suspenceful's Avatar
Car: 2008 BSM 135i
Default My Experience Installing MMP Stage 3 Turbos - 07-27-2017, 09:20 AM
UPDATE: I ran the turbos hard at 28-30psi for about 500 miles and then my motor gave up. Dropped compression on cylinder #3. After removing the motor and turbos, I decided to switch my setup for various reasons. Watch this video I put together for the full scoop.
https://www.youtube.com/watch?v=2XJfkXMBlJA
On a constant quest for more power, I found myself looking to upgrade from my stock turbos. As you all know, there are a few different options available and even some single turbo conversion kits. After doing some research, I was set on a pair of MMP Stage 3 turbos. They offer 700whp capability with OEM fitment and come at a great price - everything I was looking for. While MMP has had some hiccups, I know Mauricio has great customer service so I didn't hesitate and pulled the trigger.
I opted for fully-optioned MMP Stage 3 turbos which included a 2 year turbo warranty with the bearing treatment. These turbos require larger inlets and outlets, so I opted for MMP's silicone outlets and aluminum relocation inlets since I already relocated things for aftermarket inlets on my stock turbos. I also ordered the turbo install kit because I wanted fresh o-rings, gaskets, etc.
After reading some DIY N54 turbo install guides, I decided to tackle the job in my garage on jack stands. This would be one of the most involved projects I've ever attempted on my own, but I knew it was possible.
If you don't want to read this whole article about my installation experience, you can scroll to the end to see a finished photo and a few videos. I have driven over 500 miles on these turbos already and they're great! I recently installed an upgraded fuel system and these turbos pull very hard at 28PSI without a problem. I would definitely recommend MMP Stage 3 turbos to anyone who wants more power out of their N54.
Since I planned on dropping the front subframe, I wanted to replace some things while I was in there and had easy access. Here is a list of parts I bought for my 6-speed 2008 BMW 135i:
Since I am chasing 700whp, I decided to upgrade my clutch and fuel system at the same time (not required when just replacing turbos).Preventative maintenance:
None of these are required except for the motor oil and coolant because they will be drained while removing the turbos. I simply replaced all of the above parts as preventative maintenance. My oil pan gasket and oil filter housing gaskets were slowly leaking and my passenger-side motor mount was torn.
NOTE: Some people also recommend replacing the 8 turbo oil feed/drain and water feed/return lines, but I reused my existing lines (with new gaskets/o-rings of course). Some people also replace the turbo manifold studs and nuts, but I left the studs in and reused the nuts.
Now that we've gathered all of our parts, let's get to business! I put the car in the air and took off the front bumper for easy access.
Undertrays removed, time to get this subframe out!
I don't have the most tools in the world, but I managed to get the subframe and steering rack out in about 4 hours. I used an engine support brace from Harbor Freight to hold up the engine before dropping the subframe.
2 hours later I had the downp!pes, intercooler, inlets, outlets, fan, engine mount, water pump, thermostat, and coolant pipe out of the car. Don't forget to drain the oil and coolant before getting too far.
In the process I discovered what coolant tasted like and was covered in grime, but knew I was making good progress. Next, I disconnected the oil and coolant lines from the block, then removed the stock turbos. Unbolting the manifolds was the easy part. Removing the coolant and oil lines from the block was more difficult than I expected. It was a painful, tedious process because I needed to reuse the lines. Be careful with these lines if you plan on reusing them!
Look at all of that room! Now that the stock turbos were out, I had to compare them to my new MMP Stage 3 turbos.
Next, I removed the power steering pump so I could remove the oil pan to replace that gasket. Once the oil pan was out, I cleaned and reinstalled it with a new gasket, bolts, and oil level sensor o-ring. Be sure to follow the proper bolt torquing procedure if you're replacing the oil pan gasket.
The subframe was filthy from the oil pan gasket leak, so I cleaned it.
After this, I wanted to mockup the turbos with the MMP inlets and outlets attached to get a better idea of fitment.
Then I began to swap all the oil and coolant lines over to the MMP turbos but ran into a bit of an issue.As Mauricio notes in the installation instructions, you must use the included small washers on the bolts when reattaching the oil feed and coolant lines to the turbos. If you don't, you will bottom out the bolt and pull the welds off that hold the mount on. Ask me how I know - whoops! This was my own fault.
Luckily I had a friend who welded the stainless mount back to the cast cartridge housing.
Make sure all of your oil and coolant lines are in good condition and free of debris. Clean them up and blow compressed air through them before reinstalling. I found it was easier to mount the two coolant return lines to the block first and then secure the rest of the lines to the turbos on the bench. Replace all of the o-rings and gaskets on these lines carefully. Remember, use small washers and do not over torque the bolts during reassembly.
I got back underneath the car and cleaned up the mounting surfaces, then installed both turbos with new manifold gaskets. Rear turbo goes on first. It's easiest to reinstall the heat shields while the turbos are loose. Reconnect the coolant return lines to the turbos once they're mounted and then torque everything down.
Next, I wrapped the inlets and outlets with heat-resistant tape just for added reassurance. Since I already relocated things for aftermarket inlets on my stock turbos, I didn't have to do anything special this time around. I did remove the bracket for the OEM rear inlet from the block at this time because I had the space.
I installed the outlets first. Make sure the couplers are properly seated and the clamps are tight. Then I installed the inlets, but had to remove the upper OEM heat shield and boost solenoids.
I could see the light at the end of the tunnel and was determined to get the car back on the ground. I set the camera down and did the following:
  • Reattached power steering pump to oil pan
  • Reinstalled coolant pipe, water pump, thermostat with new hoses
  • Reinstalled intercooler
  • Reinstalled downp!pes with new v-band clamps
  • Connected the O2 sensors
  • Attached new motor mounts
  • Finally reinstalled the subframe!
  • Reinstalled power steering rack and refilled power steering fluid
  • Mounted boost solenoids (required heat shield modification)
  • Connected all vacuum lines
  • Replaced the oil filter housing gaskets
  • Double checked that everything was connected and tightened
  • Added oil, oil filter, and coolant, then bled the coolant system
  • Unplugged the injectors and cranked the car to prime the turbos
  • Started the car!
I was able to put on about 200 miles over weekend without a single issue! It was a great feeling being able to start the car and drive it without any problems.
These things are loud (in a good way)! I didn't reattach the exhaust to the car yet, so it's just dumping from the downp!pes.
After putting a couple hundred miles on the turbos, I decided to see what they felt like targeting 20PSI to redline.
After this pull, I ordered a Stage 3+ LPFP and port injection from Precision Raceworks so I can raise the boost (read my post about installing those parts here). Stay tuned for updates!
Overall, I'm very impressed with the quality, fit, and performance of these turbos for the price! I would definitely recommend them if you're looking to upgrade your N54 turbos. Quick spool, OEM fitment, higher boost ceiling, and no wastegate rattle!
UPDATE: Check out my post where I installed the upgraded fuel system and turned up the boost!
🚀 My 750HP 135i build: my1series.com
🔧 My budget 335i build: bmw335i.com
📷 Follow me on Instagram: instagram.com/jakespence
🎬 Watch me on YouTube: youtube.com/jakespence135
🌟 Support me on Patreon: patreon.com/jake_spence
🏁 Shop BMW merchandise: bimmerstreet.com
Car: 2008 E93
Default 07-27-2017, 03:00 PM
Thanks for taking the time to post info and pics !
3er's Avatar
3er 3er is offline
Car: E90 335i xDrive
Default 06-20-2020, 07:37 AM
Thanks for the writeup and well done on the install! Sorry to be resuscitating a 3 year old thread here but I had a question that maybe you'd be able to help me out with, OP.
I'm currently replacing my N54 with one that actually ...works.... and in the process I'm installing MMP Stage 3s. Only issue that I've run into is with bending the coolant line for the rear turbo, any insights on how you did it?
Should I secure it to the block and bend it there? Heat? I've had mild success with a propane torch and a screwdriver but it goes very slowly that way. And if it can be done without heat I'd prefer that.
Thanks in advance, I've been looking at the results you got with these twins and am very excited to be up and running with them.
E46 M52TUB28 - Gone but never forgotten
E90 N54 - Survivor of an engine transplant!
Car: 2008 BSM 135i
Default 06-22-2020, 04:32 PM
I just used a factory 335i RWD coolant line. I believe everything should fit fine if you have an E90. Only the 135i had to switch or modify the coolant line.
scubamark3995 scubamark3995 is offline
Car: 2007 335i coupe
Default Mop turbos - 06-24-2020, 02:42 PM
I purchased the next generation stage 3 turbos from MMP last year. Took me awhile to get everything together and install. The car I bought had a bad motor. So I purchased a junk yard motor and transmission. Mfactory lsd. Got a tune. When I opened the mmp turbo box, I. Noticed that the rear turbo had more drag than the front turbo. I called mmp service. Got a fellow called Gene. He said it was an oiling issue. That once I start it up and oil is flowing through the turbo, it would spin just fine. Finally got it running and was driving it around. If I floored it , it was pretty good. A decent amount of punch. when I tried to drive under normal conditions. Part throttle. it had a bad lag from 0 to about 25 percent throttle opening. Once I passed around 25 percent open, it took off. Just hit kinda hard. I had some turbo leaks that I was fixing. I had the down ***** off in order to get to the turbos. I noticed that I could see and reach the turbo impellers. The front still spun free. The rear still felt like it was binding. I called MMP service. Got Gene on the phone. At first he was trying to blame the tune. But I didnít see it that way. Gene got in touch with Mauricio. Mauricio told Gene for me to send the turbo to him. So I did. About 3 months ago. Gene has since quit. And Mauricio wonít write me back . There isnít a service phone number anymore. Trying to be patient. But I just donít like where this is going.
