eaton18spd eaton18spd is offline
Car: 2008 535xi
Default High battery drain after update - 06-25-2019, 09:52 AM
Tried to post this in the support section but did not get any response at all so I'm going to try here.
I updated the firmware on my jb4 and right after that I started getting high battery drain warnings every time I start the car after it sits several hours. The car starts fine and the battery is not going dead, also the battery is not very old. I did not have this problem until I updated the firmware on the jb4. I did not have any issues with the update and everything seems to be functioning fine, just the annoying warning every time I start the car. Any help with this will be greatly appreciated.
Default 06-25-2019, 10:55 AM
Don't see how it would be related but easy to roll back to previous firmware to confirm.
Fredm21 Fredm21 is offline
Car: Bmw 335i 2007 N54
Default 06-25-2019, 11:49 AM
Did you replaced your battery with the same as before? Did you registered your battery after replacing it?
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
BMS WMI with single nozzle ( 10 )
JB4 map 3 w/bluetooth & antiliag
Afe intake filter
BMS intercooler
BMS tranny cooler
BMS Double baffle catch can
MHD BEF Racegas
Precision Raceworks Coil
-Running 91 octane with WMI
Default 06-25-2019, 01:09 PM
Is there anything plugged into the OBD port, or anything else installed recently that would draw?
Car: 2008 535xi
Default 06-25-2019, 06:58 PM
Bigger battery, coded and registered. Everything was fine up until I updated.
Car: 2008 535xi
Default 06-25-2019, 06:59 PM
Nothing plugged into the obd port. Nothing else has changed except for the update.
Car: 2008 535xi
Default 06-25-2019, 07:00 PM
Where can I find older firmware?
Default 06-25-2019, 08:21 PM
32_12 still posted- scroll to bottom
N54Tech.com - International Turbo Racing Discussion - View Single Post - E Series N54 JB4
Car: 2008 535xi
Default 06-27-2019, 07:46 AM
I flashed back to the other firmware that is posted. Did this last night and this morning when I started my car, no battery warning.
sdimezq8 sdimezq8 is offline
Car: 2007 335xi, 2011 335i
Cool I am having a similar issue... - 06-03-2020, 04:09 PM
Hello,
I also upgraded from a previous version to G5_ISO_32_14 and am having battery drain issues. Where can I find G5_ISO_32_12, I don't see it in the new database?
-Mike
Default 06-04-2020, 07:30 AM
Here: E Series N54 JB4 - N54Tech.com - International Turbo Racing Discussion
Should be having that issue, make sure your battery isn’t actually shot lol
florida2002m3 florida2002m3 is offline
Car: E60 535i
Default 09-03-2020, 02:34 PM
I had the same problem. Did all the normal troubleshooting. The voltage of the battery was actually going down overnight, IIRC it was about 0.75V over 12ish hours (numbers are written down somewhere)
Battery was 5 years old, so replaced anyways. Problem persisted.
Rolled back FW to 32_12. Problem went away. If I get fiesty I may try 15 and see how its goes.
2010 535i, 6mt, 80k miles, BMS DCI, JB4 G5, BMS WMI (CM10), VRSF Inlets, VRSF **, ETS 5" FMIC, VRSF CP/HKS BOV, Walbro 450, E85 BEF, E50.
2011 535i, 6mt, 1000k miles, BMS intake, JB4, VRSF **, muffler delete.
Default 09-03-2020, 09:54 PM
Give 15 a try, genuinely curious
bmwboyee bmwboyee is offline
Car: 2007 335
Default 09-15-2020, 11:33 AM
Reporting as well. Flashed the newest firmware and have battery drain issue. I'll roll back to 12 and see if it continues. Hopefully not.
Car: 2007 335
Default 09-21-2020, 05:28 AM
I tried the link above and could not find the download of firmware 12. Only 14 and 15. Can someone point me in the direction?
Bbelstad's Avatar
Bbelstad Bbelstad is offline
Car: 08 E60 535i
Default 09-24-2020, 04:01 PM
I too can only see 32-14 and 32-15 in the useable database. I can read all about 32-12 in the link but can't download it.
Can someone please show us where an actual 32-12 is at? Uploaded latest 14 and having battery issues the same as above. Started on the first start up of the car after new firmware loaded.
Brandon
Hayden, Idaho.
* 08' 535I. * JB4 W/ Bluetooth Connect & custom tune. * Billy Boat 535I 3.5" *****-back exhaust W/ resonator delete. * BMS DCI. * NGK 2 step colder plugs @ .020" (And I mean .020" on money!). * New Eldor coils. * BMS BOV adapter and BMS Vac side OCC. * BMS Chargepipe. * TIAL BOV W/ Hard 1/4" Vacuum line W/stock spring. * XHP Stage 2 * C-@-T TUBES.
[/SIGPIC]
Bbelstad's Avatar
Car: 08 E60 535i
Default 09-24-2020, 04:19 PM
Gave 15 a try and having same battery drain issue as 14. Can't find 12 anywhere either. Like the download link is gone? I can read about the -12 in the revision history but can't actually download it. Can you plz point out its location as the link provided about doesn't let us download it.
Thanks much!
Brandon
Hayden, Idaho.
[/SIGPIC]
iversoncreative's Avatar
iversoncreative iversoncreative is offline
Car: 2008 535xi
Default 09-29-2020, 07:04 AM
Same issue for me on 15. Dropped back to 14 and it went away.
2008 535xi
JB4 w/Connect Kit BMS BEF 7.5 Stepped Competition HD FMIC Dual Cone Intake NGK 2 Step Colder Spark Plugs New OEM Turbos
Car: 2007 335
Default 09-29-2020, 07:10 AM
Why can't we find the 12? I have sent a ticket to burger with absolutely no response. This is frustrating.
lnxmad lnxmad is offline
Car: 335xi
Default 10-09-2020, 06:49 AM
Also getting dead batteries after about a week of sitting (garage queen).
I installed sub/amp and thought it was that, though the amp appears to be shutting off after car enters sleep mode.
Also have port injection w/controller & fuelit bucketless pump.
Using 15 beta
Now that I'm seeing this post I'm wondering if it's related.
blown07's Avatar
blown07 blown07 is offline
Car: 335xi, 335i
Default 10-10-2020, 10:17 AM
I found 32_12_T10 on my phone that I may flash back to as I'm having the same issue. I can also send this to anyone who wants it.
335i FBO,Meth,JB4,Sutphin flash,LSD,GCLites 11.25@127.4 on NT05R
335xi FBO,Meth,JB4,Sutphin flash,VTT stage1 11.38 1/4 - 7.30 1/8th - 3.35 0 to 60 @ 0C
