver side connector without removing the actuator. At least then we’ll know if it’s right or upside down.
EDIT: Nevermind. My big hands can't even get to the clip. Actuators are going to have to come off. I need to find out what size hex key fits the screws and pick up a long one. My sockets are way too big to even get to the them to figure out the size.
EDIT Again: it’s either a 5/32 or 4mm hex. I ordered both so we’ll see.
Never fear though. As anyone who knows me would attest, I'm too stupid to give up. I will get this done, even if it takes a long time.
Mike Levy
Mike_L's Avatar
Anti-Social
Default 01-22-2021, 12:09 PM
UPDATE: Okay, like I said, I'm stupid and persistent. I got it done. No point in unbolting the actuators. They're still attached to the wastegates via rod, and they don't move much. Plus I lost a screw, so its safer not to even bother.
Anyway, The harness clips into the JB4 harness perfectly. However, the plug is upside-down to plug into the actuator. For me, it doesn't really matter. I have no desire to screw with those plugs ever again. For everybody that does, its not gonna work.
Mike Levy
Default 01-22-2021, 03:44 PM
Sounds like you have one of the 180 degree orientated ones then.
phaser's Avatar
Car: X5 M50i
Default 01-26-2021, 05:50 PM
Is there a solution to this?
Default 01-27-2021, 10:53 AM
We have the updated connectors required but have not made adapters yet for them.
phaser's Avatar
Car: X5 M50i
Default 01-28-2021, 08:38 AM
So somewhere in the near future we will be able to make the wastegate connections to JB4?
Mike_L's Avatar
Anti-Social
Default 01-23-2021, 10:40 AM
Yeah, pretty sure all the TU3s are going to be.
Mike Levy
Default 01-28-2021, 12:13 PM
For those models with 180 out EWG connections, yes. We have the connectors here. Just need a 180 degree car to turn up so we can confirm the wiring positions for them.
Mike_L's Avatar
Anti-Social
Default 01-28-2021, 06:17 PM
You need access to a 180 degree car and a GM 2.0T. I have both. How about a trip to Central Florida?
Mike Levy
Default 01-29-2021, 11:13 AM
lol thanks but we'd need them here where we have all the testing and development equipment.
We have a new AWD dynojet going in March so I expect we'll get a lot more random cars in after that by offering them free dyno runs in exchange for letting us poke around a bit under the hood.
phaser's Avatar
Car: X5 M50i
Default 01-29-2021, 05:27 PM
How does your M550i run with just the 2 JB4 connections made?
Mike_L's Avatar
Anti-Social
Default 01-30-2021, 01:28 PM
I don't have it installed. In talking to some of the flash tuners, I'm hearing that the DMEs from 6/20-up are causing issues with tuning. They're locked down tight and aren't tuneable yet.
With that said, I'm trying to find out if the programming inside is different too. If it is, then theres no way to know if the JB4 will even work as expected. BMW isn't sharing the latest ETK or tech info yet, so I'm waiting until some others install it first to be sure. I can't risk a $35k motor in a lease on the expectation that it will work. It'll do something, but if the DME will fight it, I have no idea.
Mike Levy
phaser's Avatar
Car: X5 M50i
Default 01-30-2021, 05:21 PM
Thanks Mike, appreciate the update.
zse8h zse8h is offline
Car: M5501
Default 05-20-2021, 12:46 PM
Bump. I would like to hook my EWGs up. Does anyone know if the hardware is ready yet?
phaser's Avatar
Car: X5 M50i
Default 05-21-2021, 06:06 PM
Looking for this info also. Lets go!
