tboudre's Avatar
tboudre tboudre is offline
Car: 2011 BMW 335xi E90 N55
Default Adaptive Headlight Broken Mount - 05-17-2020, 10:58 AM
First of all I appreciate any input, and I'll post my trials and tribulations later but as a preview, J.B. Weld is the bomb.
I tore down the headlight assembly, apparently, the ball & socket joints to the manual adjustments and servo are pretty flimsy as I have seen many posts of people with the same issues.
But after I put (not quite) everything back together my car is somewhat cross-eyed. Can this be fixed with coding or do I need to tear down the assembly and adjust the servo manually? What "registery keys" control the left/right servo?
As another option, seems to be a stepper motor, I should be able to advance it if I knew what voltage it takes, but that might be just as much trouble as tearing it down again & repositioning.
Thanks In Advance,
Troy
