OldManSedan OldManSedan is offline
Car: 2009 535i
Default BMS Charge Pipe Challenges (535i) - 01-19-2020, 10:58 AM
Hey everyone,
I've spent a decent amount of time searching but never posted.
This thread is a bit of a call for help but also to document my install challenges and help someone else down the line. The 5 series does not enjoy the same wealth of parts and information that the turbo 3 series cars do.
As someone who can't leave well enough alone, I decided to pick up a Burger Motorsports charge pipe for my E60. I consider them one of the more reputable companies out there. I expected a somewhat painless install, but ran into some major clearance issues.
I have photos but Photobucket is currently down. Will try to update asap.
Quality is great, and all hardware looks like something I'd want on my car
Install is where the trouble comes in. Because of the wider bend radius and tubing OD, the charge pipe interferes with my power steering lines and the reservoir. Even with the reservoir bracket removed, I can't maneuver it to a place where these lines aren't getting squeezed by the charge pipe.
Has anyone made it to the other side of this install? I'd like to know what I'm missing here. The only solutions I see are
A: extend the lines and move the reservoir
B: put a big old dent in my nicely finished charge pipe
Input and insights greatly appreciated
Car: 2009 535i
Default 01-19-2020, 12:01 PM
Note:
Charge Pipe ordered is e60 specific for n54 cars
Diverter valve fittings are clearly in the 5 series specific locations, but I seem to be SOL on clearance. I can't tell if this pipe was made with the wrong bends or if the sport package reservoir is dramatically different on size/line routing
Car: 2009 535i
Default 01-19-2020, 01:10 PM
Update photo 1
Car: 2009 535i
Default 01-19-2020, 01:11 PM
Update photo 2
Car: 2009 535i
Default 01-20-2020, 08:52 AM
Quick update. I've been told by customer service that a tight fit is normal, and to install this as-is.
​​​​​​​I believe the motor will torque away from these lines under acceleration but I still need at least some clearance here to daily/track the car. I don't believe in leaving things like this to chance, so next update will be me massaging this cp for appropriate clearance. With the lines half closed when installed, I have some work to do.
Default 01-21-2020, 04:49 PM
Yes the E60 is a tight fit but that's how it has to be to retain a full 3" pipe.
Car: 2009 535i
Default 01-26-2020, 04:09 PM
I can understand it's a tight workspace, but my understanding is all of the problems I've run into are because this is an e9x design applied to the e6x platform. My power steering interference is in an area where the 3 series has no lines or reservoirs
I'll say that I appreciate the company. This is a jb4 car, and I just installed a BMS oil catch can while replacing my valve cover gasket. Unfortunately this charge pipe is not the plug and play solution I expected it to be, and requires real modification to fit to the 5 series. If I had known this when buying, my tone would be different
Car: 2009 535i
Default 01-26-2020, 04:15 PM
Pictured is the minimum modification I was comfortable with to clear my power steering reservoir and reduce compression on the ps lines. This made install 10x easier, and I didn't have to crush the lines to get the charge pipe over the throttle body.
Again, all hardware is stout and holding 13psi without issue. However, this product could stand to have it's own bend profile and be more e60 specific than relocated diverter valve connections.
Vehicles without the sport package may have an easier time, but this is my experience. I hope this helps other owners looking for a charge pipe
Default 01-27-2020, 07:07 PM
Looks fine to me there if that makes you more comfortable with the fitment.
graphiteE82's Avatar
graphiteE82 graphiteE82 is offline
Car: 08 135i
Default 03-14-2020, 01:38 AM
That is a lot of fidgeting around with a damn charge pipr
@e82n54 -- 11.3@122 -- stock turbos, stock exhaust, stock suspension
Car: 2009 535i
Default 03-15-2020, 12:29 PM
Yeah I just wasn't very confident with how much I had to press on the ps lines just to test fit it. It wouldn't slip over the throttle body without a lot of muscle on the lines.
Not perfect but much easier to work with now
coolbluestreak coolbluestreak is offline
Car: 2010 E61 535I
Default 03-24-2020, 01:02 PM
That's to bad, mine fit's perfectly.
I would buy again.
Car: 2009 535i
Default 03-24-2020, 02:48 PM
I would buy again.
Does your car have active power steering?
