Jroms135's Avatar
Jroms135 Jroms135 is offline
NFITY5
Car: 2011 135 6spd
Default Largest rim/tire combo on a 135i - 02-25-2019, 12:59 PM
So I have the stock 18" wheels. 215/40/18(front) 245/35/18(rear) After installing ******* **, CP, 7" FMIC, GFB dv+, & JB4 I notice the traction light A LOT more. Looking to putnwider rims thus wider tires. Was considering going 8.5 w/235/40/18(front) and 9.5" w/265/35/18 Curious as to if these will even fit. Any help/thoughts would be greatly appreciated. Thanks fellas 🏎🏎🏁🏁
jymmijamez's Avatar
jymmijamez jymmijamez is offline
Car: 2009 BMW 135i
Default 04-04-2019, 02:25 PM
I run 245 and 265 for front/rear. I also have a complete M3 suspension components for my 135. I also have an aggressive fender role in the rear and still rub over high speed bumps. Currently running Federal 595 RS-RR tires, and Vorsteiner 18" VFF-108 , 18x8.5 ET40 front and 18 X 9.5 ET42 rears.
If you want to run even wider tires I would suggest wider front fenders from ER and fender flares with some cutting for larger tires in rear.
2009 Space Grey 135i 6MT - FBO Phoenix Intake PFS Stage 4 and PI w/ JB4 MHD BEF VTT GC Lites MFactory Limited Slip - Trebila Tuned -- 534hp 488tq (uncorrected for Mile High elevation)
eligard eligard is offline
Car: 2007 335i
Default 04-28-2019, 11:54 AM
What size combo did you end up with? We'll be working on buddy's 135i soon right after we finished installing the new brake kit and mickey thompson tires plus led light bar wiring on the current truck project. He wants a beefier tire set up.
jymmijamez's Avatar
Car: 2009 BMW 135i
Default 05-17-2019, 11:08 AM
The fronts should be fine but the rears will rub, and it does get annoying with the tires hitting the inner fender liner.
The best options is to get a LSD for the rear-end. I only lasted about 9 months with limited driving on previous tire size. I got a puncture and tires were causing odd vibration similar to out of balance at speed. All the tires checked out for balancing but after puncture and seeing the wear on inside of rears I decided to go down 10mm after getting new tires.
I'm now running 235/40 and 255/35 and much happier.
