Ke90 Ke90 is offline
B58_Dude
Car: M240i
Default LPFP Replacement Upgrade - 04-14-2020, 04:59 PM
Has anyone replaced their Low Pressure Fuel Pump?
Preferably on the M240i or similar. Currently upgraded HPFP but eventually I want to run full E85 and the LPFP will need to be upgraded.
I have had great results with E50 blend and will be going to E60 then E70 to see if fuel can keep up.
Just wanted to see if anyone has done this before and get a good discussion going!
B58_Dude
Car: M240i
Default 08-14-2020, 12:59 PM
If anyone is following this. Here is one from Vader Solutions
https://vadersolution.com/collection...ge-3-fuel-pump
Here is a review of the install from NoClutch Garage
STAGE 3 LOW PRESSURE FUEL PUMP BY VADER SOLUTIONS - COMPLETE INSTALLATION GUIDE - YouTube
I did reach out to Walbro to see if their universal one will fit. No response yet. Also, reached out to Vader solution for pump specifications because I couldn't find anything on website; no response yet.
JBoe JBoe is offline
Car: M240i
Default 08-15-2020, 04:57 PM
To my knowledge, M240 only has the one pump. Am I wrong on that? Many have upgraded to the Supra pump and some are running full E85. Most run a high blend E50ish after upgrading the pump.
That's been my experience.
AFE Drop-in Filter
BMS Meth Kit (100% M1)
Muffler Delete
CA 91 Piss Gas...
(8oz Boostane 95ish Oct)
E85 (2Gal/Fill)
BEF (Race_WMI)
JB4 (Map 7 - Add 45... 19-20psi)
VipinLJ VipinLJ is offline
Default 08-15-2020, 08:01 PM
I thought the LPFP is the one in the fuel tank? I thought all cars had two FPs?
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
2016 BMW X3 xDrive28i
Car: M240i
Default 08-15-2020, 08:12 PM
I see... Guess I didn't consider that as the HP pump upgrade alone is supposed to support 600hp on pump gas. Higher if you're WMI/Injected on top of that. There's a Supra member pushing high HP and a few M240 pushing over 600. It may be best to PM them and share the info here. Most don't browse topics often enough to respond. I'm often away for weeks+.
AFE Drop-in Filter
Muffler Delete
CA 91 Piss Gas...
E85 (2Gal/Fill)
BEF (Race_WMI)
B58_Dude
Car: M240i
Default 08-16-2020, 09:20 PM
I want to run full E85. I am having difficulty with Trims stuck at 25 and car runs Lean with 20+PSI on higher than E60 blends (happens randomly post shift, I can tell so I let up immediately to avoid limp mode and messing up car). Thus upgrading my LPFP should solve all this.
I know other members are pushing good numbers with pump gas. I rather run E85 + WMI with my build, plus eventually when I upgrade Turbo, I will already have the fueling capabilities to support for Port Injection.
Car: M240i
Default 08-16-2020, 11:28 PM
So you've already upgraded the HPLP? Again, I thought that's all that was needed to run straight E85? That's why the forums are so great... the info never stops. Lol!
AFE Drop-in Filter
Muffler Delete
CA 91 Piss Gas...
E85 (2Gal/Fill)
BEF (Race_WMI)
B58_Dude
Car: M240i
Default 08-17-2020, 04:11 AM
Yes, Dorch stage 2.
One person I know has been able to run straight E85. But for some reason I keep running into the lean issue. But in mean time I got my BMS WMI kit I need to install, once chargepipe finally comes in. Iím hoping this will solve any issues and lower my trims when running the 20+ PSI.
