Roma_335i Roma_335i is offline
Default Need help after stage 3 lpfp install - 07-12-2019, 09:37 PM
Hey guys, I have bean searching all day can't find no info on what I am looking.
I just installed stage 3 lpfp bocketless, before this I had stage 1 lpfp and car was runing perfect. Now after the stage 3 install I don't hear the pump priming and car won't start it wants but wont. I have a friend with a 335i so I swaped his ekpm3 module and same thing. I swaped back my stage 1 lpfp and same thing car won't start and I don't hear the pump turning on. The fuel level works on stage 3 and stage 1. Can some one give me any advice or maybe you had this happen.
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 07-13-2019, 02:15 AM
Not sure, but possible blowen fues check your glove box fuse I believe it's a 20 Amp fuse that could be blowen.
Default 07-13-2019, 06:10 AM
Hey thx for reply, I did check all the fuses and they are all good. Will look one more time.
Xtremestang351 Xtremestang351 is offline
Car: 2011 BMW 335xi n55
Default 10-10-2020, 11:06 AM
I realize this is an old thread but did you ever figure out what that problem was? I'm having about the same issue after installing a fuel it 650hp pi kit. Lpfp worked fine following pi install. After secondary pump install, I no longer have power to lpfp. I have been emailing steve about this as well and he's been good about answering questions. I'm just at a loss here. I am new to this forum so if this post is in the wrong place I apologize. Just trying to figure out my issue here. Thx.
