Stevae Stevae is offline
Car: 2009 BMW 335i E92
Default Need some help with post LPFP install, and long starts... - 10-08-2020, 04:40 AM
Hey guys, I've installed a Spool Performance bucketless Stage Two LPFP, and the car ran without problems for about a week or so. Now I am getting frequent warnings about the fuel pump, saying there's a problem. When I connect MHD to read the codes, it mostly shows "2ABD DME: Boost-pressure sensor, overrun." But sometimes also shows "2F0C - Intake air temperature sensor." But mostly only the first one.
Afterwards, sometimes the car will then ignore that warning and go on running normally. And sometimes I need to delete codes with MHD. Then the car runs fine for several days before showing that code again. And usually it ONLY shows that code if I run it hard.
Any advice or information on this would be highly appreciated, as I really do not want to go back into the fuel tank if I don't have to. Thanks.
