Jevsays Jevsays is offline
Car: C450 AMG
Default Map 3 log check - 05-27-2020, 02:07 PM
Running 93 oct on Map 3.
Thank you.
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 06-02-2020, 09:56 AM
Looks like something happened ariund row 10, your AFR/AFR2 spiked very high to 16, and you had Ignition retard. You also had another Ignition retard on row 14.
You may need to use better fuel or check plugs, or dial it back a bit.
Car: C450 AMG
Default 06-02-2020, 10:08 AM
Thank you for the response. My car has just over 31k miles. Always ran 93 octane and Map 2 was fine per Terry on my first log check.
I'll run it again on Map 2 (93 octane as well) if you don't mind checking it this afternoon.
Car: C450 AMG
Default Log Check - 06-03-2020, 08:28 AM
Can you check this log, please? Map 2, 93 oct.
LessIsMore's Avatar
Inner Circle Member
Default 06-04-2020, 04:36 PM
No problem. That makes sense that map 2 would have been fine, these are probably minor misfires from being slightly too aggressive tuning-wise. Droppig back to map2 is probably a good idea for now.
Can't really evaluated that one, You need to be full throttle for much longer.
Default 06-04-2020, 07:58 PM
Sorry late to the party. Been buried with work lately and sometimes miss posts like this. Thanks for filling in LessIsMore!
Fueling and fuel trims look good. I noticed it's on v3 firmware, might be worth updating to v6 as we made some minor improvements.
Car: C450 AMG
Default 06-08-2020, 08:22 AM
Thank you both for the replies! I've attached a log from this morning with the updated firmware - I believe it's on firmware 7 rather 6 as mentioned above unless I'm reading it incorrectly. Still Map 2 with 93 oct.
Should I test log Map 3 with 93 oct or not until I use a mixture with race fuel?
Firmware Version: 23/7//5
