jtrejo jtrejo is offline
Car: 535 2008
Default JB4 Help for F chassis ewg - 11-27-2018, 08:11 AM
I have a f chassis with ewg and Bluetooth adapter and it keeps failing to upload update from the ios app and now my jb4 says no firmware detected , keeps failing, what do you think it could be. I ended up unplugging it from the motor because of delayed start and engine malfunction.
Can the JB4 be updated with it just being plugged into the ob2 port?
any and all help appreciated
2015 535 - JB4 - VRSF pipe- Burger Intake - Straight piped - MHD Backend Flash
Martin.328 Martin.328 is offline
Car: 16 328
Default 11-27-2018, 09:42 AM
are you able to connect to it ?
Car: 535 2008
Default 11-27-2018, 09:50 AM
I was able to when it was all connected, but would fail around 100 furthest I got was 400, now just fails around 100ish, so I’m confused
Default 11-27-2018, 10:03 AM
Is ignition fully on? If you have a weak phone signal holding phone close to blue tooth adapter can also help.
Car: 535 2008
Default 11-27-2018, 10:43 AM
ill try that again, but Terry can the board be updated just plugging in the obd2 plug and not anything else?
Car: 16 328
Default 11-27-2018, 11:15 AM
No it gets power from the sensor
Car: 535 2008
Default 11-27-2018, 02:45 PM
what sensor?
Jon @ BMS's Avatar
Jon @ BMS Jon @ BMS is offline
Administrator
Default 11-29-2018, 12:32 PM
Originally Posted by jtrejo
what sensor?
The TMAP sensor connection is required to power the JB4.
It is the sole responsibility of the purchaser and installer of any BMS part to employ the correct installation techniques required to ensure the proper operation of BMS parts, and BMS disclaims any and all liability for any part failure due to improper installation or use. It is the sole responsibility of the customer to verify that the use of their vehicle and items purchased comply with federal, state and local regulations. BMS claims no legal federal, state or local certification concerning pollution controlled motor vehicles or mandated emissions requirements. BMS products labeled for use only in competition racing vehicles may only be used on competition racing vehicles operated exclusively on a closed course in conjunction with a sanctioned racing event, in accordance with all federal and state laws, and may never be operated on public roads/highways. Please see http://www.burgertuning.com/emissions_info.html for more information on legal requirements related to use of BMS parts.
Car: 535 2008
Default 12-03-2018, 07:29 PM
so i re connected it and tried uploading new firmware i put my phone right next to my jb4 this time and it installed but after it verifies it says error failed checksum testing file : 42327 read 3545817. so what could the issue be ?
Default 12-03-2018, 09:53 PM
Means you still have a bad connection, maybe check blue tooth adapter on JB4 to ensure that's solid. If all else fails order another 2580 chip from our site for $25, those come with firmware pre-loaded.
Car: 535 2008
Default 12-03-2018, 10:25 PM
ok i just ordered it and the ewg cable
Car: 535 2008
Default 12-03-2018, 10:32 PM
does it matter what red wire you power the bluetooth from?
