Edyuly's Avatar
Edyuly Edyuly is offline
Default 11-23-2011, 03:49 PM
does anyone have any pics of the system in there car so the newbys have a better . understandings .
mykal335xi mykal335xi is offline
boom
Car: BMW
Default 02-18-2012, 11:49 PM
Not having any luck with the wiring, everything works fine except the JB4 side of things. That is to say, I've wired up the relay to the solenoid, with everything connected except the ground. If I close ground manually to the frame the solenoid fires, but when the JB4 setup is attached to the relay's ground and map 20 is coming up on the laptop logging I get nothing.
My setup from the JB4:
-wire from JB4 soldered to one end of resistor, other end of resistor soldered to first pin on digikey semiconductor.
-middle pin on semi-conductor soldered to wire going to ground post on relay
-last pin on resistor soldered to wire going to chassis ground
I thought maybe my wires were too thin so I just re-did the whole setup with 16ga wire but still no luck. I did a voltmeter test, and when map 20 is on there is current coming out of the JB4 (250mv?) but it drops a ton after the resistor. I'm wondering if maybe I bought the wrong resistor, it's listed as 1k ohms but I don't remember the watts.
I was tempted to just wire it up to a switch in the cabin to see what the nitrous did, but I would really like to have it tied to the JB4.
Anyone have any ideas on what I'm doing wrong, or something I can test to try and zero in on the problem?
2011 335i m-sport
2008 335xi (Sold)
chuckd05 chuckd05 is offline
Car: 08 135i , 06 325xi e90
Default 05-04-2012, 01:36 AM
Do you need a 4 or 5 pin automotive relay ?
e92
Default 05-04-2012, 01:38 AM
And I'm just a little confused on the wiring side of the relay. Can anyone give in better detail which post connects to what on the relay ?
e92
boom
Car: BMW
Default 05-04-2012, 05:04 PM
I just used a standard guide to wire the relay, just do a Google search as most automotive 30 AMP relays work the same. Worst case just use some alligator clip wires to test it out and you can see for yourself how it operates, it's pretty basic.
The part I could never get to work right is the JB4 trigger wire using the semi-conductor to close the ground portion of the relay. Until the BT board comes out I'm not running nitrous, since myst has a BT board hopefully that is soon. I had assumed Shiv would be into the 10s already, would be pretty funny if a FBO+Meth+Nitrous 335xi beat him to it
2011 335i m-sport
2008 335xi (Sold)
aflatau aflatau is offline
Default 05-13-2012, 10:43 AM
bump - so how many of you are running n20? how long have you been running it? any issues so far?
Car: guess...
Default 07-02-2012, 08:55 AM
Has anyone tested and proven this to work yet? How did you set up your JB4 methanol tab in the software? I'm thinking a simple old boost switch from ebay would be just as effective.
strayman strayman is offline
Car: bmw 335i
Default 07-31-2012, 06:53 PM
sorry but if the cps is -2 degrees when you run without n20 the car lost power, or you change te cps value for only turbo?
crisart's Avatar
crisart crisart is offline
Car: 135i n55
Default 01-02-2013, 09:07 PM
Is this the same for the jb4 g5 board ? Or do you use the two step relay wiring
Default 01-04-2013, 11:17 AM
All obsolete now, was for G4 board only.
crisart's Avatar
Car: 135i n55
Default 01-04-2013, 11:19 AM
Can we use both 2 step and nos
Nope.
Boosted-m Boosted-m is offline
Default 03-15-2013, 05:07 AM
Do you have a dyi for the g5 board?
335XI 6AT
AR Design 3" *** less DP's | ER Competition Series FMIC, Charge Pipe & Tial Q BOV | BMS DCI | E85/93 | Aquamist HSF-4 100% meth| Walbro LPFP | JB4 G5 ISO | Cobb AP with Custom BMS Flash | KW V3 | 19" OEM E92 M3 Wheels | M3 Suspenion Bits | NX Express
viana 135i viana 135i is offline
Default 03-23-2013, 06:51 AM
The nitrous setup will work on n55 ??
I really want to run on that setup
marconi118 marconi118 is offline
Default 10-27-2013, 07:50 AM
is the nitrous output on the G5 using the NLS output on DB9 or the processor pin 11 as on G4 board
Default 10-28-2013, 02:14 AM
This
Ed_Z Ed_Z is offline
Car: 1M
Default 03-14-2014, 02:14 PM
Could someone send me/ us the DIY nos wiring on a JB 4 G 5 please? Many are asking but seems we not getting anywhere with this?
Car: 1M
Default 03-14-2014, 02:16 PM
Do you leave the 2 step as is and change nos solenoid ground to / step only?
Do you use 2 step clutch wire straight to solenoid and other side if solenoid ground?
Or???
Car: 1M
Default 03-16-2014, 02:01 AM
Anything or anyone else know the wiring?
NJz NJz is offline
Default 03-31-2014, 03:42 PM
Bump need some help here with the JB interface side of things. PM me if you do not mind answering a few quick questions.
Foacad Foacad is offline
Car: 2012 BMW 135i
Default 07-21-2014, 01:46 AM
Also in the N55 and looking for info boat.
Abacus38 Abacus38 is offline
Car: 2007 6spd 335i
Default 04-05-2015, 10:28 AM
Bumping this for a quick question. If you position 7 for n2o integration then you lose No lift shift and 2step correct?
e90tiag335i e90tiag335i is offline
Car: 2010 335i
Default 04-16-2015, 08:41 AM
Correct
JB4, PT5858 ST, 3.5" exhaust, VMR V710, KW V3 coilovers, Wavetrac LSD, AKG subframe and diff bushings- Hybrid Ovations, Jehnert Doorboards, IDMax15 and 2 Arc Audio 1200.6 amps, white gauge cluster
603r6 603r6 is offline
Car: 09 335xi
Default 05-19-2020, 04:14 AM
Terry will this stop nitrous from flowing between shifts? I have the two step relay and typically do not let off the gas between gears
Default 05-20-2020, 08:43 AM
Once you get it wired up send a log and let's evaluate. It's been awhile since I looked at the N20 logic carefully!
