trb1 trb1 is offline
Car: 2009 e90 335i
Default Failing or crashing hpfp? Scary logs. - 10-01-2020, 07:01 PM
6062 precision doc race kit. After this log I turned the boost down and FOL up to 80, and now am spraying meth. Consistently getting random lean pulls.
Car: 2009 e90 335i
Default 10-01-2020, 07:32 PM
I notice that i overboosted, but trims/hpfp were maxing beforehand. I ran 22 PSI for several weeks before these issues started happening
Car: 2009 e90 335i
Default 10-01-2020, 07:40 PM
Hereís another log today. Afraid to push it into boost at all right now because Iím getting timing drops in a few cyls from being lean now. AFR is scary high.
Default 10-03-2020, 06:13 AM
Do you have a log without spraying methanol?
Is the methanol kit a new addition?
Car: 2009 e90 335i
Default 10-03-2020, 08:33 AM
No it’s not. I’ve had the meth kit on for a while. I’ll try and get a map 1 log today.
Default 10-05-2020, 06:56 AM
Originally Posted by trb1
First log is no meth. No itís not. Iíve had the meth kit on for a while. Iíll try and get a map 1 log today.
Sounds good.
What flash as well is on?
Car: 2009 e90 335i
Default 10-05-2020, 05:19 PM
Sounds good.
its just on the standard single turbo MHD BEF.
Heres three logs. a map 1 at FOL 40 and two map 2's at FOL 40 and FOL 95 spraying 100% meth. Is my fueling really that maxed, or do i have an issue here?
Car: 2009 e90 335i
Default 10-08-2020, 02:08 PM
