markycee30 markycee30 is offline
Car: M140
Default BM3 with JB4 - 08-20-2020, 06:59 AM
Hi, I see people run flash tunes with JB4 on top. The advantages are:-
1, Can use JB4 mobile app to monitor live dials (AFR/timing etc)
2, JB4 offers more protection circuits (will drop boost if it sees bad AFR etc)
3, JB4 meth capability
So if I run JB4 on top of BM3, can anyone confirm what maps are safe to run?? I asumme avoid everything apart from Map 0? Someone also mentioned map 4 is okay, but not sure if that's correct???
Appreciate some advice
tx
Default 08-21-2020, 11:01 AM
You are correct, that is exactly what people do.
It depends on how aggressive your flash is to begin with. So we would like to see logs on map 0 (JB4 off for logging only) And see what it would be safe at.
IF you haven't gone with BM3 yet, you should look into MHD+JB4. Cheaper and that's what thousands of people are running
Car: M140
Default 08-22-2020, 01:28 AM
Hi Payam, Thanks for responding. I have installed BM3 yesterday and put JB4 on top. I did a 2nd, 3rd 4th pull and will attach teh log. Would you mind taking a look. I tried map one and the car felt good, but this log is using map0
Car: M140
Default Bm3 JB4 log - Payam - 08-22-2020, 01:29 AM
Log attached hopefully
