A90supra A90supra is offline
Car: Supra
Default A90 Supra WMI Initial Setup - 09-15-2020, 07:01 PM
I've got a JB4 and recently installed the water methanol kit and EWG harness. I updated the firmware and it auto-filled the parameters in the pictures I have attached when I loaded map 7. I haven't used it yet because I'm sure some of these settings need to be added/changed. I have purged the line but that's it. I'm using a single BM10 nozzle sprayed into the charge pipe and using Boost Juice 50/50. Where should I start? Any help would be appreciated.
P.S. I have an Armaspeed intake and a catted ******** if that makes any difference.
Car: Supra
Default 09-16-2020, 09:36 PM
@Terry @bms any help?
Default 09-17-2020, 01:21 PM
Sorry been swamped with a building move so behind on forum posts. For faster support always email us.
Per the WMI guide you set additive to 50 to start, scaling to 60, min boost to 10psi. Only setting I see missing is the additive.
Car: Supra
Default 09-17-2020, 01:37 PM
Awesome and thank you. Iíll make the change and make a few logs. Should I post them in the support/log review or email them? I appreciate the help.
Default 09-17-2020, 04:03 PM
Email is faster usually.
