Go Back   N54Tech.com - International Turbo Racing Discussion > General > DIY Modification
Reload this Page How to install INPA, NCSEXPERT & other BMW Tools in under 10 Minutes !!!
Pat_62400's Avatar
Pat_62400 Pat_62400 is offline
Car: 07 335i e90 jb4, jb4 bef via mhd, wavetrac lsd, spec stage 3+ clutch & spec steel smfw, bmw occ,
Default How to install INPA, NCSEXPERT & other BMW Tools in under 10 Minutes !!! - 01-11-2018, 01:08 PM
Hey guys so after about 1 week of research on why my vehicle speed plausibility code came up, i got alot of feedback from people on here telling me to use INPA to test my wheel speeds... sadly i tried and tried to find links and watched people's youtube videos on how to install INPA but found no luck... i was about to give up until i remembered when i ordered my K+DCAN cable a month ago from BimmerGeeks.net i remembered a link on their site for BMW Tools... i went on their site and found that link... followed the steps and BOOM !!! i got it !!! i searched all over the internet... all over google and bmw forums and was unable to find anything that worked or that was even semi-helpful... so i decided for the people going through the same troubles as me or even want to download INPA to check other vehicle things such a Vanos, Injectors, timing and all the rest of the advanced stuff you can do with INPA... you also get NCSEXPERT which allows you to code your car with multiple cool features such as making your halos your DRL's and virtual speedo & much more... so here is the link to my video and i really hope i can help you guys out as much as some of you are helping me with my "new" 07 335i !
https://youtu.be/mfRXHhCo_Qw
07 335i 6SPD, FBO WITH VARGAS GC LITE 2.0'S, JB4 + MHD PUMP BEF
keyap keyap is offline
Car: N55 135i
Default 01-17-2018, 02:42 PM
Thanks for taking the time to pull this together.
Is INPA the full English version?
[B]
Pat_62400's Avatar
Default 01-17-2018, 02:51 PM
Sadly there are some parts still in German although the english scripts did pop up, if theres any advanced ways to get it full English id love to see it, but this will guarantee you to get it working, i have used it a few times already, sadly i downloaded it to check my wheel speeds cause i have a annoying P0503 code (vehicle speed plausibility A, erractic, high indication) i checked my wheel speeds and all matched up... So im not sure what to do... I know theres a wire plugged into the back of the manual transmission but i cant find anything if thats the main sensor which my mechanic said to check that and replace it...
suspenceful's Avatar
Car: 2008 BSM 135i
Default 01-17-2018, 02:56 PM
I've been putting this off forever. Thank you for this! I will follow and install this weekend.
Pat_62400's Avatar
Default 01-17-2018, 02:58 PM
No problem ! Glad i can help you out !
Car: N55 135i
The most complete version I saw was by using an up to date INPA but importing 5.02 scripts. You then need to find another work around though for MEVD172 (If you have an early N55!)
[B]
Pat_62400's Avatar
Default 01-17-2018, 03:05 PM
Sounds a little above my knowledge lol but i just used Google translate for some of the things and it worked fine !
mj888 mj888 is offline
Car: 2010 535I
Default 05-05-2020, 07:50 PM
it"s unavailable.
lcvette's Avatar
lcvette lcvette is offline
Default 08-21-2020, 01:19 PM
yes video is not longer available
bmweurotuning's Avatar
bmweurotuning bmweurotuning is offline
Car: Bmw 335i ST
Default 09-12-2020, 09:38 PM
Bmw Coding Ncs expert winkfp Correct Settings. - YouTube
WEBSITE: http://www.bmweurotuning.org
FACEBOOK GROUP: https://www.facebook.com/groups/657429951109356/
INSTAGRAM : https://www.instagram.com/bmweurotuning
YOUTUBE CHANNEL:https://www.youtube.com/channel/UCQi...u2MWT7P2ZYus5g
http://bmweurotuning.org/store
http://bmweurotuning.org/videos
For more info on jb4 products for your turbocharged bmw click here:
http://www.burgertuning.com/
