(#1026)
Sossa215 Sossa215 is offline
Car: F10 M5
Default 09-26-2018, 10:52 AM
Originally Posted by Kolbe
Great, but I don't understand the logic of going to Map 1 first. It's an additive map and hence will add onto the BM3 target of 22psi which will be too high. Why not go to map 2 (22psi) and use the BCM benefit to hit the target of the BM3 BEF which is also 22psi (together with all the other JB4 + BCM benefits) - can the BMS experts please clarify?
I was thinking the same thing. ???
Kolbe's Avatar
Kolbe Kolbe is offline
Car: BMW F10 M5
Default 09-26-2018, 11:06 AM
Is your boost also tapering off at high rpm? Mine is around 19 - 20psi up to 5500rpm and the tapers of to about 17psi at 7000rpm on Stage 2, 91 octane BM3 map. Thought that the BCM can help here to keep the boost at a higher level at high rpms ... hence the idea of JB4 + BCM on map2.
Car: F10 M5
Default 09-26-2018, 12:42 PM
Not sure if my boost is dropping, just planned running the JB4 also since I was running that before flashing with BM3. Figured that the JB4 would always make my car hit numbers.
Did you upgrade your spark plugs yet?
Kolbe's Avatar
Car: BMW F10 M5
Default 09-26-2018, 08:04 PM
Yes, have changed to two step colder NGK plugs and gapped them correctly. I am at 5000ft altitude so turbos have to work harder.
alexk alexk is offline
Car: M5 F10 and M3 CSL
Default 09-30-2018, 04:11 AM
Today I pushed a bit the car at 240km/h, and I got cylinder misfire.
JB4 with water meth running maximum 22PSI.
Is this normal ?
sabujan sabujan is offline
Car: 335i f30 2012
Default 10-10-2018, 12:03 AM
Car: 335i f30 2012
Default 09-15-2018, 08:07 AM
Hi Terry .. I have a JB4 connect kit REV3 with blue wire removed from M135i - to which wire should i connect it on my S63TU V1 board. Thanks
Default 10-10-2018, 10:22 AM
Car: 335i f30 2012
Red wiring that comes off the harness.
Default 10-21-2018, 12:18 PM
Hello,
How can I find what is causing the misfire when I am WOT with the methanol enabled ?
I do not get this with map 1 for example.
thanks
5soko's Avatar
5soko 5soko is offline
Vintage
Car: F10 N55 PWG
Default 10-21-2018, 01:27 PM
Is there a difference in maps to run for a compeition package equipped car?
2014 F10 535i N55 PWG
Default 10-21-2018, 06:40 PM
Originally Posted by alexk
Hello,
thanks
Could be a variety of things ranging from a defective nozzle to some physical issue with the car like a plug, coil, or injector.
JB4 log of issue would be a good start though.
It's not much of a difference, same mapping guide is used for CP vehicles.
Default 11-11-2018, 04:28 PM
Had both our 2015 F10 M5 and 2018 F90 M5 out at NFZ this weekend for some half mile action. Managed to get a couple side by side races in the video below! Best trap of the day for the F10 M5 was 167mph @ 27psi (map8), and for the F90 166mph @ 25psi (map3).
Default Yesterday, 03:49 PM
V2_2_3:
1) Logical change to allow boost to target below the factory boost levels, especially useful for those using flash maps in conjunction with the JB4.
2) Adjustment to code read functions, may need updated interface to properly read codes from both ECUs.
