iversoncreative's Avatar
iversoncreative iversoncreative is offline
Car: 2008 535xi
Default Advice for newbie getting first dyno - 10-10-2020, 09:47 AM
So, I’m getting my first dyno tonight. My current mods are in my signature. I’ve got an MHD BEF coming, as well as a DCI, but they won’t be here for another week or two.
Again, I’m a total newcomer. Any tips or advice on how to make the most of this?
ANSWER
For anyone looking for the answer, here is a post from Terry.
How to dyno your car - N54Tech.com - International Turbo Racing Discussion
This is what I've got from the dyno tech. Check the following:
□ No fluid leaks (Leaking fluids can damage electronics under the dyno, and cause traction issues)
□ No check engine light or ECU codes that may affect drivability or tuning
□ Ride height is adjusted, or front and rear bumpers are removed (for clearance on to lift, and to have room to securely strap the car down onto the dyno)
□ Check fluid levels - oil, coolant, transmission, power steering, etc.
□ Check for compression, vacuum, and/or boost leak
□ Tires have adequate tread, no traction issues (including due to camber)
□ No exposed wires. All connections soldered or butt-connected
□ Battery and alternator in good working order and producing adequate voltage
□ Identify strap-down points, ensure they are not obstructed or exposed to heat from exhaust, wastegate, or pinch points
2008 535xi
JB4 w/Connect Kit BMS BEF 7.5 Stepped Competition HD FMIC Dual Cone Intake NGK 2 Step Colder Spark Plugs New OEM Turbos
brendan's Avatar
brendan brendan is offline
Brendan
Car: 335i 2007 6spdman
Default 10-10-2020, 07:02 PM
Dont go Save your cash and get some parts.
Car: 2008 535xi
Default 10-10-2020, 07:48 PM
Right? But I wanted baseline. Here's what I put up. Something happened at the dip and wound up with a couple of codes.
2008 535xi
dmckmc dmckmc is offline
Car: E60 535i
Default 10-15-2020, 01:04 AM
N54
FBO
E40
JB4
MHD
XHP
Car: 2008 535xi
Default 10-15-2020, 01:24 PM
Bingo! Thanks!
2008 535xi
