(#1901)
thisismynick thisismynick is offline
Car: M240i xDrive Convertible (F23)
Default f/w v14 vs v17 Map3 vs old map4 vs Map0 - 10-11-2020, 06:24 AM
Map6 is meant for those familiar with reading their own logs. But maybe best next step for you is just to post a map3 log so we can check it out.
Thank you very much in advance for your support!
Please find several logs attached: 4 logs are v17, one of that is a Map0 for orientation, and 3x it's map3's.
I've also attached one old v14 Map4 and one old v14 Map0 log. (They were automatically generated I think. I dont recall to press a recording button or sth.)
My butt-meter says: In the past the car definitely felt quite more brutal when WOT, and it definitely felt stronger especially when not WOT but in all day partial throttle commute mode. That has on the spot changed with v17.
The car is ever running on ARAL 102 Octane german premium fuel, from the very same fuel station. I dont assume any changes coming from there. Everythin else is the absolute same with this car. No services in between etc. It is an xDrive 8 shift automatic 240i convertible LCI, built early 2018. It had the bouncing needle bug with v11.
If there is nothing else I can do to return to the old feeling, some simultaneously occuring error or something, I definitely wish I could go back to v14 :-/
Default 10-12-2020, 11:35 AM
Uh, am I in the wrong forum for that analysis...? Thought it was said to post it here?
Default 10-12-2020, 02:05 PM
If we're looking for half throttle differences we'd need to look at half throttle logs. But maybe next step is to test out map4 on the latest firmware. You can also load v18 firmware and set DWP = 100 to see if that offers any improvement for you on part throttle feel.
Do you have an EWG connector installed? If not that would also be very useful in boosting up lower end response.
Default 10-13-2020, 02:26 AM
Hi Terry,
1) Would you say the v17 map3 WOT logs I've provided look fine and normal to you, i.e. "as expected", especially in comparison to the old firmware logs? Me thinks the max boost is overall lower now?!
2) No, I got no EWG connector installed AFAIK, just JB4 and bluetooth module.
3) So I should check out map4 on v17 instead of map3, and do logs?
3) Would try the v18, but what does DWP=100 mean? Where would I set that?
Default 10-13-2020, 10:28 AM
DWP is a setting on the user adjustment page. After loading v18, set it to 100, and do a couple runs on map3 and map4 to see how both feel and look in logs.
M3fory M3fory is offline
Car: Bmw M340i
Default 10-13-2020, 10:19 PM
Hey everyone, I just installed bms intake along with a evolution racewerks ******* ********. Currently running map 2. My check engine light came on and I know it's obviously because of the o2 sensor. Since I have the jb4 installed what can I do to get rid of the check engine light?
Heusing240i Heusing240i is offline
Car: M240i Sunset Orange
Default 10-14-2020, 08:53 AM
Hey All, I have a few questions around my 18' M240i (B58B30O0). Currently set up with BMS CAI, 4.5" VRSF CTLSDP, and JB4 (V15-Map3) and it has been great. Time to increase my power though. From doing research and reading peoples updates, I'm not certain I have the answer i'm looking for.... Im considering the E85 mixture (e30) with NYS 93 octane.
*I dont have the EWG connector and wanted to know if I could run this without?
Also, I store my car for the winter and normally fill it up with 90 octane, ethanol-free.
*If I do this after running E30 - will it harm anything or will I be okay?
I recently took my car to get inspected - they said they updated the software due to a service recall or something like that. I feel that this was an ECU flash as when I got my car back all of my settings were wiped.
*If this is the case, do you think it would have wiped out the data of having a JB4 installed so would act as if the car was never touched?
Default 10-15-2020, 12:41 AM
Does anybody know why I oftenly (not always) find my latest logs never, or 1-2 days later, in the log section of the JB4 app?!
Sema_540i Sema_540i is offline
Car: 2017 540i
Default 10-18-2020, 11:15 AM
I installed my JB4 yesterday with the mobile connect kit. The mobile kit won't connect (not finding it in Bluetooth on multiple phones). I also can't seem to access the maps in the dash controls. The left turn signal stays lit but the speedo and rpm gauge do not move. The car definitely feels faster so I don't think there's a connection issue. Has anyone had similar issues? The car is a 2017 540i.
Default DWP=100 => recurring error & dashboard yellow engine symbol lighting up - Today, 02:06 AM
OK, I can confirm:
DWP to "100" instead of "0" much improved the throttle feeling, esp. in Map3 v18.
Map3 v18 w/ DWP@100 gives me the most satisfaction, over Map4 or I even tried shortly Map5 (with 102 Octane fuel)
And I'd say there is no substantial difference anymore now to what I experienced w/ old Map4 in v14, although I'd say Map4 v14 somehow felt more brutal, but can very well be Placebo. I'd really love to flashback to v14 to properly compare, but this seems not to be supported here? :-/
Anyhow, what I do have now is a recurring error in the codes and in the car's dashboard (yellow engine symbol lighting up, once a day or so now, needs to be erased in JB4 app). Code section in JB4 app tells me "ignore error, tuner code only", some valve pressure to high, or something)
Is it possible to eradicate that recurring error?
Thanks again
