BimmerFan BimmerFan is offline
Car: 2014 335i M-Sport
Default JB4 Firmware Update Fail - 02-28-2020, 08:18 AM
I need help updating the JB4 frimware. I tried both via blue tooth and using my serial to USB cable with no luck. The JB4 will not communicate with com port and firmware update bombs while trying to use the blue tooth connect kit. My car wont start now and I had it towed to a shop. I am about to rip this thing out of my car so I can start my car and continue with my life. Any help would be greatly appreciated. Thank you.
2018 C63s AMG
JB4 E30, Pedal Tuner
Default 02-28-2020, 10:57 AM
Sorry to hear about the headaches. A little info would have saved you a lot of time and the tow. To start the BMS data cable is a proprietary cable with different wiring than usual DB9 data cables. Only a BMS data cable can be used for the windows software. You can't just plug in any cable that looks like it might fit as it has no chance of working and may damage the JB4 electronics.
Hopefully that isn't the case here. Put back the JB4 mobile adapter. When you connect via JB4 mobile it should recognize there is no firmware and prompt you to load it.
Since you clearly have a signal strength issue for updates make sure ignition is fully on (all lights showing in dash), phone wifi is off, upload time out changed to 25, and phone sitting close to JB4 system under the hood. That usually does the trick.
Did you see the JB4 mobile FAQ for firmware updates? https://jb4connectkit.com/troubleshooting/
PS. Next app revision will have more detailed troubleshooting information on firmware updates within the app.
Default 02-28-2020, 05:42 PM
Thanks Terry. After several tries with your suggestions above. The firmware write to the JB4 was successful. The car started right up. Is there a reason the C63 JB4 wont clear codes and quench the CEL? That wasn't an issue on my N55.
2018 C63s AMG
Default 02-29-2020, 04:58 PM
You mean passive delete? Outside the USA that option can be selected. If there is an active problem usually codes won't delete so it depends what the code is specifically.
Default 02-29-2020, 05:46 PM
Thanks Terry. So after the firmware update, certain gauges stopped working. The needles are simply frozen and don't display data. The boost and the map selection display seem to be the only I can get to work. Please advise.
2018 C63s AMG
Default 03-01-2020, 04:24 PM
OBDII cable loose it sounds like?
Default 03-01-2020, 04:45 PM
Re-seated the ODBII connector. The needles came back to life. All is well again. Thanks.
2018 C63s AMG
Default 03-01-2020, 04:59 PM
Here is screen shot of the codes I was trying to clear. This is what prompted my trying to update the JB4 firmware. The codes did not clear at the time and the CEL stayed illuminated.
2018 C63s AMG
Default 03-01-2020, 06:42 PM
Codes seem to point to a vacuum leak of some sort. To clear codes ign on, engine off, usually.
VipinLJ VipinLJ is offline
Default 03-26-2020, 03:38 PM
Totally OT but if the Jb4 firmware fails to load onto the jb4 for some reason and prevents the car from starting, wont removing the jb4 completely from the car revert the car back to stock and start again? Or will the car still not start after the jb4 unit has been removed from the car?
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
2016 BMW X3 xDrive28i
Default 03-27-2020, 03:10 PM
Removing the JB4 would revert the car to factory operation.
Default 03-28-2020, 03:56 PM
Thank you very much. Thatís all I wanted to know
Current:
Skaura23 Skaura23 is offline
Car: 2017 c43 amg
Default 06-23-2020, 06:50 AM
To update the firmware, am I to have the car fully on (foot on brake and push start) , foot off the brake and push start once or foot off the brake and push start twice?
Default 06-23-2020, 09:14 AM
All lights in dash, engine off... Engine sensors have to be powered up so JB4 can power up.
