Memo Memo is offline
Car: Bmw n54 335i 2009
Exclamation My logs for terry - 07-10-2020, 05:03 AM
I have 335 n54 2009 jb4 g5 iso mhd backend flash bef race dual cone intec bms ******* vrsf intercooler vrsf vrsf exaust Street map sensor 4 bar charch pipe vrsf tial blow off bms methanol sistema cm 10
Default 07-10-2020, 06:55 AM
Enable 6 cyl timing under user settings
What fuel?
Timing looks like it drops a bit mid pull
Exclamation 07-10-2020, 03:23 PM
What fuel?
In number 5 enable 6 cyl timing under user settings ok?
I use pump 93 oct and methanol 70 30
Default 07-11-2020, 05:43 AM
The cylinder timing value correlates with your DME- so just match your DME, with the value assigned
Get that enabled & relog
Default 07-23-2020, 04:35 PM
This is the New logs with 6cc in number 5 in jb4
Default 07-23-2020, 05:09 PM
Logs
Default 07-23-2020, 05:13 PM
New logs
Exclamation 07-23-2020, 05:40 PM
Fail to send I kent the logs
Default 07-23-2020, 07:49 PM
I don’t see any logs?
Default 07-24-2020, 06:58 AM
Default 07-24-2020, 07:02 AM
I have problems sending my logs, I don't know what happens, I don't attach the record, I only send the message, sorry, any suggestion, please
Default 07-24-2020, 07:55 AM
Default 07-24-2020, 08:33 AM
Email in to support@burgertuning.com as this thread isn't working.
Default 07-24-2020, 08:39 AM
Ok terry thanks
Default 08-23-2020, 02:45 PM
Logs
Default 08-23-2020, 03:16 PM
Hello, send these previous logs to support@burgertuning.com and they tell me that I have to buy my low-pressure fuel pump stage 2 and I bought it, I'm just waiting for it to arrive these days to install it, I have to do something else, some programming to the module ekp after installing it and heard something about a fuel pump code that appears in some units n54 or just installed the fuel pump stage 2 without doing any programming I hope you can help me or give me some information about that since this is new for me ,Thank you
Car: 2008 E93
Default 08-23-2020, 11:14 PM
Just install it. Should be pnp.
Default 08-24-2020, 06:43 AM
Just install it, our LPFP's are PNP / drop in ready.
Some have had issues, but most do not. I wouldn't worry about it, unless it actually happens.
Default 09-30-2020, 05:13 PM
I already installed the fuel pump stage 2 these are my new logs but this is static my fpl in 48 does not move it is the same as when I had the oem fuel pump
Default 10-03-2020, 06:05 AM
when the LPFP value stays pegged like that, your :LPFP sensor looks to be shot.
Default 10-03-2020, 12:41 PM
Will I have to install a new one? If so, I have seen two types of sensors, one oem copper color and one from the bosch brand, which of the two do you recommend?
Default 10-05-2020, 06:58 AM
Either work.
