MyN54isSlow MyN54isSlow is offline
Car: E92 335i 6MT
Unhappy WTF is my rail pressure doing? Is this normal? - 10-13-2020, 05:07 AM
Yesterday, after driving to work, upon parking and letting the car idle a for a minute, rail pressure shot up from ~700 to ~2000psi. I’ve got a log here: *********** | E92Dave | WTF is my rail pressure doing? Is this completely normal? Found it a little odd.
Edit: Spike at the end is me blipping throttle to see if it would drop, it did.
Car: E92 335i 6MT
Default 10-13-2020, 11:38 PM
Does anybody know?
Bmw335turbo's Avatar
Bmw335turbo Bmw335turbo is offline
Car: 335
Default 10-14-2020, 05:48 AM
Originally Posted by MyN54isSlow
Does anybody know?
Maybe something in the line?
08 335Ci's Avatar
08 335Ci 08 335Ci is offline
Car: 08 335Ci
Default 10-14-2020, 10:02 AM
Yesterday, after driving to work, upon parking and letting the car idle a for a minute, rail pressure shot up from ~700 to ~2000psi. Iíve got a log here: *********** | E92Dave | WTF is my rail pressure doing? Is this completely normal? Found it a little odd.
Normal operating range is 1500 to 2000 PSI. I'd be more concerned about the 700 PSI.
Totaled by a careless driver:
'08 E92 335, M sport option
Car: E92 335i 6MT
Default 10-14-2020, 01:30 PM
1500-2000 is normal at WOT. At idle ~700 is what it should be at.
Car: E92 335i 6MT
Was a thought of mine since I removed the rail for the vcg recently
08 335Ci's Avatar
Car: 08 335Ci
Default 10-14-2020, 04:06 PM
If you know better, why are you asking? And I have 1500 psi at idle.
Car: E92 335i 6MT
Default 10-14-2020, 04:36 PM
Did you even read my question? Iím asking not what it should be, but if anyone has an idea as to why it is not what it should be. I can start the car, hpfp immediately goes to ~2200 as it should, and after about a minute or two comes down to ~700 like it should. After driving the car, and observing pressures are exactly how they should be, when I go to park it, if I park and let it idle for a little bit, the pressure will shoot from ~700 to ~2000. When I first noticed it, it would hold that ~2000 until I blip the throttle and it would come down for a few seconds and go back up. Today upon parking at work, it went up to ~2000 but then started fluctuating between ~2000 and ~700. As for yours being 1500 at idle, idk what to tell ya, there are countless threads on here stating it should be ~700 at idle and increase with load, being at 1500-2000 at WOT.
Car: E92 335i 6MT
Default 10-14-2020, 05:59 PM
Well out of a long shot the other day I threw in some LiquiMoly Jectron to see if maybe something was stuck in the line or who knows. Just got home from work, let it idle and the rail pressure never shot up this time. Not sure if it was just this once or not. Gonna take a log when I get to work in the morning.
