VoIPNerd's Avatar
VoIPNerd VoIPNerd is offline
Car: 2011 335is
Default Boost drop in map 7 - 09-02-2020, 08:12 PM
Long time lurker here posting for the first time.
Just upgraded my lpfp to fuel-it stage 2, and loaded up with E60. After doing a few runs in map 5 which I've used exclusively since I got my jb4 about 4 years ago, I decided to try map7 since I now meet the requirements.
My map 5 runs looked good, boost right on target, but on map 7 it would never quite reach target, and start dropping pretty quick. My ff and wgdc were pretty separated. I set ff which had climbed to 140 or so down to 70, and reset octane, throttle, and lambda adaptations using the mhd app.
Those changes improved things, but I still see a big boost drop starting about 5500 rpm. I was going to mess with the duty bias but thought I should post here first.
Car is a 2011 335is, fbo, e85 bef, original stock turbos with 75k miles.
Afraid my wastegates are starting to go, but hopefully I'm just missing something in the logs.
VoIPNerd's Avatar
Car: 2011 335is
Default 09-02-2020, 08:16 PM
Log file attached
Default 09-03-2020, 09:49 PM
I’m assuming you are stock inlets?
That looks pretty typical of a stock turbo, stock inlet car.
VoIPNerd's Avatar
Car: 2011 335is
Default 09-04-2020, 06:25 AM
Yes, stock inlets with BMS intake, and that makes sense now that you mention it. Inlets are next on my list, so time to pull the trigger there I suppose.
Should I bother with any duty bias tuning at this point, or no?
Default 09-04-2020, 08:39 PM
You can try tweaking it a bit up top, but monitor WGDC. Imo once you get into the upper 80s or so upping the duty bias wont help much.
VoIPNerd's Avatar
Car: 2011 335is
Default 09-04-2020, 08:53 PM
I'll play with it a little to get a feel for how it changes things. Ordered new inlets today and they're scheduled to be here on Sunday! Guess I know how I'm spending Labor day this year.
Thanks for the assist, Dave!
2011 335is E93 with DCT
JB4 G5 ISO * BMS DCI * VRSF 7.5" Competition FMIC * VRSF dp's * VRSF Chargepipe * VRSF Inlets * Forge Motorsports Diverter Valves * Fuel-it Stage 2 Bucketless LPFP * Fuel-it Flex fuel kit * RB Turbo External PCV w/ plugged headports and Mishimoto OCC * NGK 2-Step Colder Plugs * MHD E85 BEF
Default 09-05-2020, 10:33 AM
Sounds like a decent weekend.
Post inlet install, throw up a log in map 1, with your duty bias settings at default (50 across board).
Will make sure all looks okay & we can start turning it back up
VoIPNerd's Avatar
Car: 2011 335is
Default 09-15-2020, 05:37 PM
Finally got my inlets installed. That rear one was a real pain, but it's on.
Here's a log in Map 1, but I forgot to reset my duty bias down on the upper rpms. Looks like it tracks pretty well, though.
Default 09-16-2020, 10:18 PM
Overall this looks solid.
Some minor timing corrections, but doesn’t look too bad.
LPFP looks to dip into the high 50s, you’ll want to monitor that
VoIPNerd's Avatar
Car: 2011 335is
Default 09-17-2020, 06:45 AM
Odd. I just upgraded my LPFP to the fuel-it stage 2 bucketless with the 450. Shouldn't it be able to handle this amount of ethanol (about E60)?
VoIPNerd's Avatar
Car: 2011 335is
Default 09-17-2020, 07:01 AM
Maybe that was an anomaly. Here is a run I did in Map 7 a little later, and the FP L stays above 60 in what should be a more fuel intensive scenario.
I am still seeing the underboost at higher RPMs in Map 7, although it does look a little better than before the inlets. I have the wastegate adaptation turned on, and today FF has climbed to 97. Should I try tuning the DB without the adaptation?
Default 09-17-2020, 06:13 PM
Up FOL to 80
Disable WG adaption, and drop the FF down to 70 or 80- then let's up your duty bias by 3, from 5.5k to redline.
VoIPNerd's Avatar
Car: 2011 335is
Default 09-28-2020, 04:35 PM
Here's a new log, with ff dropped and wg adaptation disabled. Wasn't sure what you meant by the duty bias setting, so I went up 3 for each 500 rpm over 5000. Anyway, everything looks pretty good to me except the increasing underboost as rpms climb.
Default 09-29-2020, 12:20 PM
I agree. Looks pretty clean.
The stock turbos aren't going to be able to hit that boost target, WGDC is pretty high.
Inlets may help a bit, but up top the stock turbos aren't super efficient.
VoIPNerd's Avatar
Car: 2011 335is
Default 09-29-2020, 12:37 PM
Yeah, that's what I was afraid of. Just put in the new inlets which was a minor improvement, but I guess my stock turbos are getting tired. Wastegates are rattling too, so may be about time for some RBs.
Thanks for the assist!
Default 10-03-2020, 06:00 AM
RB makes a really nice product.
I had his original stuff on my 335 back in 2013-ish, loved them.
Which ones were you considering?
VoIPNerd's Avatar
Car: 2011 335is
Default 10-11-2020, 08:16 PM
I am probably going to go all out with the game finishers. Those should easily meet my hp goals without a big single. Gonna have to save a bit tho.
