AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 02-19-2016, 03:08 AM
It did bring my car close to stalling and at times felt similar to a misfire
jwalker87 jwalker87 is offline
Car: 2008 335i
Default 02-19-2016, 06:22 AM
Just like a lopey cam should feel! Cool. I'm interested to see what the PE-mod/Ghost-Cam combination sounds like on mine.
2008 e90 335i sport pkg - JB4 G5 ISO w/ MHD BEF - BMS: DCI, OCC, LED angel eyes - VRSF: 7" FMIC, *** - PE exhaust mod - LED fogs - Shifteck shifter - Apex EC-7 wheels
2011 e90 335i xdrive M-sport pkg - JB4 ISO w/ BMS BEF - BMS OCC - LUX LED angel eyes - VRSF DP - LED fogs - AFE Scoops - 12/15mm spacers
idratherbesurfing's Avatar
idratherbesurfing idratherbesurfing is offline
Car: 06 STI
Default 02-19-2016, 06:24 AM
This blows my mind everyone is having good results execpt me. My car sounds nothing like that and the knock noise is sketchy. I honestly don't even want flash that map back on to film the car idling but I guess I will have to.
AWSAWS's Avatar
Default 02-19-2016, 06:51 AM
Mine might be the same.
Straight after the jb4 flash to say the engine was warm I put the car in park. It nearly stalled and sounded like it had engine issues. After a bit more driving it still was quite lumpy. Then a couple of minutes after I pulled over and recorded it. At this point maybe 10 mins after the warm up light flashed it almost sounded like standard. There is a bit of bumping sound. Probably have to give it one more go.
Sound:
https://clyp.it/efbsfrne
Car: 2008 335i
Default 02-19-2016, 07:09 AM
Did you double check your .bin to the table from the first post to make sure you didn't make a typo or open the wrong table? Not doubting anyone's skills, but it's a reasonable place to start troubleshooting, since that's what was changed.
omarmarji's Avatar
Car: n54 335
Default 02-19-2016, 07:14 AM
FOUND THE PROBLEM!! ok guys editing the main post, extra step
751WHP 688WTQ
JP Works Kit Record
SOLD: E90 335i 751whp 688WTQ
omarmarji's Avatar
Car: n54 335
Default 02-19-2016, 07:19 AM
DONE! make sure you guys save after every step then save the bin file as a back up
751WHP 688WTQ
JP Works Kit Record
Car: 2008 335i
Default 02-19-2016, 07:48 AM
Interesting. What do the changes in timing accomplish?
AWSAWS's Avatar
Default 02-19-2016, 07:50 AM
haha, cool!
Definitely having another try now.
Thanks Omarmarji
omarmarji's Avatar
Car: n54 335
Default 02-19-2016, 07:55 AM
helps with the valve overlap and NP!
751WHP 688WTQ
JP Works Kit Record
AWSAWS's Avatar
Default 02-19-2016, 07:59 AM
yes I don't think i was getting that overlap sound...
omarmarji's Avatar
Car: n54 335
Default 02-19-2016, 08:02 AM
let us know how it goes!
751WHP 688WTQ
JP Works Kit Record
BostonBeemah's Avatar
Car: AW 135i
Default 02-19-2016, 08:24 AM
i could arrange this
Lets do it haha Ill be the guinea pig if you want.
Ran the ghost cam tune on my car since yesterday without the latest timing changes. Am I the only one with a SMFW and raised idle at 960rpm with this? Just sounds like a stumbling misfire haha Might have to lower my idle back down to get the "full effect" lol
RIP 2008 AW/BL 135i
Vogt.ryan's Avatar
Car: 2008 BMW 335i sport
Default 02-19-2016, 01:14 PM
Originally Posted by holtdahooligan
Just did it. Thank for posting this!
http://youtu.be/822atiJy6Y4
What exhaust is this?
holtdahooligan's Avatar
holtdahooligan holtdahooligan is offline
Car: 09 135i
Default 02-19-2016, 01:27 PM
It's custom. Originally it had a muffler but the baffles inside it broke. Now it's a muffler delete with an anti-drone pipe. ********* *** and secondary meow delete (<---made a huge difference).
FBO MT 09 135i w/ E60
Car: 2008 335i
Default 02-19-2016, 02:16 PM
This did NOT work on mine. About a minute after start, the car started bucking and sounding like it was falling apart. I know what a cammed car is supposed to sound/feel like, and this isn't it. It was extremely violent. Flashed back to the original Bimmerboost flash and all is normal. I verified the table modifications were according to the first post. Any ideas?
Car: 06 STI
Default 02-19-2016, 02:33 PM
Thats how my original one sounded.. unfortunately I know nothing about tuning or making adjustments to a car's computer but I'm just assuming if they're trying to copy what other platforms have done its just not working with ours
Considering I'm not the only one hearing these issues I'm not even going to record those noises I'm not going to flash this map until it's correct. It's not worth losing a motor over a silly idle sound, but when the maps are adjusted correctly I will be more than happy to use it
Car: AW 135i
Default 02-19-2016, 02:35 PM
Im wondering if its because your using the BB flasher as opposed to the MHD. What is everyone using? I am running the MHD.
RIP 2008 AW/BL 135i
Car: 2008 335i
Default 02-19-2016, 02:39 PM
Interesting. I'm actually going to switch over to MHD, and have my adapter arriving Sunday. I'll retry after I get that set up.
And for the sake of details, this was on the 021016 release of JB4_I8A0S_PUMP.
Car: 06 STI
Default 02-19-2016, 02:57 PM
Im on mhd alone currently
Beemin Beemin is offline
Car: 2007 e92 335i
Default 02-19-2016, 03:34 PM
Worked great for me. What you guys might be hearing is the throw out bearing in the clutch (if you have a manual, that is). Try pressing in the clutch and see if it goes away.
Sounds pretty cool but kinda impractical too. To each his own. Thanks to OP for sharing!
Car: 2008 335i
Default 02-19-2016, 03:51 PM
The entire car was shaking violently. Not the throwout bearing.
Car: 2007 e92 335i
Default 02-19-2016, 04:50 PM
O damn, no idea then.
Here's a quick clip of mine with *** and PE Mod:
http://youtu.be/Zinakw1eq5o
Edit- That is with idle min. set at 700 rpm through mhd.
Car: AW 135i
My car has been shaking too. Feels like a misfire. Im hoping the added timing helps smooth that out. If not I'm going to try to lower the idle but the rattle sucked before, can't imagine it will an inconsistent idle lol
RIP 2008 AW/BL 135i
omarmarji's Avatar
Car: n54 335
Default 02-19-2016, 05:13 PM
I guess it doesn't work for BB
751WHP 688WTQ
JP Works Kit Record
