(#1401)
Josie8888 Josie8888 is offline
Car: 335ti
Default 05-05-2020, 09:19 AM
Hi! Its my forst post here. Sorry for my english! There is someone using ONLY PI And delete the DI?
drdiabetes drdiabetes is offline
Car: bmw 335i e92 AT
Default Single turbo + stage 3 lpfp + PI bms controlled jb4 configuration. - 05-07-2020, 07:56 AM
Hello, I have a n54 335i ST 6466 with mhd flash and jb4 s4 lpfp and PI bms controlled.
I have read a lot and have found some diference in jb4 config and that gave me some confussion.
Fuel bias shold be set to 50 ( that is clear !!)
Fuel open loop: I saw that some people set it to zero. Why??
Meth safty mode and meth trigger mode should be at zero ??? ( I am not runing meth... just e85 with port injection and stage 4 lpfp).
Wmi settings:
Signal scaling should be 99 or 100?? What is the diference??
As I don't have hobbs switch I should enable external trigger ( option 1) and set rpms and min tps.
Am I ok??
What about ethanol set up?? Which options should I turn to ON?? I think it is 4 and what else??
Thank you guys.
335i AT 2008
DOC RACE 6466 SINGLE TURBO
JB4 G5ISO + MHD TUNING
FUEL IT PI kit BMS controlled
FUEL IT STAGE 4 LPFP
XHP flash stage 3
VRSF RACE EXHAUST
VRSF 7.5 FMIC
NGK SPARKS TWO STEPS COLDER
psixtc's Avatar
psixtc psixtc is offline
Default 05-07-2020, 09:24 AM
Wmi settings:
Am I ok??
Thank you guys.
I have an almost identical setup as yours, but with PR hobbs switch and am curious on the signal scaling and Fuel_OL too.
I have my signal scaling set to 99, but am still showing 0 in my fuelen column on the datalog when doing a pull (which then kicks the car into Map 1 due to a lastsafety-3).
Since my PI controller wiring all looks good, I will change the scaling to 100 and report back if there's any change in case you don't get a response before I try it.
For my Fuel_OL setting, the log is showing it at 80, so not sure if I should change it or not.
Evil1 '08 135i 6MT swapped with a few go fast bits...
Default 05-07-2020, 03:35 PM
Fuel open loop should be 0.
If you're not getting any signal then PI wiring might be wrong.
davisnapier davisnapier is offline
Car: BMW 335i xDrive
Default 05-10-2020, 09:26 PM
Any way to turn off or turn down PI & the secondary lpfp on a stage 3 with the jb4? Just wondering before I make the plunge to this setup with full e85 in the event that I'm not able to get e85 & have to fill up with pump gas. I would want those to not be running? Or do I need to get the flex fuel setup to control things? Thanks. & sorry if this has been asked, this thread is long.
Car: 335ti
Default 05-20-2020, 09:27 AM
No one?
lnxmad lnxmad is offline
Default 05-20-2020, 10:20 AM
No one?
Seems like it would be a pain.. you would need to seal the injector ports.. What benefits would there be by deleting DI?
Car: 335ti
Default 05-20-2020, 10:24 AM
Yeah, i know it would be a pain...
I ask about these seals, or if is posible leave this injectors just for seal, i plan to machine a "fake" steel injectors to seal the head.
Benefits? Deleting Injectors, HPFP, and have a clean intake valves.
Why? I am planing a swap on a e46, and there is more easy manage the engine with a standalone without DI.
Default 05-20-2020, 11:08 AM
I know this was done with a 2020 Supra build. They left the injectors in place and the injectors basically exploded due to heat.
I always thought DI was more efficient at fuel delivery. I wonder what would be needed of LPFP and PI alone to manage AFR.
That's going to be one hellofa e46..
Car: 335ti
Default 05-20-2020, 11:10 AM
Yeah, but supra 2020 (B58) injectors are not full steel, you talk about papadakis right? N54 injectors are full steel.
