Jezabelle Jezabelle is offline
Default Pi with stage 2 pump - 10-03-2020, 12:13 PM
Hey sorry I tryed searching but my phone isn't playing along...got a good deal on a bmp pi kit and right now I have stock twins FBO everything but outlets on stage 2 bucketless pump.
Could I run pi with that on stock turbos and run full e85?
What is the max power with pi before I start loading low pressure fuel with pi?
Zeezul's Avatar
Zeezul Zeezul is offline
Car: e92 n54 pre lci
Default 10-08-2020, 10:49 AM
With the buckletless setup you should be able to run full e85. Max power as in hp or psi on the stock snails? Max hp should be around 450/500. Max psi on stock turbos is around 24 psi. I'm fbo, pi, inlets/outlets, old fuel it stage 2 pump, and i run around an e65/e70 mix w/o issues.
FBO MT N54 w/stock turbos-tuned by Trebila
