Yarbis's Avatar
Yarbis Yarbis is offline
Car: 2010 335I E93
Default Rattle upon 25% or less throttle, Not hitting boost target. - 04-09-2020, 01:18 PM
So, I recently blew my cats out and replaced with empty *****. I was having a boost issue, and it was much worse until my D p's were installed, since there were pieces of *** blocking my exhaust. Now that my car has fbo, I would expect it to run amazing. However it feels strong in lower rpms than higher.
In the last thread I started, I was told I look great on my logs, however my timing was being adjusted, and it was recommended I throw some e85 in to bring the octane up.
What I would like to know is, could this rattle that only comes on under light acceleration be related to timing/octane? And could these timing adjustments be making or causing this rattle? Or could these be my wastegates? And could this be the reason Im making 14psi when the boost target is 17psi?
What I have done so far:
Checked my boost solenoid's vacuum, both are right up with each other and look good.
When doing my *********, I finally plugged the vacuum line for the exhaust flap, which didnt have anything in it for a while, but the car boosted harder with it not plugged. (dont know if this caused any issues, but i would assume it did more good than bad plugging a vacuum leak.)
Checked for loose hose clamps or piping from hot side of the IC to the intake mani.
My mods:
D p's
DCI
BOV & chargepipe
IC
JB4 & MHD BEF
I will take any logs requested ASAP, and I am going to take a few initial logs to put here in a few minutes.
Yarbis's Avatar
Car: 2010 335I E93
Default 04-09-2020, 02:35 PM
Heres a log of Map 2 & 5, and I have only about 13 psi vs the 17psi target
Default 04-09-2020, 03:42 PM
You’re pretty under target, & FF is maxed
That rattle is likely worn wastegates
Yarbis's Avatar
Car: 2010 335I E93
Default 04-09-2020, 04:15 PM
That gives me SOME peace of mind about the rattle. Sounds like its time to save for a single.
And if I remember correctly from my previous thread, you said it is most likely a leak correct? Unless a silicon connector on the intake somewhere popped a hole or something, since I've already checked for leaks visually, do you think FF would be maxed with boost under target due to a vacuum leak or maybe wastegate leak?
Yarbis's Avatar
Car: 2010 335I E93
Default 04-11-2020, 02:37 PM
Could my BOV be letting boost off too quickly? I dont know what springs I have, but it was a package for an n54 so I know 11psi is standard. Here's some more logs in different maps. It looks to me wgdc and ff is good now, but I just don't understand why I can't achive full boost and why it feels laggy-er than it used to.
Default 04-11-2020, 07:50 PM
I don’t see any logs attached.
Rattle like your describing sounds like text book wastegate rattle / worn Turbos
You can replace / check everything, but if the Turbos are physically showing signs of rattle - replacing things outside of Turbos probably won’t help much
Yarbis's Avatar
Car: 2010 335I E93
Default 04-19-2020, 07:23 AM
Sorry for the long delay, been stupid busy this week.
Here's some logs, I don't know why they didn't attach before.
In these logs, the jb4 shows meth, but I'm not using meth... Could this be a reason that my boost is not up to target, and I feel like timing is a little low up high, what are normal timing values to have?
Also, rarely I get a long crank time lately, but it doesnt happen more than once a week if that. This gives me a small suspicion it could be HPFP related.
Default 04-19-2020, 09:22 AM
Based on these logs, up top you can see your boost fall 2-3 psi under target & wgdc is up there in the 80-9x range. This tells me that your Turbos are working extremely hard & still are not able to achieve target aka tired Turbos.
I think your going to struggle to make more boost up top, given your Turbos condition that you are describing.
