treycane treycane is offline
Car: F30 N55 EWG
Unhappy JB4 with BM3 log help - 07-24-2019, 09:36 AM
Hello guys I'm new to the forums, I recently sold my N54 335is for a F30 335 ewg. I'm currently having some issues with fuel trim levels the car is fbo with pure stage 2 and port injection with fuel it upgrade lpfp. I've attached a data log any help would be much appreciated. Thank you !!
e46m3to335i's Avatar
e46m3to335i e46m3to335i is offline
Car: 2015 F22 M235i
Default 07-24-2019, 10:02 AM
Does the car have a flash tune on it?
2014 335i xDrive / Silver / ZF8 / M-Sport / 400M / BM3 2H Map / xHP Stage 3 / ATM FMIC / H&R Sports / VRSF **/CP
Car: F30 N55 EWG
Default 07-24-2019, 10:11 AM
It has Bootmod3 installed e30 map
Car: 2015 F22 M235i
Default 07-24-2019, 10:20 AM
Good luck man. I'm having issues with stacking the JB4 with my BM3 tune as well. Not getting a lot of help on here either. :-(
Car: F30 N55 EWG
Default 07-24-2019, 10:25 AM
I know man I thought people would be more helpful on here
Good luck to you as well
Car: 2015 F22 M235i
Default 07-24-2019, 10:38 AM
I've been active on here for quite a few years. I can tell you this, before BMS branched out to 18 other vehicle platforms, troubleshooting and getting questions answered were second to none....
Car: 2015 F22 M235i
Default 07-24-2019, 10:42 AM
I'd try to ask over on the other forum for insight but if you mention the JB4, it's like saying you have an STD or something LOL. Don't get me wrong, I'm very happy with my BM3 tune, but the flexibility with the JB4 is an awesome addition to a flash tune. Once you get it working properly.....
Default 07-24-2019, 10:59 AM
Looks like DSC is kicking in and then you trigger a safety system.
Let's start with a lower map like map2 to evaluate a clean run first before going up.
Car: F30 N55 EWG
Default 07-24-2019, 11:07 AM
Thanks Terry my map 6 is a custom map for my Bootmod3 e30 flash, I switched over to map 4 for logging only to check. I've attached that log of map 4.
Default 07-24-2019, 11:50 AM
Map4 is too low. Map2 please.
Car: F30 N55 EWG
Default 07-24-2019, 12:12 PM
Ok perfect i'll try map 2 and report back in a few. Thank you
Car: F30 N55 EWG
Default 07-24-2019, 02:37 PM
Attached is a map 2 pull from 2nd gear until 5th. Thank you!
Default 07-26-2019, 02:55 PM
I see a few things. Let's try this next.
Map7, enter 75 across the board on fuel bias to increase port injection mapping.
Default 07-26-2019, 02:59 PM
Have a thread? Normally the issue with BM3 is they set the target really high. So that might require a special JB4 side setting.
Last thread I saw from you was about fuel pressure connector not working on a used system? We need to get your hardware going too. If you have a tuning issue also post the details in the same thread so we can cehck that out.
Car: F30 N55 EWG
Default 08-01-2019, 03:11 PM
Thank you Terry! but how do I adjust the fuel bias for map 7? I'm using the jb4 mobile app with the bluetooth connection for android. Also my e85 gauge doesn't work on the app, I don't have a ethanol setting under wmi nor a n20 map sensor category.
Dave @ BMS's Avatar
Dave @ BMS Dave @ BMS is offline
Default 08-01-2019, 11:45 PM
Settings > user adjustments
Fuel bias should be the middle column
